Repai imei G920F failed wath is wrong. MODEL G920F Bootloader : G920FXXS4DPJ2 Build Nr. MMB29k Andr: 6,0,1 Operation: Repair Selected model: SM-G920F Software version: 27.3 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G920F Android version: 6.0.1 Product code: Phone version: PDA version: G920FXXU3DPCA CSC version: G920FXEG3DPC3 CSC country code: Germany CSC sales code: XEG HW version: Phone SN: RF8GB1VX9VD Chip name: EXYNOS7420 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Exception: Format 'error (%s)' invalid or incompatible with argument Done with Samsung Tool PRO v.27.3 |
j320fn ney security 2016 read code ok with out root UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 11111111 To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-J320FN Software version: 27.3 Searching Samsung modem... detected COM83 Reading phone info... Ok Model: SM-J320FN Version: J320FNXXU0APK2/J320FNOXX0APK1/J320FNXXU0APK1/J320FNXXU0APK2 Product code: SM-J320FZKNXEF Phone SN: RF8HA2N5FWV IMEI: 3527180xxxxxxx Unique number: CQN0033E8C453A3 Reading codes... Ok Please wait, calculating codes... OK (time - 00:00:45) Freeze code: 04794837 NET lock: 25816361 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.3 |
G930F Frp reset done Code: Operation: Reset FRP/React/EE |
Samsung S5 Neo Read Cert SIM card must be taken out. Operation: Read CERT Selected model: SM-G903W Software version: 27.3 Searching Samsung modem... detected COM119 Reading phone info... Ok Model: SM-G903W AP version: G903WVLU1BPF1 CSC version: G903WOYA1BPF1 CP version: G903WVLU1BPF1 Product code: SM-G903WZKARWC Phone SN: RFxxxxxxxxxx Unique number: C0xxxxxxxxxxxxxxx Reading IMEI... Ok IMEI: 354xxxxxxxxxxxxxx (SIGN: OK) Reading data from phone... Ok Modem board: SHANNON310 Checking NV data... Ok Calculating... Ok HWID: E5 7C 6A 38 60 79 6D F4 EE 73 39 BD 4A 82 F6 82 Certificate file saved to C:\Program Files\Z3X\Samsung\SamsungTool\backup\Cert\SM-G903W_RFxxxxxxxxxxx_354xxxxxxxxxxxxxx_1-12-2016_11-3-20.cert Done with Samsung Tool PRO v.27.3 |
[ 12/1/2016 8:22:00 AM ] Operation: Read CERT [ 12/1/2016 8:22:00 AM ] Selected model: SM-J120A [ 12/1/2016 8:22:00 AM ] Software version: 27.2 [ 12/1/2016 8:22:00 AM ] [ 12/1/2016 8:22:00 AM ] Searching Samsung modem... detected COM210 [ 12/1/2016 8:22:00 AM ] Reading phone info... Ok [ 12/1/2016 8:22:00 AM ] Model: SM-J120A [ 12/1/2016 8:22:00 AM ] AP version: J120AUCU2APJ2 [ 12/1/2016 8:22:00 AM ] CSC version: J120AATT2APJ2 [ 12/1/2016 8:22:00 AM ] CP version: J120AUCU2APJ2 [ 12/1/2016 8:22:00 AM ] Product code: SM2J120AZWBATT [ 12/1/2016 8:22:00 AM ] Phone SN: R58XXXXXX [ 12/1/2016 8:22:00 AM ] Unique number: CFN009881A15853 [ 12/1/2016 8:22:00 AM ] Reading IMEI... Ok [ 12/1/2016 8:22:00 AM ] IMEI: 356XXXXXXXXXX3 (SIGN: OK) [ 12/1/2016 8:22:00 AM ] Reading data from phone... Ok [ 12/1/2016 8:24:00 AM ] Modem board: SHANNON308 [ 12/1/2016 8:24:00 AM ] Checking NV data... Ok [ 12/1/2016 8:24:00 AM ] Calculating... Ok [ 12/1/2016 8:24:00 AM ] HWID: A4 9B 35 5A 91 7B 87 99 16 E2 94 5B 3C A5 8E A3 [ 12/1/2016 8:24:00 AM ] Certificate file saved to C:\Program Files\Z3X\Samsung\SamsungToolPRO\backup\Cert\SM-J120A_R5XXXXXXX_356XXXXXXXXXXX_1-12-2016_8-24-23.cert [ 12/1/2016 8:24:00 AM ] |
BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Unlock Selected model: SM-G550T1 Software version: 27.3 Waiting ADB device... Ok Reading phone info... Model: SM-G550T1 Android version: 6.0.1 Product code: SM2G550TZKATMK Phone version: G550T1UVU1APF1 PDA version: G550T1UVU1APF1 CSC version: G550T1TMK1APF1 CSC country code: USA CSC sales code: TMK HW version: REV0.4 Phone SN: RVXXXXX Chip name: EXYNOS3475 Modem board: SHANNON308 RF cal date: 20160630 IMEI: Checking Super user right... true Initialization AT RIL... Ok Reading IMEI... Ok IMEI: 35XXXXXXXXXXX (SIGN: OK) Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.27.3 |
Waiting ADB device... Ok Reading phone info... Model: SM-G930F Android version: 6.0.1 Product code: Phone version: G930FXXU1APD1 PDA version: G930FXXU1APD8 CSC version: G930FOJV1APD8 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: 00000000000 Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.27.3 |
Samsung Galaxy SM-J320AZ Unlocked w/Z3X Box :-) UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J320AZ Software version: 27.1 Searching Samsung modem... detected COM47 Reading phone info... ok Model: SM-J321AZ AP version: J321AZTUU1APD1 CSC version: J321AZAIZ1APD1 CP version: J321AZTUU1APD1 Product code: SM-J321AZDZAIO Phone SN: R28H33KASXK Unique number: CQN00EFFAC4B123 Reading IMEI... ok IMEI: ........................... (SIGN: OK) Reading data from phone... ok Unlocking... ok Rebooting phone... ok Unlock done Done with Samsung Tool PRO v.27.1 |
g925i IMEI repair done android 5.1.1 thx z3x team |
z3x box samsung express modal imei not support bro help me plz bro... |
UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G928T Software version: 27.3 Searching Samsung USB Flash interface... COM35 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP... Ok Searching Reactivation lock... Ok Erasing Reactivation lock... Ok Searching EE lock... Ok Erasing EE lock... Ok Reset done Done with Samsung Tool PRO v.27.3 |
UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G928T Software version: 27.3 Waiting ADB device... Ok Reading phone info... Model: SM-G928T Android version: 5.1.1 Product code: SM4G928TZKATMB Phone version: G928TUVS2COKC PDA version: G928TUVS2COKC CSC version: G928TTMB2COKC CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R58G71TZ9RD Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: 20150728 IMEI: Checking Super user right... true Initialization AT RIL... Ok Reading IMEI... Ok IMEI: 353753070604324 (SIGN: OK) Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.27.3 |
UNLOCKED DONE J120AZ :D Searching Samsung modem... detected COM370 Reading phone info... Ok Model: SM-J120AZ AP version: J120AZTUU1APD2 CSC version: J120AZAIO1APD2 CP version: J120AZTUU1APD2 Product code: SM2J120AZKZAIO Phone SN: ------- Unique number: CFN00CC16C65B93 Reading IMEI... Ok IMEI: 3564190--------- (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON308 Checking NV data... Ok Calculating... Ok HWID: 4F 11 86 98 21 C1 8C D8 F9 6D E8 89 02 87 DD F4 Please wait, calculating codes... OK (time - 00:00:07) Freeze code: 31936175 NET lock: 86040947 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.3 S.G :) |
plz help me why samsung E2252 not connection box for unlocking sim how body know say samtang plz be fast |
SM-G361F unlock Operation: Unlock Selected model: SM-G361F Software version: 27.3 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-G361F Android version: 5.1.1 Product code: SM-G361FHAAVOD Phone version: G361FXXU1APD5 PDA version: G361FXXU1AOG1 CSC version: CSC country code: CSC sales code: HW version: MP 0.100 Phone SN: RV8G91R090B Modem board: RF cal date: 20150926 IMEI: Checking Super user right... true Reading NV data... Ok Analyzing SEC file... Ok Writing AT RIL... Ok Initialization AT RIL... Ok Bypass MSL... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.27.3 |
