Samsung Galaxy ACE S5830I Direct Unlock done.. :D UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Applications'-'Development' for Android 2.x or 'Settings'-'Developer options' for Android 4.x. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: GT-S5830I Software version: 23.4.1 Waiting ADB device... OK Reading phone info... Model: GT-S5830i Android version: 2.3.6 Product code: Phone version: S5830iXXLB1 PDA version: S5830iBGLB3 CSC version: S5830iXECLB1 CSC country code: Spain CSC sales code: XEC HW version: MP 0.900 Phone S/N: R21C25MVDTB Modem board: RF cal date: 20120226 IMEI: 359160048731516 Checking Super user right... false Rooting phone, please wait... OK Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.23.4.1 |
andrew i m new here . i have pro version active and i want to unlock samsung ative s. can you help me |
Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-N920T Android version: 5.1.1 Product code: SM-N920TZWATMB Phone version: N920TUVU2COI5 PDA version: N920TUVU2COI5 CSC version: N920TTMB2COI5 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone S/N: RF8G722H1MN Modem board: SHANNON333 RF cal date: 20150726 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Writing nv data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.23.5 |
UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP' to deactivate Google account activation lock. 4. Press 'Reset Reactivation Lock' to deactivate Samsung reactivation lock. Operation: Unlock Selected model: SM-G920F Software version: 23.4 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 5.1.1 Product code: SM-G920FZWAVOD Phone version: G920FXXU3QOJQ PDA version: G920FXXU3QOJQ CSC version: G920FVFG3QOJQ CSC country code: UK CSC sales code: VOD HW version: MP 0.80V Phone S/N: R58G41916EY Modem board: SHANNON333 RF cal date: 20150418 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Writing nv data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.23.4 |
Unlocking g900w8 any one can help how to unlock g900w8 v5.0 with z3x pro. Thanks in advance |
GALAXY CORE PRIME SM-G360H READ CODE DONE BY Z3X PRO 23.5 http://i1356.photobucket.com/albums/...pstrxa55yr.jpg |
G928F 5.1.1 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SM-G928F Android version: 5.1.1 Product code: SM-G928FZDABTU Phone version: G928FXXU1AOH3 PDA version: G928FXXU1AOH3 CSC version: G928FOXA1AOH3 CSC country code: UK & IRE CSC sales code: BTU HW version: MP 0.500 Phone S/N: RF8GA15W03E Modem board: SHANNON333 RF cal date: 20151014 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:01) Freeze code: 18614158 NET lock: 41797931 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.23.4 |
successfully unlock s6 g925f 5.1.1 http://i65.tinypic.com/ri51l4.png |
Galaxy Note 2 T889 IMEI and Factory mode disable done.. :D REPAIR INSTRUCTIONS: Repair IMEI/Serial/BT/WiFi/Product Code: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Reboot phone. 4. Connect USB cable, install drivers if needed. 5. Select Samsung diagnostic port in port settings. 6. Press 'Reset MSL' button to deactivate security. 7. Wait till phone reboot. 8. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 9. Select device in ADB settings. 10. Fill values what you need to repair. 11. Press 'Repair' button. Reset EFS, Disable Factory Mode: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. To use 'Auto backup/restore QCN' function (recommended): Type *#0808# and select 'DM+MODEM+ADB'. Type *#9090# and select 'DM/DUN over HSIC'. Or you can disable this function and use ADB only. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select device in ADB settings. 6. Choose diagnostic port in port settings if 'Auto backup/restore QCN' is not skipped. 7. Press 'Wipe EFS/NVM' button. Operation: Repair Selected model: SGH-T889 Selected port: COM84 SAMSUNG Mobile USB Serial Port Software version: 23.5 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SGH-T889 Android version: 4.3 Product code: Not Active Phone version: T889UVUCOH4 PDA version: T889UVUCOH4 CSC version: T889TMBCOH4 CSC country code: USA CSC sales code: TMB HW version: Not Acti Phone S/N: RV1D53AJQHV Modem board: MDM9215M RF cal date: NONE IMEI: Initialization AT RIL... OK Bypass MSL... OK Repairing IMEI... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.23.5 |
Samsung G350 Galaxy Core Plus unlock done z3x Rooted with iRoot Operation: Unlock Selected model: SM-G350 Software version: 23.5 Waiting ADB device... OK Reading phone info... Model: SM-G350 Android version: 4.2.2 Product code: Phone version: G350XXUANB1 PDA version: G350XXUANB1 CSC version: G350OXXANC1 CSC country code: SEAD CSC sales code: SEE HW version: MP 0.500 Phone S/N: RV1DC07MGBP Modem board: RF cal date: 20131205 IMEI: 358495051786911 Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.23.5 |
