02-19-2016, 18:31 | #15646 (permalink) |
No Life Poster Join Date: Jun 2014 Location: GSM FORUM ♥
Member: 2207555 Status: Offline Thanks Meter: 1,622 | Galaxy Note 1 Flash Done 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: GT-N7000 Software version: 24.3 File analysis... OK Total file size: 0x3722C9AC (882 Mb) Searching USB Flash Interface... detected COM7 Setup connection... OK Reading PIT from phone... OK Sending boot.bin... OK Sending Sbl.bin... OK Sending param.lfs... OK Sending zImage... OK Sending factoryfs.img... OK Sending data.img... OK Sending cache.img... OK Sending hidden.img... OK Sending modem.bin... OK Sending cache.img... OK Flashing done (time - 00:04:16) Done with Samsung Tool PRO v.24.3 |
The Following User Says Thank You to rehansk8879 For This Useful Post: |
02-19-2016, 19:31 | #15647 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | UNLOCK INSTRUCTIONS: Micro-UART cable: 1. Phone must be powered on. 2. Type *#7284# and choose Modem for UART and PDA for USB options. 3. Type *#9090# and choose UART. 4. Reboot phone. 5. Connect the phone to UART port. 6. Choose correct COM port in port settings. 7. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Micro-USB cable: 1. Phone must be powered on. 2. Type *#7284# and choose Modem for USB and PDA for UART options. 3. Type *#9090# and choose HS-USB. 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: SGH-T989 Selected port: COM89 SAMSUNG Mobile USB Serial Port Software version: 24.3 Reading phone info... Model: SGH-T989 Country code: ªU Cal date: ªU Factory SW: T989UVMC6 Unique number: CKY25CB356A2F11 Memory phone: ªU Phone S/N: R21D17XXAB PDA/CSC version: T989UVMC6/T989TMBMC6 Phone version: SW VERSION :None Phone HW: REV0.1 Cal date: 2013.01.30 Reading IMEI... OK IMEI: 354778051829698 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.3 |
The Following User Says Thank You to ghacks For This Useful Post: |
02-19-2016, 21:50 | #15648 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Alabama, United States Age: 41
Member: 2489757 Status: Offline Thanks Meter: 6 | SM-G900A 5.0 unlock successfull Operation: Unlock Selected model: SM-G900A Selected port: COM164 SAMSUNG Mobile USB Serial Port Software version: 24.3 Reading phone info... Reading IMEI... OK IMEI: 354891062681097 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.3 |
02-20-2016, 08:50 | #15649 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | Searching Samsung modem... detected COM188 Reading phone info... OK Model: SM-J100H Version: J100HXXU0AOJ1/J100HOJV0AOJ1/J100HXXU0AOJ1/J100HXXU0AOJ1 Product code: SM-J100HZWDKSA Phone S/N: RV1G3203ZCE Imei: 358414066977423 Unique number: C01D7C0321022 Reading codes... OK Please wait, calculating codes... OK (time - 00:02:29) Freeze code: 71836924 NET lock: 38305294 For check lock status: *#7465625# Done with Samsung Tool PRO v.24.3 |
02-20-2016, 09:52 | #15650 (permalink) | |
Freak Poster Join Date: Apr 2010 Location: WESTJAVA - INDONESIA
Member: 1278042 Status: Online Sonork: 100.1656045 Thanks Meter: 117 | Unlock samsung SM-G920I done Quote:
02-20-2016, 10:46 | #15651 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Cebu Phils.
Member: 183390 Status: Offline Thanks Meter: 74 | sm-g925f s6 edge no network after unlock done after unlock no network but successfully patch by z3x Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 5.0.2 Product code: Phone version: G925FXXU1AOE3 PDA version: G925FXXU1AOE3 CSC version: G925FOLB1AODM CSC country code: PHILIPPINES CSC sales code: GLB HW version: Phone S/N: RF8G404T0PM Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... OK Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.24.2 |
02-20-2016, 18:29 | #15652 (permalink) |
Member: 2207555 Status: Offline Thanks Meter: 1,622 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. If you have one file firmware, then you must check 'Use one package file' option. 4. Check flashing options if needed (Repartition, EFS clear, Boot update). 5. Power on phone in download mode (turn off phone, hold Volume Down + Home + Power). 6. Connect phone to PC with USB cable, install drivers if needed. 7. Press 'Flash' button. Operation: Flash Selected model: GT-S6812 Software version: 24.3 File analysis... OK Total file size: 0x3820F7AD (898 Mb) Searching USB Flash Interface... detected COM28 Setup connection... OK Reading PIT from phone... OK Sending BcmBoot.img... OK Sending sboot.bin... OK Sending param.lfs... OK Sending dt-blob... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Sending BcmCP.img... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:03:26) Done with Samsung Tool PRO v.24.3 |
02-20-2016, 21:22 | #15653 (permalink) |
No Life Poster Join Date: Sep 2010 Location: Gsm-Djibouti
Member: 1406357 Status: Offline Sonork: 100.1654421 Thanks Meter: 45 | Operation: Unlock Selected model: SGH-M919 Selected port: COM139 SAMSUNG Mobile USB Serial Port Software version: 24.3 Reading phone info... Reading IMEI... OK IMEI: 35553xxxxxxxxxx Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.3 |
02-21-2016, 17:04 | #15654 (permalink) | |
Banned Join Date: Nov 2010 Location: :::LONDON:::
Member: 1442994 Status: Offline Thanks Meter: 899 | s5611 unlock done after flashing first unlock it by selecting flash mode and press 1 button on mobile if after unloking still it will ask code then flash it Quote:
02-21-2016, 21:10 | #15655 (permalink) |
Insane Poster Join Date: Jan 2016
Member: 2510231 Status: Offline Thanks Meter: 11 | Sm-n910p 5.1.1 ok1 successful domestic unlock Operation: Unlock SPRNT Selected model: SM-N910P Selected port: COM29 SAMSUNG Mobile USB Serial Port Software version: 24.3 Waiting ADB device... OK Reading phone info... Model: SM-N910P Android version: 5.1.1 Product code: Not Active Phone version: N910PVPS4COK1 PDA version: N910PVPS4COK1 CSC version: N910PSPT4COK1 CSC country code: USA CSC sales code: XAS HW version: N910P.05 Phone S/N: 00000000000 Modem board: MDM9625M RF cal date: 2015.04.14 IMEI: Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.24.3 |
02-22-2016, 11:49 | #15657 (permalink) |
Member: 2207555 Status: Offline Thanks Meter: 1,622 | S7562 Flash Done FLASH INSTRUCTIONS: 1. Choose correct flash file(s).Check flashing options if needed (Re-partition, EFS clear, Boot update) 2. Power on phone in download mode (turn off phone, hold Volume Down + Home(Central) Button + Power.) 3. Connect phone to PC, install drivers if needed. 4. Press 'Flash' button. Operation: Flash Selected model: GT-S7562 Software version: 24.3 File analysis... OK Total file size: 0x3972B688 (919 Mb) Searching USB Flash Interface... detected COM9 Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending oemsbl... OK Sending appsbl... OK Sending qcsbl.mbn... OK Sending qcsblhd_cfgdata.mbn... OK Sending oemsbl... OK Sending appsbl... OK Sending qcsbl.mbn... OK Sending qcsblhd_cfgdata.mbn... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending userdata.img.ext4... OK Sending persist.img.ext4... OK Sending fat.bin... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... OK Flashing done (time - 00:07:42) Done with Samsung Tool PRO v.24.3 |
02-22-2016, 12:16 | #15658 (permalink) |
Freak Poster Join Date: May 2013 Location: india punjab
Member: 1930279 Status: Offline Sonork: 100.1663273 Thanks Meter: 113 | Sm-j200y 5.1.1 unlock done. Selected model: SM-J200Y Software version: 24.3 Waiting ADB device... OK Reading phone info... Model: SM-J200Y Android version: 5.1.1 Product code: SM-J200YZKNTNX Phone version: J200YDOU1AOJ2 PDA version: J200YDOU1AOJ2 CSC version: J200YTNX1AOJ3 CSC country code: New Zealand CSC sales code: TNX HW version: MP 0.300 Phone S/N: R28H1019XJV Modem board: SHANNON308 RF cal date: 20151230 IMEI: Checking Super user right... true Initialization AT RIL... OK Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Writing nv data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.24.3 |
02-22-2016, 15:40 | #15660 (permalink) |
Member: 2207555 Status: Offline Thanks Meter: 1,622 | i9082 flash done FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. If you have one file firmware, then you must check 'Use one package file' option. 4. Check flashing options if needed (Repartition, EFS clear, Boot update). 5. Power on phone in download mode (turn off phone, hold Volume Down + Home + Power). 6. Connect phone to PC with USB cable, install drivers if needed. 7. Press 'Flash' button. Operation: Flash Selected model: GT-I9082 Software version: 24.3 File analysis... OK Total file size: 0x6477B3AB (1607 Mb) Searching USB Flash Interface... detected COM21 Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending BcmBoot.img... OK Sending sboot.bin... OK Sending param.lfs... OK Sending dt-blob... OK Sending vc-firmware.img... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Sending BcmCP.img... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:09:19) Done with Samsung Tool PRO v.24.3 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
