02-06-2011, 10:53 | #3106 (permalink) |
Banned Join Date: Sep 2003 Location: Cambodia
Member: 39069 Status: Offline Sonork: 100.1606677 Thanks Meter: 190 | Model: SGH-T479 CountryCode: TMB Factory SW: UVJH1 UniqueNumber: 55480001576587 MemoryPhone: K5R2G1GACC(T479)S IMEI: 35466504053913/4 Phone S/N: RR3ZA39527 Build: SBAM6246A-KPVZL-1.2.0035_6S Reading SysInfo... OK Calculating... error Reading SysInfo... OK Calculating codes... OK (time - 00:00:45) Freeze code: 64902505 NET lock: #7465625*638*20646393# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.3 |
02-06-2011, 15:50 | #3107 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 533827 Status: Offline Thanks Meter: 34 | 2pcs c3303k unlock by z3x & modify cable Selected model: C3303 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 88 second, sw ver: 3.4.0074 ------------------------------------------------------------------------------- Selected model: C3303 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 79 second, sw ver: 3.4.0074 ------------------------------------------------------------------------------- |
02-07-2011, 09:00 | #3110 (permalink) |
No Life Poster Join Date: Aug 2007 Location: GREAT INDIA
Member: 559113 Status: Offline Sonork: 100.1596477 Thanks Meter: 760 | E2121 IMEI repair done... Selected model: E2121B Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Repair IMEI block Repair IMEI block Repair - ok Elapsed time: 46 second, sw ver: 3.5.0003 |
02-07-2011, 09:25 | #3111 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Bulgaria,Assenovgrad Age: 46
Member: 591325 Status: Offline Thanks Meter: 151 | Selected model: E1210M Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35301403120091 Phone SW: E1210MXFIG3 Phone BT ADDR: 0000-00-000000 Phone SN: RPTZ252214 Deactivated MSL - TRUE [FREZEE]: 18597530 [NET Lock]: 37303750 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00000000 Read info - ok Elapsed time: 16 second, sw ver: 3.5.0003 ------------------------------------------------------------------------------- |
02-07-2011, 09:25 | #3112 (permalink) |
Member: 559113 Status: Offline Sonork: 100.1596477 Thanks Meter: 760 | Samsung A727 country unlock done . Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... unable to find phone COM or QUALCOMM interface required Searching Qualcomm USB interface... detected (COM18) Model: A727 IMEI: 35565501191449 SW: A727UCGD5 Unlock as MSL2 Direct... OK (time - 00:00:01) |
02-07-2011, 10:44 | #3114 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Mauritius Port Louis
Member: 762522 Status: Offline Thanks Meter: 156 | f480i unlock done Selected model: F480I Selected com port: COM10 Selected speed port: 921600 Please, connect phone and press on 3 sec power button Booting... OK Found bad block Remaped bad block 6 -> 1002 Remaped bad block 759 -> 1003 Unlock - ok Elapsed time: 40 second, sw ver: 3.5.0001 --------------------------------------------- |
02-07-2011, 11:30 | #3115 (permalink) |
Member: 762522 Status: Offline Thanks Meter: 156 | f480 unlock done Count supported models - 209 Searching Samsung USB interface... not found ----------------------------- Model: SGH-F480 CountryCode: H3G Factory SW: F480MNID1 UniqueNumber: 80060000181463 MemoryPhone: KBN00700AM(F480) IMEI: 35492603522058/9 Phone S/N: RU4S695580 Build: M6281A-KLRZ-4.0.9535 Done with Samsung 3G tool ver 8.4 ----------------------------- Model: SGH-F480 CountryCode: H3G Factory SW: F480MNID1 UniqueNumber: 80060000181463 MemoryPhone: KBN00700AM(F480) IMEI: 35492603522058/9 Phone S/N: RU4S695580 Build: M6281A-KLRZ-4.0 Reading SysInfo... OK Calculating... OK Searching Samsung USB interface... not found Unlocking... OK (time - 00:00:03) Done with Samsung 3G tool ver 8.4 |
02-07-2011, 11:45 | #3116 (permalink) |
Member: 559113 Status: Offline Sonork: 100.1596477 Thanks Meter: 760 | Samsung E2152 unlock done . Selected model: E2152 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 10 Sending loader2... OK Unlock block Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 110 second, sw ver: 3.5.0003 |
02-07-2011, 11:46 | #3117 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | Selected model: E250I Selected com port: COM2 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35803603115346 Phone SW: E250iBAIC2 Phone BT ADDR: A007-98-203826 Phone SN: RVISA29486 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok |
02-07-2011, 13:04 | #3118 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Romania
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | C3050 C3050 succesfullyunlocked. Thank you Z3X Team. BR. Selected model: C3050 Selected com port: COM29 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: C3050BUII1 IMEI: 3524770451xxxxx MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 19 second, sw ver: 3.5.0003 |
02-07-2011, 14:43 | #3119 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Alaska
Member: 672931 Status: Offline Thanks Meter: 28 | M8800 RSRC1... Erase error!. Code: Count supported models - 221 Searching Samsung USB Flash interface... detected (COM21) Sending OEMSbl... OK Sending QcSblHD_cfgdata... OK Sending MIBIB1... OK Sending MIBIB2... OK Sending QcSbl... OK Flashing boot files done (time - 00:00:23) Reseting phones... Sending AMSS... OK Sending RSRC1... Erase error! Done with Samsung 3G tool ver 9.3 Last edited by OnyGSM; 02-07-2011 at 14:49. Reason: .... |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
