![]() | #16 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2015 Location: Pakistan Age: 25
Member: 2488001 Status: Offline Sonork: 100.1669288 Thanks Meter: 296 | Samsung G925f DRk Repair Done With great Z3x Box Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Repair DRK Selected model: SM-G925F Software version: 28.2 Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM4 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Sending data to phone... Ok Waiting ADB device... Ok Reading phone info... Recovery build version: 6.0.1 Boot version: G925FXXU5DQD3 Platform: exynos7420 Boot serial: 01157df18a9b6119 Product board: zerolte Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Checking DRK status... NG! Writing DRK... Ok Checking DRK status... Repairing DMVT key... Ok Rebooting phone... Ok Repair DRK done Done with Samsung Tool PRO v.28.2 |
The Following 5 Users Say Thank You to Salman725626 For This Useful Post: |
![]() | #17 (permalink) |
Junior Member ![]() Join Date: Sep 2008 Location: DHAKA BANGLADESH
Member: 853304 Status: Offline Sonork: 100:1602230 Thanks Meter: 7 | ![]() Operation: Unlock Selected model: SM-G570Y Software version: 28.1 Waiting ADB device... Ok Reading phone info... Model: SM-G570Y Android version: 6.0.1 Product code: SM-G570YWDDXME Phone version: G570YDXU1APK2 PDA version: G570YDXU1APL4 CSC version: G570YOLB1APL2 CSC country code: MALAYSIA CSC sales code: XME HW version: MP 0.500 Phone SN: R58J56MDXBA Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2016-12-01 RF cal date: 20170529 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... error Security damaged (4 23) Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Ok Modem board: SHANNON305 HWID: 59 CA 97 6F 95 15 C6 84 E8 8D F8 6B 0A 00 00 00 Calculating... Ok Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.1 |
The Following 2 Users Say Thank You to nayan sarder For This Useful Post: |
![]() | #18 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2015 Location: searching Age: 32
Member: 2424314 Status: Offline Thanks Meter: 731 ![]() | G9005 unlocking done SAMSUNG S5 G900F COUNTRY CODE UNLOCKING DONE THANKS SOMUCH Z3X TEAM ![]() |
The Following 2 Users Say Thank You to farooquepm For This Useful Post: |
![]() | #19 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2012 Location: india
Member: 1860703 Status: Offline Sonork: 100.1641707:shahid Thanks Meter: 35 ![]() | g920t version naugat 7.0 unlock done Operation: Unlock Selected model: SM-G920T Software version: 28.6 Waiting ADB device... OK Reading phone info... Model: SM-G920T Android version: 7.0 Product code: SM2G920TZWATMB Phone version: G920TUVU5FQE1 PDA version: G920TUVU5FQE1 CSC version: G920TTMB5FQE1 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R58G51D2YWF Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-05-01 RF cal date: 20150520 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 88 11 D1 77 35 04 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.28.6 |
The Following User Says Thank You to shahid. For This Useful Post: |
![]() | #20 (permalink) | |
Junior Member ![]() Join Date: Jun 2017
Member: 2730724 Status: Offline Thanks Meter: 2 | Quote:
![]() | #21 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2009 Location: serbia Age: 45
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | Code: UNLOCK INSTRUCTIONS: New Securiry Type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. 6. Press 'Read codes' button and select 'Read codes New' to read security codes. Old Securiry Type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. 5. Press 'Read codes' button and select 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-G925T Software version: 28.6 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 7.0 Product code: SM-G925TZKFTMB Phone version: G925TUVS5FQG1 PDA version: G925TUVS5FQG1 CSC version: G925TTMB5FQG1 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone SN: R58G31D340V Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-07-01 RF cal date: 20150318 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 08 E7 D4 CF D6 06 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.28.6 https://forum.xda-developers.com/app...mless-t3473445 |
The Following User Says Thank You to galijus For This Useful Post: |
![]() | #23 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2016 Location: valsad
Member: 2529129 Status: Offline Thanks Meter: 56 | samsung SM-J710F unlock done. z3x box UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. Operation: Unlock Selected model: SM-J710F Software version: 29.0 Waiting ADB device... OK Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZKDKSA Phone version: J710FXXU3AQF5 PDA version: J710FXXS3AQG2 CSC version: J710FOJV3AQD1 CSC country code: KSA CSC sales code: KSA HW version: MP 0.300 Phone SN: RF8H71LS9JV Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-07-01 RF cal date: 20160717 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 57 00 00 00 00 00 00 00 00 00 00 00 AA 0E DA D2 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.0 |
![]() | #24 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2009 Location: ***** Taste Good Age: 40
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,650 ![]() | ![]() UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Read Codes via Server Selected model: SM-G930A Selected port: COM669 SAMSUNG Mobile USB Serial Port Software version: 29.5 Checking Login and Password... OK Ballance: 15 crd. Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SAMSUNG-SM-G930A Android version: 7.0 Product code: SM-G930AZKAATT Phone version: G930AUCS4BQE1 PDA version: G930AUCS4BQE1 CSC version: G930AATT4BQE1 CSC country code: USA CSC sales code: ATT HW version: REV0.6 Phone SN: R58J42HZE1L Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-05-01 RF cal date: 2017.04.12 IMEI: 35XXXXXXXXXXXXXX Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM5 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 95730636 NET lock: 85020704 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.5 |
The Following User Says Thank You to ghacks For This Useful Post: |
![]() | #25 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2017 Location: Balochistan
Member: 2682425 Status: Offline Thanks Meter: 66 | successfully Remove Frp From G531H Thanks Searching Samsung USB Flash interface... COM85 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.29.5 |
![]() | #26 (permalink) |
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,650 ![]() | SM-N950U read codes done UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-N950U Software version: 29.6 Checking Login and Password... OK Ballance: 5 crd. Waiting ADB device... OK Reading phone info... Model: SM-N950U Android version: 7.1.1 Product code: SM-N950UZKAATT Phone version: N950USQU1AQIA PDA version: N950USQU1AQIA CSC version: N950UOYN1AQIA CSC country code: USA CSC sales code: ATT HW version: REV1.0 Phone SN: R38J906S88B Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-08-01 RF cal date: 2017.09.09 IMEI: 350000000xxxxxxxxxxxx8 Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM49 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 83839748 NET lock: 84619693 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.6 |
The Following 2 Users Say Thank You to ghacks For This Useful Post: |
![]() | #30 (permalink) |
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,650 ![]() | ![]() root the phone selected model sprint unlock the phone Waiting ADB device... OK Reading phone info... Model: SM-N950U Android version: 7.1.1 Product code: SM-N950UZVASPR Phone version: N950USQU1AQH8 PDA version: FA71_N950USQU1AQH8 CSC version: CSC country code: CSC sales code: HW version: REV1.0 Phone SN: R28J90R2K4T Modem board: MSM8998 Security patch: 2017-07-01 RF cal date: 2017.09.07 IMEI: Writing AT RIL... OK Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 https://mega.nz/#!8TBVQJqJ!VVK8EMogy...bCghyx-0ijrmvU https://mega.nz/#!cXJGEC4Q!DAHl-s9li...W9UlfvW9Cp8nEo Last edited by ghacks; 11-06-2017 at 15:39. |
