05-20-2017, 12:39 | #18361 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Sri Lanka Age: 35
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Selected model: SM-J710FN Software version: 28.1 Searching Samsung modem... detected COM332 Reading phone info... Ok Model: SM-J710FN AP version: J710FXXU2AQA8 CSC version: J710FDBT2APK1 CP version: J710FXXU2AQB1 Product code: SM-J710FZKNDBT Phone SN: RF8J2125PBW Unique number: C000057485385B3 Reading IMEI... Ok IMEI: 355233087826762 (SIGN: OK) Reading data from phone... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.1 |
05-20-2017, 12:40 | #18362 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Searching Samsung modem... detected COM402 Reading phone info... Ok Model: SM-G930F AP version: G930FXXU1BPLB CSC version: G930FOXA1BPLB CP version: G930FXXU1BPJJ Product code: SM-G930FZDABTU Phone SN: R58H4192FGD Unique number: 9886784E4E464D3341 Reading IMEI... Ok IMEI: 359467072387093 (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON335 HWID: 88 72 97 FE 3A E3 82 BC 56 6C 61 AC C1 36 DF 89 Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:01) Freeze code: 02474196 NET lock: 50282036 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.1 |
05-20-2017, 12:44 | #18363 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Read Codes Selected model: SM-A510F Software version: 28.1 Searching Samsung modem... detected COM44 Reading phone info... Ok Model: SM-A510F AP version: A510FXXU3BPK4 CSC version: A510FOXX3BPK4 CP version: A510FXXU3BPK4 Product code: SM-A510FEDAXEF Phone SN: R58XXXXXXX Unique number: C00000D8A13EA33 Reading IMEI... Ok IMEI: 357XXXXXXXXXXX (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON310 HWID: 91 5C 38 A3 C1 D9 D1 91 5E FF CE 06 8E AB D1 15 Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:06) Freeze code: 69053638 NET lock: 14163173 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.1 |
05-20-2017, 12:46 | #18364 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Unlock Selected model: GT-S5510 Software version: 28.1 Searching Samsung modem... detected COM69 Reading phone info... Model: GT-S5510 Country code: ½º¿þµ§ Cal date: 2009-11-06 Factory SW: S5510CSIK1 Unique number: 80210000527276 Memory phone: K5E1H12ACM(S5510) Reading SYSINFO... Ok Searching server... Ok Writing sysinfo... Ok Reseting... Ok Unlock done Done with Samsung Tool PRO v.28.1 |
05-20-2017, 12:46 | #18365 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP/React/EE Selected model: SM-J200G Software version: 28.1 Searching Samsung USB Flash interface... COM5 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.1 |
05-20-2017, 12:47 | #18366 (permalink) |
05-20-2017, 13:39 | #18367 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP Selected model: SM-G532G Software version: 28.1 Waiting ADB device... Ok Reading phone info... Model: SM-G532G Android version: 6.0.1 Product code: SM-G532GZDDXSG Phone version: G532FDXU1APJ7 PDA version: G532GDXU1APJ7 CSC version: G532FOJV1APJ1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.300 Phone SN: R58J23P2BMJ Chip name: MT6737T Modem board: MT6737T Security patch: 2016-10-01 RF cal date: 20170216 IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.1 |
05-20-2017, 14:48 | #18368 (permalink) |
Freak Poster Join Date: Aug 2013 Age: 33
Member: 1996171 Status: Offline Thanks Meter: 74 | Repair DRK G925P 6.0.1 Code: REPAIR INSTRUCTIONS: Activate Diagnostic Port: 1. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Select device in ADB settings. 2. Press 'Activate Diag' button. Reset EFS, Disable Factory Mode: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. 1. Power on phone in download mode (turn off phone, hold Volume Down + Home + Power). 2. Connect USB cable, install drivers if needed. 3. Press 'Wipe EFS/NVM' button to deactivate security. 4. Wait till phone reboot. Operation: Repair DRK Selected model: SM-G925P Software version: 28.2 Checking local file... not found Searching server... Ok Downloading file... Ok Checking local file... Ok Searching USB Flash interface... COM28 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Sending data to phone... Ok Waiting ADB device... Ok Reading phone info... Recovery build version: 6.0.1 Boot version: G925PVPU3BOI1 Platform: exynos7420 Boot serial: 06157df683926328 Product board: zerolte Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Checking DRK status... Ok Repairing DMVT key... Ok Rebooting phone... Ok Repair DRK done Done with Samsung Tool PRO v.28.2 |
05-20-2017, 14:50 | #18369 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | SAMSUNG SM-G920F FRP UNLOCK DONE Operation: Reset FRP/React/EE Selected model: SM-G920F Software version: 28.2 Searching Samsung USB Flash interface... COM7 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.2 |
05-20-2017, 21:45 | #18370 (permalink) |
No Life Poster Join Date: Apr 2013 Location: morocco Age: 36
Member: 1917054 Status: Offline Thanks Meter: 268 | SM-J510FN Reset FRP Done Operation: Reset FRP/React/EE Selected model: SM-J510FN Software version: 28.2 Searching Samsung USB Flash interface... COM22 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.2 |
05-20-2017, 22:01 | #18371 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | LG 2-3G Tool v9.34 supported models: 1445 Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507940040-0 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3311 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3312 Reboot phone Done Elapsed: 44 secs. --> (v9.34) Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507940041-8 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3314 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3313 Reboot phone Done Elapsed: 44 secs. --> (v9.34) Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507017360-0 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3316 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3315 Reboot phone Done Elapsed: 45 secs. --> (v9.34) Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507159345-9 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3318 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3317 Reboot phone Done Elapsed: 44 secs. --> (v9.34) Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507940038-4 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3320 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3319 Reboot phone Done Elapsed: 44 secs. --> (v9.34) Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507005720-9 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3322 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3321 Reboot phone Done Elapsed: 44 secs. --> (v9.34) Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507934455-8 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3324 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3323 Reboot phone Done Elapsed: 44 secs. --> (v9.34) Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507934455-8 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3324 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3323 Reboot phone Done Elapsed: 44 secs. --> (v9.34) Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507934455-8 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3324 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3323 Reboot phone Done Elapsed: 44 secs. --> (v9.34) Port already opened! Elapsed: 0 secs. --> (v9.34) Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507156916-0 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3326 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3325 Reboot phone Done Elapsed: 44 secs. --> (v9.34) Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507157824-5 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3328 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3327 Reboot phone Done Elapsed: 45 secs. --> (v9.34) Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507006206-8 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3329 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3330 Reboot phone Done Elapsed: 44 secs. --> (v9.34) Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507159059-6 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 3 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3331 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3332 Reboot phone Done Elapsed: 44 secs. --> (v9.34) Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507115483-1 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 4 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3333 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3334 Reboot phone Done Elapsed: 44 secs. --> (v9.34) Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507157081-2 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3335 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3336 Reboot phone Done Elapsed: 45 secs. --> (v9.34) Mode: Normal Model: LGK371AT Build version: Sep 29 201612:58:09Sep 28 201600:00:00LGK371AT SW Version: MPSS.JO.1.0.c5.7-00030-M8909EAAAANVZM-1.71849.3 IMEI: 35488507940044-2 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v9.34) Direct unlock Working with security zone Checking phone at COM3338 Reboot phone Phone detected! Repair IMEI... Search LG Modem port... Detected LG Modem port at COM3337 Reboot phone Done Elapsed: 44 secs. --> (v9.34) |
05-20-2017, 23:37 | #18372 (permalink) |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | g532m unlock ok Operation: Unlock Selected model: SM-G532M Software version: 28.2 Waiting ADB device... Ok Reading phone info... Model: SM-G532M Android version: 6.0.1 Product code: SM-G532MZKADOR Phone version: G532MUBU1APK4 PDA version: G532MUMU1APK4 CSC version: G532MUWE1APL1 CSC country code: DOMINICAN REPUBLIC CSC sales code: DOR HW version: MP 0.300 Phone SN: R58J3188B9F Chip name: MT6737T Modem board: MT6737T Security patch: 2016-11-01 RF cal date: 20170307 IMEI: Checking Super user right... true Reading security... Ok Unlocking... Ok Writing security... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.2 |
The Following User Says Thank You to frankcelular1 For This Useful Post: |
05-21-2017, 07:29 | #18373 (permalink) |
Freak Poster Join Date: Jan 2015 Location: GSM Net Age: 46
Member: 2334036 Status: Offline Thanks Meter: 131 | A520F Unlock Operation: Unlock Selected model: SM-A520F Software version: 28.2 Searching Samsung modem... detected COM13 Reading phone info... Ok Model: SM-A520F AP version: A520FXXU1AQD3 CSC version: A520FVFG1AQC8 CP version: A520FXXU1AQD3 Product code: SM-A520FZKAMOB Phone SN: R58J1****** Unique number: CBJ10C6******** Reading IMEI... Ok IMEI: 3546070******** Reading SN... Ok Phone SN: R58J****** Enter MSL: 2712474249193E48*************** Bypass MSL... Ok Unlocking... Ok Codes set to 00000000 Rebooting phone... Ok Unlock done |
The Following User Says Thank You to mach6 For This Useful Post: |
05-21-2017, 09:34 | #18374 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,709 | G532F FRP reset done Code: Operation: Reset FRP Selected model: SM-G532F Software version: 28.2 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... Ok Reading phone info... Model: SM-G532F Android version: 6.0.1 Product code: SM-G532FZDATUR Phone version: G532FXXU1AQB3 PDA version: G532FXWU1AQB5 CSC version: G532FOJV1AQB5 CSC country code: CSC sales code: HW version: MP 0.300 Phone SN: Chip name: MT6737T Modem board: MT6737T Security patch: 2017-03-01 RF cal date: 20161020 IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.2 |
05-21-2017, 10:10 | #18375 (permalink) |
Member: 1614640 Status: Offline Thanks Meter: 468 | GT I9000 NETWORK LOCK UNLOCK DONE Operation: Unlock Selected model: GT-I9000 Software version: 28.2 Waiting ADB device... Ok Reading phone info... Model: GT-I9000 Android version: 2.3.6 Product code: GT-I9000HKDSER Phone version: I9000XXJPK PDA version: I9000XWJVW CSC version: I9000SERJV5 CSC country code: Russia CSC sales code: SER HW version: MP 0.800 Phone SN: 00000000000 Modem board: RF cal date: 2010.11.18 IMEI: 354795043014866 Checking Super user right... false Rooting phone, please wait... Ok Checking Super user right... true Reading NV data... Ok Checking magic... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.2 |
The Following User Says Thank You to bright hlatini For This Useful Post: |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
