Post here successfully job with Z3X-BOX Samsung (2018-2022) SGH-X460 UNLOCK DONE BY Z3X http://www.4shared.com/download/8ez4....jpg?lgfp=1000 Connect PHONE BY E700 CABLE CLICK READ INFO BR, GSM-SHAFAIT :):):) |
N920T repair succeed done Operation: Write CERT Selected model: SM-N920T Software version: 22.8 Waiting ADB device... OK Reading phone info... Model: SM-N920T Android version: 5.1.1 Product code: SM-N920TZKATMB Phone version: N920TUVU1BOH4 PDA version: N920TUVU1BOH4 CSC version: N920TTMB1BOH4 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone S/N: RF8G724HKCL Modem board: SHANNON333 RF cal date: 20150727 IMEI: Checking Super user right... true Checking certificate file... OK KEY ID: 0448 Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Writing nv data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.22.8 |
Where is the cert file ? |
SM-J100Y unlock DONE UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 00000000 Operation: Unlock Selected model: SM-J100Y Software version: 24.1 Waiting ADB device... OK Reading phone info... Model: SM-J100Y Android version: 4.4.4 Product code: SM-J100YZWAOPP Phone version: J100YDXU0AOC1 PDA version: J100YDXU0AOC1 CSC version: J100YOPP0AOC1 CSC country code: Australia CSC sales code: OPP HW version: MP 0.100 Phone S/N: R28GA3EKQAL Modem board: RF cal date: 20151029 IMEI: 358926061661041 Checking Super user right... true Reading nv data... OK Analysing SEC file... OK Initialization AT RIL... OK Bypass MSL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.24.1 thankz Z3X Team |
SM-N910T 5.1.1 write cert done.. Checking certificate file... OK KEY ID:**** Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-N910T Android version: 5.1.1 Product code: SM-N910TZWATMB Phone version: N910TUVU2DOK2 PDA version: N910TUVU2DOK2 CSC version: N910TTMB2DOK2 CSC country code: USA CSC sales code: TMB HW version: REV1.1 Phone S/N:******** Modem board: ******* RF cal date: 2015.10.05 IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: ***** Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.24.2 :D:D:D |
G928F Unlock done Z3X G928F S6 edge plus 5.1.1 UNLOCK DONE With Z3x PROCEDURE 1. ENABLE OEM 2. DOWNLOAD Root File https://www.4shared.com/file/NY3tPIy...KLSI-ODIN.html 3. Put Phone to DOWNLOAD MODE 4. Open Odin3_v3.10.6 and select root file After root unlock via Z3x https://dc780.4shared.com/img/WT-cPr...8/IMG_2949__1_ https://www.4shared.com/account/home.jsp#dir=UzWtJeah |
unlock is ok after root 5.0.1 thank you men |
does any one tested it? |
Samsung Galaxy S SC-02B IMEI Repair Done Samsung Galaxy S SC-02B IMEI Repair Done With z3x In my Set No IMEI After update but with the help of z3x Box All Done 1. Flash with z3x this firmwre SC02BOMKL4_SC02BDCMKL4 (Download From support Area) 2. After Flash IMEI ok automatic. But not Registered on Network 3 Now write Modem file "Modem_SC02BOMJJ1_patched.zip" file (download From Support Area) And All Done :) Thanks z3x Team |
J710gn unlock done J710GN UNLOCK DONE FINALLY THANX TO Z3X NLOCK INSTRUCTIONS: READ CODES: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read codes' to read security codes. DIRECT UNLOCK: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button. Operation: Unlock Selected model: SM-J710GN Software version: 26.2 Searching Samsung modem... detected COM23 Reading phone info... OK Model: SM-J710GN AP Version: J710GNDXU1APG1 CSC Version: J710GNOLB1APG1 CP Version: J710GNDXU1APG1 Product code: SM-J710GZDUXME Phone S/N: RF Imei: 35 Unique number: C00 Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.2 |
Samsung G928F unlock done 100% Searching Samsung modem... detected COM508 Reading phone info... OK Model: SM-G928F AP Version: G928FXXS2BPG1 CSC Version: G928FOXX2BPF1 CP Version: G928FXXU2BPE6 Product code: SM-G928FZDATPH Phone S/N: RF8GB2JXWXH Imei: 354750074186851 Unique number: 0915F9D9E2D72704 Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.3.1 A phone must be root! You can root with cf auto root |
samsung g828f unlock Yes but unlock without root : Directly unlock with read codes not work Searching Samsung modem... detected COM89 Reading phone info... OK Model: SM-G928F AP Version: G928FXXS2BPG2 CSC Version: G928FVFG2BPB6 CP Version: G928FXXU2BPF1 Product code: SM-G928FZDACNX Phone S/N: R58G80F4X1R Imei: xxxxxxxxxxxxxx Unique number: xxxxxxxxxxxxx Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.4 :) |
Samsung wp sgh-i187 phone unlock successfull UNLOCK INSTRUCTIONS: USB cable: 1. Phone must be powered on. 2. Type ##634#, then type *#7284# and choose 'QC RmNetComposite' option. 3. Apply confirmation and wait till phone reboot. 4. Connect USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: SGH-I187 Selected port: COM78 USB Serial Port Software version: 27.7 Reading phone info... Reading IMEI... Ok IMEI: 35628SKYULOCK Unlocking... Ok Reseting... Ok Unlock done Done with Samsung Tool PRO v.27.7 |
