07-23-2016, 12:24 | #16516 (permalink) |
Freak Poster Join Date: Oct 2015
Member: 2478777 Status: Offline Sonork: 1669951 Thanks Meter: 103 | GT-E1150 Unlock Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Please wait for patching firmware... Already patched SW Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master IMEI: 00000000000000 Phone slave IMEI: 00000000000000 Phone SW: E1150JVKC1 Phone CSC: E1150OJVKC1 Phone BT ADDR: 0000-00-000000 Phone SN: RQHB779290 Deactivated MSL - TRUE Unlock - ok Elapsed time: 43 second, sw ver: 3.5.0040 |
07-23-2016, 17:47 | #16517 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | UNLOCK INSTRUCTIONS: Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock SPRNT Selected model: SM-G928P Software version: 26.0 Waiting ADB device... OK Reading phone info... Model: SM-G928P Android version: 5.1.1 Product code: Not Active Phone version: G928PVPU2AOJ6 PDA version: G928PVPU2AOJ6 CSC version: G928PSPT2AOJ6 CSC country code: USA CSC sales code: SPR HW version: G928P.03 Phone S/N: 00000000000 Modem board: MDM9635M RF cal date: 2015.07.21 IMEI: Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.0 Last edited by ghacks; 07-23-2016 at 17:54. |
07-23-2016, 18:00 | #16519 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Reset FRP/React/EE Selected model: SM-G930F Software version: 26.0 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM17 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G930F Android version: 6.0.1 Product code: SM-G930FZDALUX Phone version: G930FXXU1APB1 PDA version: G930FXXU1APAW CSC version: G930FLUX1APB1 CSC country code: Luxembourg CSC sales code: LUX HW version: PR 0.700 Phone S/N: R38H203D4YN Modem board: SHANNON335 RF cal date: 20160205 IMEI: Checking Super user right... true Erasing FRP... OK Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Restoring kernel... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.26.0 |
07-23-2016, 19:43 | #16520 (permalink) |
Member: 1933823 Status: Offline Thanks Meter: 1,273 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Reset FRP/React/EE Selected model: SM-G930F Software version: 26.0 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM17 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G930F Android version: 6.0.1 Product code: SM-G930FZDALUX Phone version: G930FXXU1APEQ PDA version: G930FXXS1APG3 CSC version: G930FLUX1APD1 CSC country code: Luxembourg CSC sales code: LUX HW version: PR 0.700 Phone S/N: R38HXXXXX Modem board: SHANNON335 RF cal date: 20160205 IMEI: Checking Super user right... true Erasing FRP... OK Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Restoring kernel... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.26.0 |
The Following User Says Thank You to souma_k For This Useful Post: |
07-24-2016, 06:11 | #16521 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Pakistan
Member: 682736 Status: Offline Thanks Meter: 457 | Operation: Reset FRP/React/EE Selected model: SM-J500G Selected port: Software version: 26.0 Searching Samsung USB Flash Interface... detected COM4 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.26.0 |
The Following User Says Thank You to adnon For This Useful Post: |
07-24-2016, 16:05 | #16522 (permalink) |
Freak Poster Join Date: Oct 2014 Location: algeria Age: 34
Member: 2266626 Status: Offline Thanks Meter: 40 | SM-J500FN UNLOCK DONE Operation: Unlock Selected model: SM-J500FN Selected port: COM62 SAMSUNG Mobile USB Serial Port Software version: 26.0 Reading phone info... Reading IMEI... OK IMEI: 35957xxxxxxxxx Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.0 |
07-24-2016, 17:30 | #16523 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung I9300 Imei Repaire Code: Operation: Repair Selected model: GT-I9300 Software version: 26.0 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: GT-I9300 Android version: 4.1.1 Product code: Not Active Phone version: I9300ZCDLJ4 PDA version: I9300XXDLJ2 CSC version: I9300XEFDLJ2 CSC country code: France CSC sales code: XEF HW version: REV__ Phone S/N: 00000000000 Modem board: RF cal date: none IMEI: 004999010640000 Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Writing nv data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.26.0 |
07-24-2016, 19:53 | #16524 (permalink) |
Freak Poster Join Date: Apr 2016
Member: 2554552 Status: Offline Thanks Meter: 21 | Operation: Unlock SPRNT Selected model: SM-N910P Selected port: COM18 SAMSUNG Mobile USB Serial Port Software version: 26.0 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-N910P Android version: 5.0.1 Product code: Not Active Phone version: N910PVPU1BOB7 PDA version: N910PVPU1BOB7 CSC version: N910PSPT1BOB7 CSC country code: USA CSC sales code: SPR HW version: N910P.05 Phone S/N: 00000000000 Modem board: MDM9625M RF cal date: 2014.11.18 IMEI: Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done AFTER UNLOCK DONE, YOU NEED TO DO THIS STEP. 2) Perform the following actions: 1. Dial *#0011# and in the service menu do the following. 2. Click "Menu" then "Key input" then input Q then press "Ok". 3. Click "Menu" then "Back". 4. Click "Menu" then "Key input" then input 0000 then click "Ok". 2. After these steps Hidden menu should open. In Hidden menu, depending on available options, try to do the following: I. Press UMTS Press DEBUG SCREEN Press PHONE CONTROL Press NETWORK CONTROL Set GCF to ON II. Press [2] UE SETTING & INFO Press [1] SETTINGS Press [4] GCF Set [1] GSM/(E)GPRS/WCDMA GCF to ON After these actions go to Settings -> Mobile Networks and Set Network Mode to Automatic, or GSM. |
07-25-2016, 14:08 | #16527 (permalink) |
Freak Poster Join Date: May 2016
Member: 2566911 Status: Offline Thanks Meter: 27 | Operation: Unlock SPRNT Selected model: SM-G900P Selected port: COM31 RIM Virtual Serial Port v2 Software version: 26.0 Waiting ADB device... OK Reading phone info... Model: SM-G900P Android version: 6.0.1 Product code: Not Active Phone version: G900PVPU3CPE1 PDA version: G900PVPU3CPE1 CSC version: G900PSPT3CPE1 CSC country code: USA CSC sales code: SPR HW version: G900P.04 Phone S/N: 00000000000 Modem board: MSM8974PRO RF cal date: 2014.11.21 IMEI: Checking Super user right... true Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done |
07-25-2016, 15:53 | #16528 (permalink) |
Freak Poster Join Date: Jan 2016 Location: UnderGround Age: 35
Member: 2509163 Status: Offline Thanks Meter: 77 | UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose USB (or 'DM/DUN over HSIC'). 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SC-03E Selected port: COM374 SAMSUNG Mobile USB Serial Port Software version: 26.1 Reading phone info... Reading IMEI... OK IMEI: 353986056383246 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.1 |
07-25-2016, 15:54 | #16529 (permalink) |
Member: 2509163 Status: Offline Thanks Meter: 77 | UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose USB (or 'DM/DUN over HSIC'). 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SC-06D Selected port: COM375 SAMSUNG Mobile USB Serial Port Software version: 26.1 Reading phone info... Reading IMEI... OK IMEI: 352670054947647 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.1 |
07-25-2016, 15:56 | #16530 (permalink) |
Member: 2509163 Status: Offline Thanks Meter: 77 | UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose USB (or 'DM/DUN over HSIC'). 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SC-06D Selected port: COM378 SAMSUNG Mobile USB Serial Port Software version: 26.1 Reading phone info... Reading IMEI... OK IMEI: 353595053156917 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.1 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
