09-07-2020, 07:13 | #1561 (permalink) |
Junior Member Join Date: Mar 2009
Member: 997034 Status: Offline Thanks Meter: 5 | Checking Login and Password... OK Ballance: 21 crd. You have 21 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J415FN Android version: 9 PDA version: J415FNXXU6BTG1 CSC version: J415FNOXM6BTG1 Phone version: J415FNXXU6BTF1 Product code: SM-J415FZKPSEK CSC country code: Ukraine CSC sales code: SEK Phone SN: R58KB1B2VFN IMEI: 352342101377901 HW version: REV0.4A RF cal date: 2018.11.07 Chip name: MSM8917 Modem board: MSM8917 Security patch: 2020-07-01 Boot Warranty bit: 0 SIM State: ABSENT Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Searching Samsung diag port... detected COM532 Reading phone info... OK Searching Samsung modem... detected COM533 Checking SIM status... error Please check Samsung USB drivers. Disable screenlock(PIN, password, fingerprint and etc...). Disable SIM PIN/PUK code. Done with Samsung Tool PRO v.41.2 |
09-08-2020, 19:20 | #1562 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | SM-T377A U3 unlock done no need nothing UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-T3777 Software version: 41.2 Searching Samsung modem... detected COM132 Reading phone info... Model: SM-T377A AP version: T377AUCU3BRD1 CSC version: T377AATT3BRD1 CP version: T377AUCU3ARD1 Product code: ATT Phone SN: R52J7003QAN IMEI: 359768081544453 Unique number: CAJ03E28053C864 Reading IMEI... OK IMEI: 359768081544453 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.41.2 |
09-09-2020, 20:47 | #1564 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Egypt Age: 37
Member: 710690 Status: Offline Thanks Meter: 907 | G532F Repair network successfully done! after EMMC changed network Emergency call only Code: Operation: Patch Certificate Selected model: SM-G532F Software version: 41.2 Waiting ADB device... OK Reading phone info... Model: SM-G532F Android version: 6.0.1 PDA version: G532FXWU1AQA6 CSC version: G532FOJV1AQA5 Phone version: G532FXXU1AQA4 Product code: SM-G532FZDDEGY CSC country code: Egypt CSC sales code: EGY Phone SN: R59J30HE5NH IMEI: 3576********** HW version: MP 0.300 RF cal date: 20170313 Chip name: MT6737T Modem board: MT6737T Security patch: 2017-01-01 Boot Warranty bit: 1 SIM State: ABSENT,READY Checking Super user right... true Searching server... OK Checking server answer... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Preparation of data... OK Writing data to phone... OK Rebooting phone... OK Done with Samsung Tool PRO v.41.2 |
09-11-2020, 11:04 | #1565 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | e1310b unlock select model connect using uart cable press unlock Connect phone and press power button... Phone detected Switching phone to TAT mode... OK Reading phone info... OK Phone version: E1310BBUID1 IMEI: 35423703125584 Phone SN: RP6S672082 Phone BT: 00:25:67:01:82:BD Reading security... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.41.2 |
09-12-2020, 20:32 | #1566 (permalink) |
Member: 216446 Status: Offline Thanks Meter: 220 | samsung e1200i unlock Reading phone info... OK IMEI: 353736068306705 Product code: GT-E1200ZKITCL Phone HW: MP 0.300 Phone SN: R21F603QEG Unlocking... OK Done with Samsung Tool PRO v.41.2 |
09-15-2020, 18:56 | #1568 (permalink) |
Member: 216446 Status: Offline Thanks Meter: 220 | samsung g960f s9 unlock UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button, select 'Unlock via server ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G960F Software version: 41.2 Checking Login and Password... OK Ballance: 15 crd. You have 15 credit(s) left. This operation takes 8 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G960F Android version: 10 PDA version: G960FXXS9DTD7 CSC version: G960FOTF9DTD7 Phone version: G960FXXS9DTD7 Product code: SM-G960FZKAO2U CSC country code: UNITED KINGDOM CSC sales code: O2U Phone SN: R58K24MA7WR IMEI: 352802096080521 HW version: MP 0.900 RF cal date: 20180301 Chip name: EXYNOS9810 Modem board: SHANNON360 Security patch: 2020-05-01 Boot Warranty bit: 0 SIM State: ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Samsung diag port... detected COM206 Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 27253072 NET lock: 49606174 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.41.2 |
09-18-2020, 05:58 | #1569 (permalink) |
No Life Poster Join Date: Oct 2011 Location: online
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 227 | Operation: Unlock Selected model: SM-N910T Selected port: COM85 SAMSUNG Mobile USB Serial Port Software version: 41.2 Reading phone info... Reading IMEI... OK IMEI: 354594061382010 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.41.2 |
09-18-2020, 06:08 | #1570 (permalink) |
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 227 | Operation: Flash Selected model: SM-N910T Software version: 41.2 File analysis... OK Total file size: 0x2B4390C0 (692 Mb) Searching USB Flash interface... COM118 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending sdi.mbn... OK Sending NON-HLOS.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending persist.img.ext4... OK Sending persdata.img.ext4... OK Sending modem.bin... OK Sending cache.img.ext4... OK Flashing done (time - 00:01:11) Done with Samsung Tool PRO v.41.2 |
09-18-2020, 06:11 | #1571 (permalink) |
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 227 | Operation: Unlock Selected model: SM-N910T Selected port: COM69 SAMSUNG Mobile USB Serial Port Software version: 41.2 Reading phone info... Reading IMEI... OK IMEI: 356095061205894 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.41.2 |
09-18-2020, 06:21 | #1572 (permalink) |
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 227 | Operation: Flash Selected model: SM-N910T Software version: 41.2 File analysis... OK Total file size: 0xE15EAE18 (3605 Mb) Searching USB Flash interface... COM118 detected Setup connection... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending sdi.mbn... OK Sending NON-HLOS.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending cache.img.ext4... OK Sending modem.bin... OK Flashing done (time - 00:05:23) Done with Samsung Tool PRO v.41.2 |
09-22-2020, 14:52 | #1574 (permalink) |
Major Poster Join Date: Jul 2019 Location: Dhaka,Bangladesh
Member: 2918257 Status: Offline Thanks Meter: 20 | J700t t-mobile network unlock done instant J700T T-MOBILE NETWORK UNLOCK DONE INSTANT...OLD IS GOLD Operation: Unlock Selected model: SM-J700T Software version: 41.2 Waiting ADB device... OK Reading phone info... Model: SM-J700T Android version: 6.0.1 PDA version: J700TUVU3AQC3 CSC version: J700TTMB3AQC3 Phone version: J700TUVU3AQC3 Product code: SM2J700TZWATMB CSC country code: USA CSC sales code: TMB Phone SN: R58H84PXXXX IMEI: 357218076XXXXXX HW version: REV0.5 RF cal date: 20160827 Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-03-01 Boot Warranty bit: 1 SIM State: NETWORK_LOCKED Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... OK Reading data... OK HWID: A5 AE EC 51 2F 44 68 86 17 BB 94 A2 71 3D 2B 99 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.41.2 |
09-22-2020, 15:42 | #1575 (permalink) |
Freak Poster Join Date: Dec 2018 Location: Harare Zimbabwe Age: 33
Member: 2883035 Status: Offline Thanks Meter: 84 | UNLOCK INSTRUCTIONS: To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-J415FN Selected port: COM92 SAMSUNG Mobile USB Serial Port Software version: 41.2 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J415FN Android version: 9 PDA version: J415FNXXS6BTE1 CSC version: J415FNOBE6BTB3 Phone version: J415FNXXS6BTE1 Product code: SM-J415FZKPEVR CSC country code: UK CSC sales code: EVR Phone SN: R58M1192HGD IMEI: 35XXXXXXXXXXX HW version: REV0.4A RF cal date: 2019.01.08 Chip name: MSM8917 Modem board: MSM8917 Security patch: 2020-05-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Searching Samsung diag port... detected COM92 Reading phone info... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Executing... OK Searching Ramdump interface... COM10 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 90839296 NET lock: 49462790 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.41.2 thanks z3x team |
