07-18-2017, 22:38 | #18722 (permalink) |
Insane Poster Join Date: Sep 2014 Location: UNITED STATES Age: 37
Member: 2266076 Status: Offline Sonork: Propery Thanks Meter: 19 | G928t frp done.. Qe1 Operation: Reset FRP Selected model: SM-G928T Selected port: COM3 USB Serial Port Software version: 28.8 Waiting ADB device... OK Reading phone info... Model: SM-G928T Android version: 7.0 Product code: SM2G928TZDETMB Phone version: G928TUVU4EQE1 PDA version: G928TUVU4EQE1 CSC version: G928TTMB4EQE1 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R58GB0QZ7KL Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-05-01 RF cal date: 20151109 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' |
The Following User Says Thank You to Repaircell For This Useful Post: |
07-18-2017, 23:07 | #18723 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2738130 Status: Offline Thanks Meter: 0 | how to start unlocking mobile devices? Hello,greetings from Mexico, I`m new in this theme of phone unlocking, and I don`t know much it`s, I would like your help on how to start, tips, what boxes to buy, before buying a box that I recommend as chemera tools etc. Thank you |
07-19-2017, 13:26 | #18728 (permalink) |
Junior Member Join Date: Jun 2012 Location: In the World
Member: 1777225 Status: Offline Thanks Meter: 4 | i repaired j710f imei after patch network ok..then i flash to stock firmware network goes into emergency calls only..again i have to patch certificate..is there any other permanent solution |
07-19-2017, 15:01 | #18729 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Cote d'Ivoire
Member: 841640 Status: Offline Thanks Meter: 86 | SAMSUNG GALAXY S8+ SUCCESSFULLY UNLOCKED VIA SERVER USING Z3x CREDITS UNLOCK INSTRUCTIONS: Unlocking with original MSL code: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G955U Selected port: COM4 Z3X BOX Serial Port Software version: 28.8.1 Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G955U Android version: 7.0 Product code: SM-G955UZKAATT Phone version: G955USQU1AQC9 PDA version: G955USQU1AQC9 CSC version: G955UOYN1AQC9 CSC country code: USA CSC sales code: ATT HW version: REV1.0 Phone SN: R38J40CMVRD Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-03-01 RF cal date: 2017.04.13 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM7 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 7028xxxx NET lock: 2097xxxx SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.8.1 |
07-19-2017, 15:20 | #18730 (permalink) |
No Life Poster Join Date: Jul 2006 Location: TÜRKİYE
Member: 311558 Status: Offline Thanks Meter: 476 | j710fq Waiting ADB device... OK Reading phone info... Model: SM-J710FQ Android version: 6.0.1 Product code: SM-J710FZWATUR Phone version: J710FQXXU1API1 PDA version: J710FQXXU1APL3 CSC version: J710FQTUR1APJ2 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.400 Phone SN: RF8J11CAZMT Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2016-10-01 RF cal date: 20170112 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.28.8.1 |
07-19-2017, 15:24 | #18731 (permalink) |
Member: 311558 Status: Offline Thanks Meter: 476 | j710fq repair done Operation: Repair Selected model: SM-J710FQ Software version: 28.8.1 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-J710FQ Android version: 6.0.1 Product code: SM-J710FZWATUR Phone version: J710FQXXU1API1 PDA version: J710FQXXU1APL3 CSC version: J710FQTUR1APJ2 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.400 Phone SN: RF8J11CAZMT Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2016-10-01 RF cal date: 20170112 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: C9 8E D9 7E 6D 6F 74 D1 0A DE 8A 14 8A 54 3D E3 Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.28.8.1 |
07-20-2017, 15:53 | #18735 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Samsung G532f Unlock done Operation: Unlock Selected model: SM-G532F Software version: 28.8.1 Waiting ADB device... OK Reading phone info... Model: SM-G532F Android version: 6.0.1 Product code: SM-G532FZKDMID Phone version: G532FXXU1AQB3 PDA version: G532FXWU1AQB5 CSC version: G532FOJV1AQB5 CSC country code: Iraq CSC sales code: MID HW version: MP 0.300 Phone SN: R58J64YK4QW Chip name: MT6737T Modem board: MT6737T Security patch: 2017-03-01 RF cal date: 20170622 IMEI: Checking Super user right... true Reading security... OK Unlocking... OK Writing security... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.28.8.1 Thanks z3x Team |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
