11-18-2010, 11:25 | #2146 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Code: Selected model: B5310 Selected com port: COM3 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM14 Phone OLD IMEI: 00000000000000 /0 Phone SW: B5310JPJD4/B5310OJPJE2 Search flash modem ... Search flash modem ... Search flash modem ... OK Search flash modem on:COM19 Send loader... OK Wait for boot ... Phone must be ON Search modem ... OK Search modem on:COM14 MSL DEACTIVATED - TRUE Write imei - ok Phone NEW IMEI: 35220604206917 /6 Search flash modem ... Search flash modem ... Search flash modem ... OK Search flash modem on:COM19 Send loader... OK Elapsed time: 95 second, sw ver: 3.4.0071 ------------------------------------------------------------------------------- WBR sahil2000ind |
11-18-2010, 12:21 | #2147 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Romania
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | S501i S501i succesfully read codes and direct unlock. Thank you Z3X Team. BR. Selected model: S501I Selected com port: COM29 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK SW: 501AGGA1 Langpack: Not found langpack ! IMEI: 351794011xxxxxx S/N: R1VP615312 HW-> MP 1.400 Phone password: 5462 Sum Flash: 1 Flash Prod ID: 0ec Flash Device ID: 22fd0000 Flash size: 33554432 Bytes Flash sectors: 519 sectors Bluetooth ID: 001c43-281667 Status OTP: OTP not present MSL DEACTIVATED - TRUE Locks is active [NETLOCK]: Use #0111*76062435# for deactivate this lock [SIMLOCK]: Use #0141*00000000# for deactivate this lock Read info - ok Elapsed time: 13 second, sw ver: 3.4.0071 ------------------------------------------------------------------------------- Selected model: S501I Selected com port: COM29 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: S501AGGA1 IMEI: 351794011xxxxxx MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 12 second, sw ver: 3.4.0071 |
11-18-2010, 13:11 | #2148 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | Selected model: S3500I Selected com port: COM7 Selected speed port: 460800 Decode *.s3 file - please wait segments 9 segment 1 20000000 100 byte segment 2 20300000 52113996 byte segment 3 2001E000 172 byte segment 4 20016000 5248 byte segment 5 20078000 1129752 byte segment 6 2000C000 21572 byte segment 7 20058000 56 byte segment 8 20058138 13724 byte segment 9 2003803C 36528 byte Phone must be OFF with battery Please, connect phone and press shortly power button Syncing phone... OK Sending loader 1... OK Syncing phone... OK Sending loader 2... bad ask - +ok+ bad ask - +ok+ OK Syncing phone... OK Syncing phone... OK Flash ID: 89000000B088 Syncing phone... OK Sending *.s3 file... OK Sending *.cts or *.csc file... Detected file - > 121 Format FFS - wait... OK Send content - wait... OK Elapsed time: 2732 second, sw ver: 3.4.0071 |
The Following 2 Users Say Thank You to joni_rajpura For This Useful Post: |
11-18-2010, 13:11 | #2149 (permalink) |
No Life Poster Join Date: Jul 2010 Location: North Africa
Member: 1350724 Status: Offline Thanks Meter: 188 | Selected model: E2210 Selected com port: COM6 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35******* Phone SW: E2210BBGIG1 Phone BT ADDR: 101D-C0-10F722 Phone SN: RQUZ816443 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 34 second, sw ver: 3.4.0071 |
11-19-2010, 08:10 | #2150 (permalink) |
Registered User Join Date: Jun 2010 Location: GSM POWERTEAM
Member: 1330543 Status: Offline Thanks Meter: 177 | E250i unlocked ok Selected model: E250I Selected com port: COM7 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35237503130400 Phone SW: E250iBAIC2 Phone BT ADDR: 0026-5D-740815 Phone SN: RPGS708771 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 14 second, sw ver: 3.4.0071 |
11-19-2010, 10:14 | #2151 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Code: Selected model: S3653 Selected com port: COM3 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM10 Phone IMEI: 35166004002283 /8 Phone S/N: RD1Z434283 Detecting UART port..... OK Repower phone - please wait Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM10 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 46 second, sw ver: 3.4.0071 ------------------------------------------------------------------------------- WBR sahil2000ind |
11-19-2010, 12:17 | #2153 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Birmingham U.K
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | SAMSUNG C 3050 UNLOCKED SUCCESSFULLY Selected model: C3050 Selected com port: COM19 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: C3050BVIH2 IMEI: 35869703XXXXXX1 MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 24 second, sw ver: 3.4.0066 ------------------------------------------------------------------------------- |
11-19-2010, 12:20 | #2154 (permalink) |
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | SAMSUNG E1080 UNLOCKED SUCCESSFULLY [PRESSED POWER BUTTON A BIG LONGER] Selected model: E1080 Selected com port: COM19 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 06 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 53 second, sw ver: 3.4.0066 |
11-19-2010, 12:31 | #2155 (permalink) |
No Life Poster Join Date: May 2008 Location: gsm city
Member: 767786 Status: Offline Thanks Meter: 320 | d900i imei Selected model: D900I Selected com port: COM31 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3541 Sending loader2... OK Flash ID: 00EC2206000100000034 Repair IMEI block Repair IMEI block Repair IMEI block Repair IMEI block Repair - ok Elapsed time: 134 second, sw ver: 3.4.0071 ------------------------------------------------------------------------------- |
11-19-2010, 15:15 | #2156 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Selected model: C3200 Selected com port: COM64 Selected speed port: 921600 Phone must be OFF Press * and connect phone by cable Connecting to Device... OK [Phone IMEI]:35317004047565 [Phone SN]:RSCZ957482 [Phone HW]:MP 0.400 Wait for decrypted code... OK Decrypted time: 20 sec [PCK]:#0141*00000000# [NCK]:#0111*00000000# [SCK]:#0121*00000000# [SPCK]:#0133*00000000# [MCK]:#0199*27223916# Read info - ok Elapsed time: 43 second, sw ver: 3.4.0071 ------------------------------------------------------------------------------- |
11-19-2010, 18:24 | #2157 (permalink) |
No Life Poster Join Date: Mar 2007 Location: TuNiSiA
Member: 462224 Status: Offline Sonork: 100.1586374 Thanks Meter: 103 | C6625 Code: Selected model: C6625 Selected com port: COM3 Selected speed port: 921600 Power On phone Press on phone keyboard code *#0228# Press Back and press 2 key Select UART-CP and connect phone on cable Phone detected [SOFTWARE]:C6625AFID2 [Unique number]:60030000497015 [IMEI]:359757021012606 [Serial number]:R3YS896817 Start Bruteforce Msl code detected: 022661 Unlock - ok Elapsed time: 464 second, sw ver: 3.4.0071 |
11-19-2010, 18:27 | #2158 (permalink) |
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | Selected model: S5230 Selected com port: COM5 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM11 Phone IMEI: 353458049xxxxxxx /9 Phone S/N: RQRZxxxxxxxxx Detecting UART port..... OK Repower phone - please wait Phone must be ON Search modem ... OK Search modem on:COM12 Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Elapsed time: 51 second, sw ver: 3.4.0071 ------------------------------------------------------------------------------- |
11-19-2010, 21:45 | #2159 (permalink) |
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | Model: GT-M7600 CountryCode: COMMON Factory SW: M7600XXIDA UniqueNumber: 80810000038159 MemoryPhone: K5R2G1GACC(M7600)S IMEI: 35282603xxxxx/8 Phone S/N: RUKS488418 Build: SBAM6281A-KLRZR-4.0.9640_3S Reading SysInfo... error (Cant read Security data) Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:58) Freeze code: 81848050 NET lock: #7465625*638*0000xxxxx# Sub lock: #7465625*782*0000xxxxx# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# |
11-20-2010, 00:09 | #2160 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Colombia Unlock
Member: 978651 Status: Offline Sonork: 1672421 Thanks Meter: 85 | Model: SGH-i900L CountryCode: COM Factory SW: i900URHJ3_HK2 UniqueNumber: 60140000003078 MemoryPhone: K5D1258DCA(I900) PDA/CSC version: i900LURHJ3_HK2/URHJ3 Phone version: i900LURHJ3_HK2 Phone HW: MP 0.300 IMEI: ‹3569910203592/ Phone S/N: R9XS166372 Build: M6281A-KLUZ-4.0.95604S Done with Samsung 3G tool ver 8.6 ----------------------------- Model: SGH-i900L CountryCode: COM Factory SW: i900URHJ3_HK2 UniqueNumber: 60140000003078 MemoryPhone: K5D1258DCA(I900) PDA/CSC version: i900LURHJ3_HK2/URHJ3 Phone version: i900LURHJ3_HK2 Phone HW: MP 0.300 IMEI: ‹3569910203592/ Phone S/N: R9XS166372 Build: M6281A-KLUZ-4.0.95604S Reading Security... OK Bypass MSL... OK Unlocking ... OK Done with Samsung 3G tool ver 8.6 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
