04-17-2018, 18:22 | #46 (permalink) |
No Life Poster Join Date: May 2011 Location: tropical island
Member: 1568769 Status: Offline Sonork: 161.1167 Thanks Meter: 208 | g570m unlock done Selected model: SM-G570M Software version: 31.3 Waiting ADB device... OK Reading phone info... Model: SM-G570M Android version: 6.0.1 PDA version: G570MUBU1AQH2 CSC version: G570MUWM1AQJ1 Phone version: G570MUBU1API9 Product code: SM-G570MZKACOL CSC country code: COLOMBIA CSC sales code: COL Phone SN: R28J225VZSA IMEI: 353420085929993 HW version: Rev0.0 RF cal date: 20170214 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-08-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... error Security damaged (4 13) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Modem board: SHANNON305 HWID: 36 A0 D5 01 67 02 15 75 BE 3E E4 14 0A 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.31.3 |
The Following 2 Users Say Thank You to headszone1 For This Useful Post: |
05-16-2018, 19:07 | #47 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | Sm-g903w unlock done by z3x +modem unlock UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes DIAG Selected model: SM-G903W Software version: 31.5 Checking hash file... OK Searching Samsung modem... detected COM109 Reading phone info... Model: SM-G903W AP version: G903WVLU1CQI1 CSC version: G903WOYA1CQI1 CP version: G903WVLU1APJ1 Product code: VTR Phone SN: RF8H629M7TA IMEI: 3547XXXXXXXXXXXXXXX Unique number: C00007AE937D323 Searching Samsung diag port... detected COM110 Reading phone info... OK CP version: G903WVLU1APJ1 CP build: Oct 20 2016 15:31:45 Reading data from phone... OK Reading NV data... OK Modem board: SHANNON310 Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:09) Freeze code: 60919240 NET lock: 86462706 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.31.5 https://mega.nz/#!QHIlnJQC!pwW-sadYR...CZtzqg0xjy9nzw PJ1 https://mega.nz/#!pXojmRgJ!4OUgFReLS...niMDFcG-I10tUQ PF1 |
05-27-2018, 10:42 | #48 (permalink) |
Junior Member Join Date: Nov 2015 Location: Iran JHR
Member: 2487583 Status: Offline Thanks Meter: 6 | SM-J700F Patch Certificate ok Operation: Patch Certificate Selected model: SM-J700F Software version: 32.4 Waiting ADB device... OK Reading phone info... Model: SM-J700F Android version: 6.0.1 PDA version: J700FXXU2BPG3 CSC version: J700FOJV2BPG1 Phone version: J700FXXU2BPG1 Product code: SM-J700FZWDKSA CSC country code: KSA CSC sales code: KSA Phone SN: R28H5xxxxxx IMEI: 352842xxxxxxxxx HW version: MP 0.700 RF cal date: 20150722 Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2016-07-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.32.4 |
06-05-2018, 07:46 | #50 (permalink) |
Freak Poster Join Date: Aug 2015 Location: Peace Age: 27
Member: 2441366 Status: Offline Sonork: Telegram: @FahadBoss10 Thanks Meter: 243 | SM-J120AZ 6.0.1 Binary 5 Unlock [Done] J120AZ 6.0.1 Binary 5 Successfully Unlocked by Z3X 1. Read Info: 2. Flash ENG_Modem file by Odin in CP section. 3. Read Codes DIAG: 4. Enter NET lock code. That's it Br, Fahad Ahmad |
The Following 8 Users Say Thank You to fahadboss For This Useful Post: |
06-21-2018, 01:53 | #51 (permalink) |
Freak Poster Join Date: Jun 2017
Member: 2730595 Status: Offline Thanks Meter: 13 | j727 t1 unlocking done UNLOCK INSTRUCTIONS: Warning! Knox warranty must be active (0x00)! 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Type *#0808# and select 'DM + MODEM + ADB' (or 'DM + ACM + ADB'). 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select device in ADB settings. 6. Press 'Unlock TMB via Server' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Unlock Selected model: SM-J727T1 Software version: 32.7 Checking Login and Password... OK Ballance: 130 crd. You have 130 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J727T1 Android version: 7.0 PDA version: J727T1UVS3ARE1 CSC version: J727T1TMK3ARE1 Phone version: J727TUVU3ARA1 Product code: SM2J727TZKETMK CSC country code: USA CSC sales code: TMK Phone SN: R28K30QABPN IMEI: 354254093027501 HW version: REV0.7 RF cal date: 20180306 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-05-01 Boot Warranty bit: 0 Searching Samsung diag port... detected COM184 Reading phone info... OK CP version: J727TUVU3ARA1 CP build: Jan 24 2018 13:02:34 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.32.7 |
The Following User Says Thank You to dineshkannur123 For This Useful Post: |
06-21-2018, 21:55 | #53 (permalink) |
Member: 2730595 Status: Offline Thanks Meter: 13 | brother ,first whn i try for unlocking z3x box saying reading phone data is failed afer that i have done modem downgrade PDA version: J727T1UVS3ARE1 CSC version: J727T1TMK3ARE1 Phone version: J727TUVU3ARA1 Security patch: 2018-05-01 after downgrade modem Reading phone info... OK CP version: J727TUVU3ARA1 CP build: Jan 24 2018 13:02:34 Reading data from phone... OK then ucan unlock via z3x server if u getting reading pone data error,,, same way u can do ( downgrading the modem) Thanks bro.. |
06-21-2018, 21:59 | #54 (permalink) |
Member: 2730595 Status: Offline Thanks Meter: 13 | brother ,first whn i try for unlocking z3x box saying reading phone data is failed afer that i have done modem downgrade PDA version: J727T1UVS3ARE1 CSC version: J727T1TMK3ARE1 Phone version: J727TUVU3ARA1 Security patch: 2018-05-01 after downgrade modem Reading phone info... OK CP version: J727TUVU3ARA1 CP build: Jan 24 2018 13:02:34 Reading data from phone... OK then ucan unlock via z3x server if u getting reading pone data error,,, same way u can do ( downgrading the modem) Thanks bro.. Report Post |
06-23-2018, 11:53 | #55 (permalink) |
Freak Poster Join Date: Mar 2018 Location: Kharian Age: 43
Member: 2826140 Status: Offline Sonork: 1644958 Thanks Meter: 103 | G920P Unlock done Operation: Unlock Selected model: SM-G920P Software version: 32.7 Waiting ADB device... OK Reading phone info... Model: SM-G920P Android version: 7.0 PDA version: G920PVPS4DRA2 CSC version: G920PSPT4DRA2 Phone version: G920PVPS4DRA2 CSC country code: USA CSC sales code: SPR IMEI: 99 HW version: G920P.02 RF cal date: 2016.01.22 Chip name: EXYNOS7420 Modem board: MDM9635M Security patch: 2018-01-01 Boot Warranty bit: 1 Writing AT RIL... OK Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.32.7 |
08-13-2018, 13:32 | #56 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2017 Location: USA, China, BD Age: 27
Member: 2780773 Status: Offline Sonork: Not useing Thanks Meter: 152 | SAMSUNG SM-J320F Unlock [Done] Operation: Read Codes Selected model: SM-J320F Software version: 33.2 Searching Samsung modem... detected COM57 Reading phone info... Model: SM-J320F AP version: J320FXXU0AQG2 CSC version: J320FDBT0AQG1 CP version: J320FXXU0AQE2 Product code: SM-J320FZKDDBT Phone SN: RV8JA1CFXXX IMEI: 353751090547XXX IMEI2: 353752090547XXX Unique number: CQN00CA71D46884 Reading codes... OK Please wait, calculating codes... OK (time - 00:01:15) Freeze code: 31727926 NET lock: 35081684 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.33.2 |
10-02-2018, 08:40 | #58 (permalink) |
Freak Poster Join Date: Nov 2011
Member: 1689739 Status: Offline Sonork: 100.1608775 Thanks Meter: 164 | SAMSUNG N920P unlock done Operation: Unlock Selected model: SM-N920P Software version: 33.8 Waiting ADB device... OK Reading phone info... Model: SM-N920P Android version: 7.0 PDA version: N920PVPS3DRC1 CSC version: N920PSPT3DRC1 Phone version: Product code: CSC country code: USA CSC sales code: SPR Phone SN: 00000000000 IMEI: HW version: RF cal date: Chip name: EXYNOS7420 Modem board: Security patch: 2018-03-01 Boot Warranty bit: 0 Writing AT RIL... OK Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.33.8 |
