10-26-2016, 21:19 | #17041 (permalink) |
No Life Poster Join Date: May 2013
Member: 1930570 Status: Offline Thanks Meter: 82 | Operation: Reset FRP/React/EE Selected model: SM-G925F Software version: 27.0 Searching Samsung USB Flash interface... COM226 detected Setup connection... ok Reading PIT from phone... ok Searching FRP lock... ok Erasing FRP... ok Searching Reactivation lock... ok Erasing Reactivation lock... ok Searching EE lock... ok Erasing EE lock... ok Reset done Done with Samsung Tool PRO v.27.0 S.G |
10-27-2016, 05:28 | #17042 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2638858 Status: Offline Thanks Meter: 0 | HI guys please help me out with the error 0 that I gets always by unlocking my G930W8 samsung galaxy S7 I downgrade the modem it says searching modem not found. I did so many ways to unlock my phone but I can't I hope you guys will help me out thank you |
10-27-2016, 05:36 | #17043 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Karachi, Pakistan Age: 28
Member: 1785307 Status: Offline Thanks Meter: 112 | Succfully Unlocked J105B (No Root) JUST USB & Z3X ;) UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-J105B Software version: 26.5 Searching Samsung modem... detected COM374 Reading phone info... OK Model: SM-J105B Version: J105BDXU0APE5/J700FOJV1AOH3/J105BDXU0APE3/J105BDXU0APE5 Product code: SM-J105BZDLXME Phone S/N: R21H817728X Imei: 356707072560691 Unique number: C8G01186A709673 Reading codes... OK Please wait, calculating codes... OK (time - 00:01:30) Freeze code: 84707424 NET lock: 14275264 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.26.5 |
10-27-2016, 10:27 | #17044 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | GT-I9500 unlock done Code: Operation: Unlock Selected model: GT-I9500 Software version: 27.0 Waiting ADB device... ok Reading phone info... Model: GT-I9500 Android version: 5.0.1 Product code: GT-I9500ZKAKSA Phone version: I9500XXUHOG2 PDA version: I9500XXUHOH6 CSC version: I9500OJVHOG3 CSC country code: KSA CSC sales code: KSA HW version: MP 0.800 Phone SN: R31F2004CRW Modem board: XMM6360 RF cal date: 2014.2.4 IMEI: Checking Super user right... true Reading NV data... ok Checking magic... ok Running zTool, please wait... OK Detected new type of security version 1 Calculating... ok Unlocking... ok Rebooting phone... ok Unlock done Done with Samsung Tool PRO v.27.0 |
10-27-2016, 10:54 | #17045 (permalink) |
No Life Poster Join Date: Jan 2007 Location: mumbai india
Member: 432679 Status: Offline Thanks Meter: 118 | a310f unlock done UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Pattern lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. Operation: Unlock Selected model: SM-A310F Software version: 26.9 Searching Samsung modem... detected COM310 Reading phone info... OK Model: SM-A310F AP version: A310FXXU2BPH3 CSC version: A310FOJV2BPH2 CP version: A310FXXU2BPG6 Product code: SM-A310FZDDKSA Phone SN: R58H42YRCJL Unique number: C0000A5B7AC0723 Reading IMEI... OK IMEI: 357337071474543 (SIGN: OK) IMEI 2: 357338071474541 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.9 |
10-27-2016, 16:38 | #17046 (permalink) |
Freak Poster Join Date: Aug 2014 Location: UK
Member: 2240742 Status: Offline Thanks Meter: 76 | N910F 6.0.1Marshmallow unlocking error(0) done by downgrading to 5.1.1 Operation: Unlock Selected model: SM-N910F Selected port: COM7 SAMSUNG Mobile USB Serial Port Software version: 27.0 Reading phone info... Reading IMEI... ok IMEI: 35722106588xxxx Unlocking... ok Reseting... ok Unlock done Done with Samsung Tool PRO v.27.0 |
10-27-2016, 16:38 | #17047 (permalink) |
10-28-2016, 14:05 | #17049 (permalink) |
No Life Poster Join Date: Mar 2012 Location: punjab
Member: 1732025 Status: Offline Sonork: 100.1615024 Thanks Meter: 329 | Samsung j320Fn Unlock Searching Samsung modem... detected COM174 Reading phone info... ok Model: SM-J320FN Version: J320FNXXU0APF3/J320FNITV0APD1/J320FNXXU0APFG/J320FNXXU0APF3 Product code: SM-J320FZWNITV Phone SN: R58H72J43EK IMEI: 352337084822022 Unique number: CQN002B99D24B63 Unlocking... ok Rebooting phone... ok Unlock done Done with Samsung Tool PRO v.27.0 |
10-28-2016, 17:03 | #17050 (permalink) | |
No Life Poster Join Date: May 2011 Location: ..:Inside UR Brain:.. Age: 34
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | Successfully Unlock SM-G925T 6.0.1 Successfully Unlock SM-G925T 6.0.1 With Z3X... Here Is Logs Quote:
10-28-2016, 23:23 | #17051 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1825650 Status: Offline Thanks Meter: 2 | Unlocking Samsung Galaxy S5 SM-G900W8 Welcome to Octoplus/Octopus Box Samsung software version 2.4.0 ----------------------------------------------------------------------------------- To connect SM-G900W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-G900W8 Reading info... Mode: Normal Firmware compiled date: Jan 28 2016 Firmware compiled time: 23:00:00 Firmware released date: Apr 9 2016 Firmware released time: 15:32:17 SW Version: MPSS.DI.2.0.1.c2-00201-M8974AAAAANRZM-1 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900W8 Firmware compiled date: Sat Apr 9 16:21:16 KST 2016 PDA version: G900W8VLU1DPD3 CSC version: G900W8OYA1DPD3 SW version: G900W8VLU1DPD3 Phone SN: RV8F50K7QPN Android version: 6.0.1 (MMB29M) Sales code: KDO Country: Canada HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Codename: kltevl Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-G900W8-28-10-2016_15-48-27 file Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.4.0 Software version. ----------------------------------------------------------------------------------- |
10-29-2016, 00:12 | #17052 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | UNLOCK DONE G925A Operation: Unlock Selected model: SM-G925A Software version: 27.0 Searching Samsung modem... detected COM63 Reading phone info... ok Model: SM-G925A AP version: G925AUCU3BOJ7 CSC version: G925AATT3BOJ7 CP version: G925AUCU3BOJ7 Product code: SM2G925AZKAATT Phone SN: R38G509YVJH Unique number: 04157DF481BAD531 Reading IMEI... ok IMEI: 3577410616XXX (SIGN: OK) Reading data from phone... ok Unlocking... ok Rebooting phone... ok Unlock done Done with Samsung Tool PRO v.27.0 S.G |
10-29-2016, 01:34 | #17053 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | FRP DONE Operation: Reset FRP/React/EE Selected model: SM-G530T Software version: 27.0 Searching Samsung USB Flash interface... COM67 detected Setup connection... ok Reading PIT from phone... ok Searching FRP lock... ok Erasing FRP... ok Searching Reactivation lock... not supported Searching EE lock... ok Erasing EE lock... ok Reset done Done with Samsung Tool PRO v.27.0 S.G ) |
10-29-2016, 02:16 | #17054 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | i9500 done UNLOCK UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: GT-I9500 Software version: 26.9 Waiting ADB device... OK Reading phone info... Model: GT-I9500 Android version: 5.0.1 Product code: GT-I9500ZKLJDI Phone version: I9500UBUHOK1 PDA version: I9500UBUHOK2 CSC version: I9500JDIHOK1 CSC country code: JAMAICA CSC sales code: JDI HW version: MP 0.800 Phone SN: RV1D74NL96D Modem board: XMM6360 RF cal date: 2013.7.22 IMEI: Checking Super user right... true Reading NV data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 1 Calculating... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.9 S.G |
10-29-2016, 02:55 | #17055 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | LG H811 DONE Unable to get comport information , check system LG 2-3G Tool v9.27 supported models: 1397 Mode: Emergency Model: H811 Elapsed: 5 secs. --> (v9.27) Phone mode is DOWNLOAD Start reset Google Account Lock... Model name: LG-H811 Software verion: H81120p Android verion: 6.0 IMEI: 3523920731XXXX Reset ... Reboot... Elapsed: 13 secs. --> (v9.27) S.G |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
