Unlock sprint N910P by 26.1 no need root UNLOCK INSTRUCTIONS: Direct Unlock: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button. Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 5. Select device in ADB settings. 6. Press 'Unlock Domestic' button. Operation: Unlock SPRNT Selected model: SM-N910P Selected port: COM3 USB Serial Port Software version: 26.1 Waiting ADB device... OK Reading phone info... Model: SM-N910P Android version: 5.1.1 Product code: Not Active Phone version: N910PVPU4COG5 PDA version: N910PVPU4COG5 CSC version: N910PSPT4COG5 CSC country code: USA CSC sales code: SPR HW version: N910P.05 Phone S/N: 00000000000 Modem board: MDM9625M RF cal date: 2014.11.08 IMEI: Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.1 |
Operation: Unlock Selected model: 403SC Selected port: COM119 SAMSUNG Mobile USB Serial Port Software version: 26.1 Reading phone info... Reading IMEI... OK IMEI: 357084061054337 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.1 |
Operation: Unlock Selected model: SM-R750T Software version: 26.1 Waiting SDB device... OK Reading phone info... Model: SM-R750T Build: R750TUVU1AOA7 Tizen version: Tizen release 2.2.0 (Magnolia) Checking Super user right... true HW version: REV0.3 Phone S/N: R3AG600VDYJ Product code: SM-R750TZKATMB Initialization Tizen RIL... OK Unlocking... OK Rebooting... OK Unlock done Done with Samsung Tool PRO v.26.1 |
Samsung GT-C3592 Direct Unlock DONE............ Code: UNLOCK INSTRUCTIONS: |
i9100p unlocked Code: Operation: Unlock |
UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J500F Selected port: COM175 SAMSUNG Mobile USB Serial Port Software version: 26.0 Reading phone info... Reading IMEI... OK IMEI: 3597XXXXXXXX Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.0 |
Unable to repair IMEI - GT-N7100 I always get this error, zTool not found for this selected model how to fix this ? This is the log, Waiting ADB device... OK Reading phone info... Model: GT-N7100 Android version: 4.3 Product code: Not Active Phone version: N7100DDDMG1 PDA version: N7100XXUEMK4 CSC version: N7100ODDEMK1 CSC country code: India CSC sales code: INU HW version: Unknown Phone S/N: 00000000000 Modem board: XMM6262 RF cal date: Unknown IMEI: 004999010640000 Checking Super user right... true Reading nv data... OK Checking magic... OK zTool not found for selected model Done with Samsung Tool PRO v.24.3 |
Operation: Reset Pattern Lock Selected model: SM-N920T Software version: 26.1 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM7 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Android version: 6.0.1 Boot version: N920TUVU3DPG1 Platform: exynos7420 Boot serial: 0815f828b3e62b02 Product board: zenlte Erasing locks... OK Rebooting phone... OK Reset locks done Done with Samsung Tool PRO v.26.1 |
G920F write cert done Samsung s6 g920f 6.0.1 imei damaged 350000000006 fixed by write cert Code: Operation: Write CERT |
Samsung Sm-G531h FRP Code: Operation: Reset FRP/React/EE |
LG P700 Unlock . Mode: Normal Model: P705 Build version: Dec 19 201412:20:05Feb 22 201300:00:00P705 SW Version: P705-M7227A-V20c-DEC-15-2014-XX IMEI: 352******67189-* BlueTooth Address: 00:AA:70:F3:0A:DF Phone Code: default Elapsed: 2 secs. --> (v9.19) Mode: Normal Model: P705 Build version: Dec 19 201412:20:05Feb 22 201300:00:00P705 SW Version: P705-M7227A-V20c-DEC-15-2014-XX IMEI: 35**********89-* BlueTooth Address: 00:AA:70:F3:0A:DF Phone Code: default Elapsed: 2 secs. --> (v9.19) Check adb server status... OK Found 1 device(s) Device name: LG-P705 Firmware version: LGP705AT-01-V20c-208-10-DEC-15-2014+0 Android release: 4.1.2 Platform: msm7627a Start root... Send exploit: OK! Install exploit: OK! Root status: OK! Read sec zone Read sec zone OK! Sec zone saved: C:\Program Files\Z3X\LG\LGTool\Backup\P705_352248051671898_27 072016_132457.lgsb Security format: New IMEI[1] block found! IMEI[2] block not found! SimLocks block found! SimLocksCounter block found! SimLocks clear OK! Signature created! Write sec zone Write sec zone OK! Write new signature Write new signature OK! Done! Elapsed: 28 secs. --> (v9.19) |
Unlock L600 BY 26.1 http://ultraimg.com/images/2016/07/2...eenshot.md.png |
g935f frp done one single click Operation: Reset FRP/React/EE Selected model: SM-G935F Software version: 26.2 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM4 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZSUINS Phone version: G935FXXU1APEQ PDA version: G935FXXU1APF2 CSC version: G935FODD1APF2 CSC country code: India CSC sales code: INS HW version: MP 0.801 Phone S/N: RZ8H30GXQHN Modem board: SHANNON335 RF cal date: 20160312 IMEI: Checking Super user right... true Erasing FRP... OK Checking local file... error (md5 mismatch) Searching server... OK Downloading file... OK Checking local file... OK Restoring kernel... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.26.2 |
Searching Samsung modem... detected COM32 Reading phone info... OK Model: SM-J320A AP Version: J320AUCU1APC9 CSC Version: J320AATT1APC9 CP Version: J320AUCU1APC9 Product code: SM2J320AZWAATT Phone S/N: R28H527H5TZ Imei: 355022xxxxxxxxxxxx Unique number: CQ300DB036A2643 Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.2 |
