thank you boss for sharing this usefull post |
Samsung E1207Y user lock unlock done by flash.... :D FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. Choose flash option if needed: -'Re-write NV' - Warning! This option will erase all calibration data! -'Single file firmware' - if you have *.pac firmware 3. Press 'Flash' button. 4. Connect phone in flash mode (Press 'OK' button (Centre of navigation buttons module) and connect USB cable). Operation: Flash Selected model: GT-E1207Y Software version: 22.2 Waiting phone... detected COM45 Sending FDL... OK Reconnecting phone... OK Reading NV... OK Saved to C:\Program Files\Z3X\Samsung\SamsungToolPRO\backup\NV\nvitem_ GT-E1207Y_24-8-2015_11-51-7.bin Sending SSBOOT... OK Sending PS... OK Sending CSC... OK Erasing FLASH... OK Flashing done (time - 00:01:52) Done with Samsung Tool PRO v.22.2 |
UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-N900A Selected port: COM173 SAMSUNG Mobile USB Serial Port Software version: 21.8 Reading phone info... Reading IMEI... OK IMEI: XXXXXXXXXXXXXX Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.21.8 UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G900A Selected port: COM175 SAMSUNG Mobile USB Serial Port Software version: 21.8 Reading phone info... Reading IMEI... OK IMEI: XXXXXXXXXXXXX Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.21.8 UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G900A Selected port: COM177 SAMSUNG Mobile USB Serial Port Software version: 21.8 Reading phone info... Reading IMEI... OK IMEI: XXXXXXXXXXX Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.21.8 UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G900A Selected port: COM179 SAMSUNG Mobile USB Serial Port Software version: 22.3 Reading phone info... Reading IMEI... OK IMEI: XXXXXXXXXXXXXX Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.22.3 UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G900A Selected port: COM181 SAMSUNG Mobile USB Serial Port Software version: 22.3 Reading phone info... Reading IMEI... OK IMEI: XXXXXXXXXXXXXX Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.22.3 UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G900A Selected port: COM183 SAMSUNG Mobile USB Serial Port Software version: 22.3 Reading phone info... Reading IMEI... OK IMEI: XXXXXXXXXXXXXX Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.22.3 UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G900A Selected port: COM185 SAMSUNG Mobile USB Serial Port Software version: 22.3 Reading phone info... Reading IMEI... OK IMEI: XXXXXXXXXXXXX Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.22.3 UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G900A Selected port: COM187 SAMSUNG Mobile USB Serial Port Software version: 22.3 Reading phone info... Reading IMEI... OK IMEI: XXXXXXXXXXXXXXX Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.22.3 UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G900A Selected port: COM189 SAMSUNG Mobile USB Serial Port Software version: 22.3 Reading phone info... Reading IMEI... OK IMEI: XXXXXXXXXXXXXXXXX Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.22.3 |
UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G900T Selected port: COM191 SAMSUNG Mobile USB Serial Port Software version: 22.3 Reading phone info... Reading IMEI... OK IMEI: XXXXXXXXXXXXXXXXXXX Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.22.3 |
Samsung j1 unlock by Read code done :) Operation: Read Codes Selected model: SM-J100H Software version: 20.5 Waiting ADB device... OK Reading phone info... Model: SM-J100H Android version: 4.4.4 Product code: SM-J100HZKAITV Phone version: J100HXCU0AOG1 PDA version: J100HXCU0AOG1 CSC version: J100HITV0AOG1 CSC country code: ITALY CSC sales code: ITV HW version: MP 0.201 Phone S/N: R51G711L9BB Modem board: sc7727s RF cal date: 20150711 IMEI: 35283007xxxxxxx Checking Super user right... true Running zTool, please wait... OK Reading codes... OK Please wait, calculating codes... [Update] Your firmware DB will be updated after model change or software restart. OK (time - 00:00:37) Freeze code: 20863152 NET lock: 29359473 :) For check lock status: *#7465625# Done with Samsung Tool v.20.5 Thanks z3x Team |
Samsung E1200y Read code Done :) Operation: Read Codes Selected model: GT-E1200Y Selected port: COM85 SPRD U2S Diag, Software version: 20.5 Reading phone info... OK IMEI Master: 35689106xxxxxxx Product code: Phone HW: MP 0.400 Phone S/N: RZ1FB2ALEN Reading codes... OK :) Please wait, calculating codes... OK (time - 00:00:10) Freeze code: 42403952 :) NET lock: 00000000 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool v.20.5 Thanks z3x Team |
G530H sucsefuul repaird by z3x |
Samsung SGH-T399N Network Searching problem solve by Z3X Box Pro... :D Waiting ADB device... OK Reading phone info... Model: SGH-T399N Android version: 4.4.2 Product code: Phone version: T399NUVUANK3 PDA version: T399NUVUANK3 CSC version: T399NTMBANK3 CSC country code: USA CSC sales code: TMB HW version: Phone S/N: RV8F90EQDVH Modem board: SS222 RF cal date: IMEI: 350695200123951 Checking Super user right... true Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.22.3 |
E1151 unlock done by Z3X Selected model: E1151 Selected com port: COM42 Selected speed port: 921600 Search 1 parts for flashing Please, connect phone and press power button Sending file: ../HW/EGVV3_FORMFACTOR/COBBLE_I/XMM1100.fls... OK Search 1 parts for flashing Sending file: ../HW/EGVV3_FORMFACTOR/VODAFONE_BA/cust_package_BA_Version_RCT.cust... OK Search 1 parts for flashing Sending file: ../HW/EGVV3_FORMFACTOR/COBBLE_I/XMM1100.eep... OK Flash FLS - ok Elapsed time: 192 second, sw ver: 3.5.0040 i just flashed it :):) |
S6310n unlock done Selected model: S6310N Selected port: COM232 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... PDA/CSC version: S6310NXXAMG1/S6310NSWRAMF2 Phone version: SW VERSION :None Phone HW: MP 0.100 Cal date: 2014.03.25 Reading IMEI... OK IMEI: 351942068417706 Phone S/N: RF1F336PNM Build: 76XXS-USUSKOLYM-2035 Done with Samsung Tool v.18.8 Selected model: S6310N Selected port: COM232 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... PDA/CSC version: S6310NXXAMG1/S6310NSWRAMF2 Phone version: SW VERSION :None Phone HW: MP 0.100 Cal date: 2014.03.25 Reading IMEI... OK IMEI: 351942068417706 Phone S/N: RF1F336PNM Build: 76XXS-USUSKOLYM-2035 Bypass MSL... OK Unlocking... OK Reseting... OK Unlock done Codes set to 00000000 Done with Samsung Tool v.18.8 Done with Samsung Tool v.18.8 NOTE after unlocking it restore to factory settings |
UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G850F Software version: 22.3 Waiting ADB device... OK Reading phone info... Model: SM-G850F Android version: 4.4.4 Product code: SM-G850FZDEMAT Phone version: G850FXXU1BOA2 PDA version: G850FXXU2BOA2 CSC version: G850FOJV2BOB1 CSC country code: MOROCCO CSC sales code: MAT HW version: MP 1.100 Phone S/N: R58FA______ Modem board: XMM7260 RF cal date: 2014.10.11 IMEI: 3560100________ Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 0 Calculating... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.22.3 THANKS Z3X TEAM |
