Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #121 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: Sindh Pakistan
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,341 | ![]() Selected model: SM-J120A Software version: 34.0 Searching Samsung USB Flash interface... COM41 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.34.0 |
![]() | #122 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2006 Location: pakistan
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 392 | SM-T280 frp done with download mode UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Unlock' button for direct unlock. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP/React/EE Selected model: SM-J500FN Software version: 34.0 Searching Samsung USB Flash interface... COM196 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.34.0 |
![]() | #125 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 707 | SM-G955u u5 unlock done UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Unlocking using Server: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G955U Selected port: COM2581 SAMSUNG Mobile USB Serial Port Software version: 34.3 Checking Login and Password... OK Ballance: 15 crd. You have 15 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G955U Android version: 8.0.0 PDA version: G955USQS5CRH1 CSC version: G955UOYN5CRH1 Phone version: G955USQS5CRH1 Product code: SM-G955UZKATMB CSC country code: USA CSC sales code: TMB Phone SN: R28J91XKH9Z IMEI: 35598********* HW version: REV1.0 RF cal date: 2017.09.15 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-08-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Searching Samsung diag port... detected COM2581 Reading phone info... OK Reading data from phone... error (0), skip Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM5 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.34.3 |
![]() | #126 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 706 | Operation: Read Codes via Server Selected model: SM-G960F Software version: 34.3 Checking Login and Password... OK Ballance: 300 crd. You have 300 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G960F Android version: 8.0.0 PDA version: G960FXXU2BRI3 CSC version: G960FOXM2BRHA Phone version: G960FXXU2BRHA Product code: SM-G960FZBADBT CSC country code: Germany CSC sales code: DBT Phone SN: R5xxxxxxxx IMEI: 35xxxxxxxxxxxx HW version: MP 0.900 RF cal date: 20180228 Chip name: EXYNOS9810 Modem board: SHANNON360 Security patch: 2018-09-01 Boot Warranty bit: 0 SIM State: ABSENT Searching server... OK Checking server answer... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 24759707 NET lock: 27168193 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.3 |
![]() | #127 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2012
Member: 1713974 Status: Offline Thanks Meter: 34 | g965f unlock Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G965F Android version: 8.0.0 PDA version: G965FXXS2BRI1 CSC version: G965FOXM2BRG8 Phone version: G965FXXS2BRH8 Product code: SM-G965FZKDDBT CSC country code: Germany CSC sales code: DBT Phone SN: RF8KA16ZL5B IMEI: 35********** HW version: MP 0.900 RF cal date: 20181009 Chip name: EXYNOS9810 Modem board: SHANNON360 Security patch: 2018-09-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Searching server... OK Checking server answer... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 38538631 NET lock: 31582935 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.3 |
![]() | #129 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Online Sonork: 100.1684818 Thanks Meter: 1,302 | ![]() Operation: Unlock Selected model: SM-G925I Software version: 34.3 Searching Samsung modem... detected COM119 Reading phone info... Model: SM-G925I AP version: G925IDVS3EPC1 CSC version: G925IKSA3EPB4 CP version: G925IDVU3EPB2 Product code: SM-G920FZKAXEF Phone SN: RF8G42DQLGW IMEI: 359030061927707 Unique number: 04157DF4ACEE2A07 Reading IMEI... OK IMEI: 359030061927707 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.34.3 |
![]() | #131 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2017
Member: 2766801 Status: Offline Thanks Meter: 182 | sm-n950u TMB unlock done UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will appear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Unlocking using Server: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-N950U Software version: 34.3 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-N950U Android version: 8.0.0 PDA version: N950USQS5CRJ3 CSC version: N950UOYN5CRJ3 Phone version: N950USQS5CRJ3 Product code: SM2N950UZVATMB CSC country code: USA CSC sales code: TMB Phone SN: R28JB09HXBF IMEI: 351xxxxxxxxxxxxx HW version: REV1.0 RF cal date: 2017.11.03 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-11-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Searching Samsung diag port... detected COM11 Reading phone info... OK Reading data from phone... error (0), skip Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM17 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.34.3 |
![]() | #132 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2011 Location: dominican republic Age: 43
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 536 | Operation: Unlock Selected model: SM-J727T1 Software version: 34.3 Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J727T1 Android version: 7.0 PDA version: J727T1UVU3ARF1 CSC version: J727T1TMK3ARF1 Phone version: J727T1UVU3ARF1 Product code: SM-J727TZKETMK CSC country code: USA CSC sales code: TMK Phone SN: R28K40SSXCD IMEI: 35425xxxxxxxxxx HW version: REV0.7 RF cal date: 20180407 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-06-01 Boot Warranty bit: 0 SIM State: READY Searching server... OK Checking server answer... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.34.3 |
![]() | #133 (permalink) |
Junior Member ![]() ![]() Join Date: Oct 2016
Member: 2643497 Status: Offline Thanks Meter: 6 | j3 pro j330f/ds unlock done Operation: Read Codes via Server [ 30/11/2018 13:10:57 ] Selected model: SM-J330F [ 30/11/2018 13:10:57 ] Software version: 34.3 [ 30/11/2018 13:10:57 ] [ 30/11/2018 13:10:58 ] Checking Login and Password... OK [ 30/11/2018 13:12:33 ] Ballance: 20 crd. [ 30/11/2018 13:12:37 ] You have 20 credit(s) left. This operation takes 5 credits.Continue? Yes [ 30/11/2018 13:12:38 ] Searching Samsung modem... detected COM7 [ 30/11/2018 13:12:41 ] Reading phone info... [ 30/11/2018 13:12:43 ] Model: SM-J330F [ 30/11/2018 13:12:43 ] AP version: J330FXWU3ARD1 [ 30/11/2018 13:12:43 ] CSC version: J330FOJV3ARD1 [ 30/11/2018 13:12:44 ] CP version: J330FXXU3ARD1 [ 30/11/2018 13:12:44 ] Product code: XSG [ 30/11/2018 13:12:44 ] Phone SN: R58KA4TRRVT [ 30/11/2018 13:12:45 ] IMEI: 351821107765293 [ 30/11/2018 13:12:45 ] IMEI2: 351822107765291 [ 30/11/2018 13:12:45 ] Unique number: CQE0034B5077B85 [ 30/11/2018 13:12:48 ] Searching Samsung diag port... detected COM21 [ 30/11/2018 13:12:49 ] Reading phone info... OK [ 30/11/2018 13:12:50 ] CP version: J330FXXU3ARD1 [ 30/11/2018 13:12:50 ] CP build: Apr 17 2018 16:10:59 [ 30/11/2018 13:12:51 ] Reading data from phone... error (1) [ 30/11/2018 13:13:03 ] Searching server... OK [ 30/11/2018 13:13:03 ] Checking available files... OK [ 30/11/2018 13:13:04 ] Available CP file for downgrade, try download and flash? Continue? Yes [ 30/11/2018 13:13:22 ] Downloading file... OK [ 30/11/2018 13:16:02 ] Checking local file... OK [ 30/11/2018 13:16:02 ] Switching to flash mode... OK [ 30/11/2018 13:16:04 ] Searching USB Flash interface... COM5 detected [ 30/11/2018 13:16:13 ] Setup connection... OK [ 30/11/2018 13:16:13 ] Reading data from phone... OK [ 30/11/2018 13:16:14 ] Sending data to phone... OK [ 30/11/2018 13:16:18 ] Searching Samsung modem... detected COM7 [ 30/11/2018 13:16:56 ] Reading phone info... [ 30/11/2018 13:16:58 ] Model: SM-J330F [ 30/11/2018 13:16:58 ] AP version: J330FXWU3ARD1 [ 30/11/2018 13:16:58 ] CSC version: J330FOJV3ARD1 [ 30/11/2018 13:16:59 ] CP version: J330FXXU3ARA1 [ 30/11/2018 13:16:59 ] Product code: XSG [ 30/11/2018 13:16:59 ] Phone SN: R58KA4TRRVT [ 30/11/2018 13:17:00 ] IMEI: xxxxxxxxxxxxxxxxxx [ 30/11/2018 13:17:00 ] IMEI2: xxxxxxxxxxxxxxxxx [ 30/11/2018 13:17:00 ] Unique number: CQE0034B5077B85 [ 30/11/2018 13:17:03 ] Searching Samsung diag port... detected COM21 [ 30/11/2018 13:17:04 ] Reading phone info... OK [ 30/11/2018 13:17:05 ] CP version: J330FXXU3ARA1 [ 30/11/2018 13:17:05 ] CP build: Jan 5 2018 14:38:19 [ 30/11/2018 13:17:06 ] Reading data from phone... OK [ 30/11/2018 13:17:49 ] Calculating... OK [ 30/11/2018 13:17:57 ] Searching server... OK [ 30/11/2018 13:18:00 ] Waiting for server answer... OK [ 30/11/2018 13:18:43 ] Freeze code: 27258480 [ 30/11/2018 13:18:44 ] NET lock: 02024847 [ 30/11/2018 13:18:44 ] SUB lock: 00000000 [ 30/11/2018 13:18:44 ] SP lock: 00000000 [ 30/11/2018 13:18:44 ] CP lock: 00000000 [ 30/11/2018 13:18:45 ] SIM lock: 00000000 [ 30/11/2018 13:18:45 ] For check lock status: *#7465625# ![]() |
![]() | #135 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2011 Location: online
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 205 | File analysis... OK Total file size: 0x1DEB04EF7 (7659 Mb) Searching USB Flash interface... COM44 detected Setup connection... OK Getting device info... OK Reading PIT from phone... OK Sending abl.elf.lz4... OK Sending bksecapp.mbn.lz4... OK Sending xbl.elf.lz4... OK Sending tz.mbn.lz4... OK Sending hyp.mbn.lz4... OK Sending devcfg.mbn.lz4... OK Sending pmic.elf.lz4... OK Sending rpm.mbn.lz4... OK Sending cmnlib.mbn.lz4... OK Sending cmnlib64.mbn.lz4... OK Sending keymaster.mbn.lz4... OK Sending apdp.mbn.lz4... OK Sending msadp.mbn.lz4... OK Sending sec.dat.lz4... OK Sending NON-HLOS.bin.lz4... OK Sending storsec.mbn.lz4... OK Sending boot.img.lz4... OK Sending recovery.img.lz4... OK Sending system.img.ext4.lz4... OK Sending persist.img.ext4.lz4... OK Sending modem.bin.lz4... OK Sending adspso.bin.lz4... OK Sending cache.img.ext4.lz4... OK Sending userdata.img.ext4.lz4... OK Sending cache.img.ext4.lz4... OK Flashing done (time - 00:09:48) Done with Samsung Tool PRO v.34.3 |
