03-16-2010, 18:54 | #196 (permalink) |
Freak Poster Join Date: Jul 2007 Location: on cloud
Member: 543191 Status: Offline Thanks Meter: 42 | KB775F unlock perfect ! supported models: 97 andrew_tm 2009(c) You have last unlock.db! Not detect phone! Please manual select port or reboot PC! Mode: Normal Model: KB775F Build version: Apr 29 200916:46:39FEB 05 200910:00:00KB775F SW Version: KB775F-MSM6280-V10b-FEB-05-2009-OPN-BR IMEI: 3522xxxxxxxxxxxxxxx BlueTooth Address: 00:22:A9:82:5C3 Flash Name: toshiba_tya000bc00bogg Flash Info: 0691/0040/0800 Elapsed: 0 secs. Mode: Normal Model: KB775F Build version: Apr 29 200916:46:39FEB 05 200910:00:00KB775F SW Version: KB775F-MSM6280-V10b-FEB-05-2009-OPN-BR IMEI: 35220xxxxxxxxxxx BlueTooth Address: 00:22:A9:82:5C3 Flash Name: toshiba_tya000bc00bogg Flash Info: 0691/0040/0800 Elapsed: 0 secs. Firmware signature in base: 250 Ver: Apr 29 200916:46:39FEB 05 200910:00:00KB775F Signature detected! Start send loader... Loader startup OK... Flash IC name: toshiba_tya000bc0 Security backup saved to: C:\Arquivos de programas\Z3X\LG\LGQ\Backup\KB775F_352204030201141 _16032010_143043.sec Erase sec. zone... Write data to phone... Phone rebooted! Elapsed: 8 secs. |
The Following 3 Users Say Thank You to marcopolod For This Useful Post: |
03-18-2010, 19:05 | #197 (permalink) |
No Life Poster Join Date: May 2009 Location: spain
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | Gu280 Code: v.1.8.6 supported models: 98 andrew_tm 2009(c) ;) You have last unlock.db! Select ComPort or use Search Phone button! Elapsed: 0 secs. Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 3 secs. Mode: Normal Model: GU280 Build version: Oct 13 200916:15:26Jul 28 200924:00:00GU280 SW Version: GU280-QSC6240-V10b-SEP-11-2009-XX IMEI: 357 8-3 BlueTooth Address: 20:21:A5:3E:9F:CB Elapsed: 0 secs. Mode: Normal Model: GU280 Build version: Oct 13 200916:15:26Jul 28 200924:00:00GU280 SW Version: GU280-QSC6240-V10b-SEP-11-2009-XX IMEI: 357 BlueTooth Address: 20:21:A5:3E:9F:CB Elapsed: 0 secs. NV read... NV save:..\backup\GU280_35783_18032010_184634.cnv Elapsed: 46 secs. Selected file: C:\Celulares\lg\firmware\gu280\GU280AT-00-V10c-OPEN-XX-OCT-27-2009+1_PATCH_UNLOCK_v1.crp1 Mode: Normal Model: GU280 Build version: Oct 13 200916:15:26Jul 28 200924:00:00GU280 SW Version: GU280-QSC6240-V10b-SEP-11-2009-XX IMEI: 3579-3 BlueTooth Address: 20:21:A5:3E:9F:CB Elapsed: 0 secs. NV read... NV save:..\backup\GU280_3 010_184821.cnv Elapsed: 47 secs. Start flashing in Normal Mode Change mode... Phone Detected! Start write AMSS... AMSS write done! Start write BootLogo... Bootlogo write done! Erase EFS Initialize EFS Start write EFS... EFS write done! Reboot phone! Elapsed: 170 secs. Mode: Normal Model: GU280 Build version: Nov 25 200916:07:43Jul 28 200924:00:00GU280 SW Version: GU280-QSC6240-V10c-OCT-27-2009-XX IMEI: 35-3 BlueTooth Address: 20:21:A5:3E:9F:CB Elapsed: 0 secs. Mode: Normal Model: GU280 Build version: Nov 25 200916:07:43Jul 28 200924:00:00GU280 SW Version: GU280-QSC6240-V10c-OCT-27-2009-XX IMEI: 35125518-3 BlueTooth Address: 20:21:A5:3E:9F:CB Elapsed: 0 secs. Ver: Nov 25 200916:07:43Jul 28 200924:00:00GU280 Unlock done! Elapsed: 1 secs. |
The Following 3 Users Say Thank You to hugmax For This Useful Post: |
03-20-2010, 10:00 | #198 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Denmark Age: 41
Member: 268415 Status: Offline Thanks Meter: 57 | U300 unlock.. Mode: Normal Model: U300 Build version: May 18 200619:29:36MAY 18 200617:00:00U300 SW Version: U300-MSM6250A-V10a-MAY-18-2006-H3G-UK IMEI: 359288000******-0 BlueTooth Address: 00:12:56:4E:3D:6C Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. NV read... NV save:..\backup\U300_359288000******_20032010_13403 0.cnv Elapsed: 4 secs. Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! Write NV... EFS Write Start... Start Write Media... Start Write Module... EFS Write Done. Flash Done. Elapsed: 574 secs. Mode: Normal Model: U300 Build version: Sep 28 200619:04:03SEP 28 200617:00:00U300 SW Version: U300-MSM6250A-V10h-SEP-28-2006-H3G-UK IMEI: 359288000*****-0 BlueTooth Address: 00:12:56:4E:3D:6C Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. Start repair media... Change country to: United Kindom Phone reboot! Elapsed: 7 secs. Mode: Normal Model: U300 Build version: Sep 28 200619:04:03SEP 28 200617:00:00U300 SW Version: U300-MSM6250A-V10h-SEP-28-2006-H3G-UK IMEI: 359288000*****-0 BlueTooth Address: 00:12:56:4E:3D:6C Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM57 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... Unlock done! Phone reboot! Elapsed: 112 secs. |
03-20-2010, 11:59 | #199 (permalink) |
Freak Poster Join Date: Sep 2009 Location: TUNISIA
Member: 1114818 Status: Offline Thanks Meter: 247 | ks 360 flashed via usb PMB8888 Module 1.1 started. SW: Ver 2.2.2.229 Please connect phone , it must be powered off Booting... \\.\USB1 Phone found! (MCU:SG3_USB) prebooting... BOOT Stage Finished , sending authority... Unable to read IMEI in this mode Finished in 0 seconds Opening "KS360AT-00-V10e-EUR-XX-SEP-10-2008+0.bin"... Writing Firmware... Sending SEC pack... Writing done! Finished in 14 minutes 8 seconds. fast work and team thanks Z3X |
03-21-2010, 15:43 | #201 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | U310 unlock done:) Code: Mode: Normal Model: U310 Build version: Oct 31 200610:01:44MAY 09 200617:00:00U310 SW Version: U310-MSM6250A-V10b-NOV-01-2006-H3G-IT IMEI: 35281801019375-2 BlueTooth Address: 00:19:A1:1B:11:0D Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. Reading file as U310... Ok Original Flash File: U310-TRINITYR-V10a-OCT-12-2006-H3G-LATIN_OFF_SEC Mode: Normal Model: U310 Build version: Oct 31 200610:01:44MAY 09 200617:00:00U310 SW Version: U310-MSM6250A-V10b-NOV-01-2006-H3G-IT IMEI: 35281801019375-2 BlueTooth Address: 00:19:A1:1B:11:0D Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. NV read... NV save:..\backup\U310_352818010193752_21032010_200119.cnv Elapsed: 4 secs. Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! Write NV... EFS Write Start... Start Write Media... Start Write Module... EFS Write Done. Flash Done. Elapsed: 453 secs. Mode: Normal Model: U310 Build version: Jan 23 200717:32:09MAY 09 200617:00:00U310 SW Version: U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI: 35281801019375-2 BlueTooth Address: 00:19:A1:1B:11:0D Flash Name: toshiba_ty90009800cogg Flash Info: 0900/0020/0200 Elapsed: 0 secs. Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM19 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... - Write nand done... Unlock done! Phone reboot! Elapsed: 97 secs. WBR sahil2000ind |
03-22-2010, 08:49 | #202 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2006 Age: 38
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | <<<<Succsessfully unlock lg kp500 with z3x>>>> Here is log: Welcome to LG Infineon SGOLD3 TOOL v2x by NoName® models count: 51 Welcome to Sgold3 Module!! Count supported models - 51 Server news: ------------------------------------ [19.03.2010] Samsung Tool 3.4.0034 - E1170 and E1390 test full support. [18.03.2010] LG Qualcomm 1.8.6 released! Full Support for KE990c - World First! [11.03.2010] Samsung Tool 3.4.0033 - S7070 full support. [05.03.2010] China Editor 4.1 released! Added font using view and changing! [25.02.2010] Shell 3.4 released! New GUI. Bugfix. [16.02.2010] Samsung Smart Phone Tool Update 2.3.50 ----------------------------------- READ NEWS FOR DETAILS! ------------------------------------ Disconnected. PMB8877 Module 1.1 started. SW: Ver 2.2.2.162 Connecting to KP500 in UART Mode (COM8 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:UNK5) prebooting... Release power button. Booting... Reading info... BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\KP500_autobackup_22032 010_131017.eep Analising EEPROM... Phone IMEI:358748036767053 Unlock codes: NCK[0]: 12844955 (LOCKED) Br: Harkishan |
The Following User Says Thank You to Harkishan singh For This Useful Post: |
03-24-2010, 08:32 | #203 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Lgcu920 locked to at&t unlocked sucessfully:) Code: Mode: Normal Model: CU920 Build version: Dec 12 200814:36:03Nov 10 200823:00:00CU920 SW Version: CU920-MSM4090201D-V10s-DEC-12-2008-ATT-US IMEI: 01148900550536-9 BlueTooth Address: 00:22:A9:3E:20:03 Flash Name: toshiba_tya000bc00dogg Flash Info: 0696/0040/0800 Elapsed: 0 secs. Firmware signature in base: 255 Ver: Dec 12 200814:36:03Nov 10 200823:00:00CU920 Signature detected! Start send loader... Loader startup OK... Flash IC name: toshiba_tya000bc0 Security backup saved to: C:\Program Files\Z3X\LG\LGQ\Backup\CU920_011489005505369_24032010_125958.sec Erase sec. zone... Write data to phone... Phone rebooted! Elapsed: 7 secs. WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
03-25-2010, 15:43 | #204 (permalink) |
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | <<<<Succsessfully unlock lg GT365 with z3x>>>> Here is log: Welcome to LG Infineon SGOLD3 TOOL v2x by NoName® models count: 51 Welcome to Sgold3 Module!! Count supported models - 51 Server news: ------------------------------------ [19.03.2010] Samsung Tool 3.4.0034 - E1170 and E1390 test full support. [18.03.2010] LG Qualcomm 1.8.6 released! Full Support for KE990c - World First! [11.03.2010] Samsung Tool 3.4.0033 - S7070 full support. [05.03.2010] China Editor 4.1 released! Added font using view and changing! [25.02.2010] Shell 3.4 released! New GUI. Bugfix. [16.02.2010] Samsung Smart Phone Tool Update 2.3.50 ----------------------------------- READ NEWS FOR DETAILS! ------------------------------------ PMB8888 Module 1.1 started. SW: Ver 2.2.2.162 Connecting to GT365 in UART Mode (COM8 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8888) prebooting... Release power button. Booting... Reading info... BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Analising EEPROM... Phone IMEI:012249004656298 Unlock codes: NCK[0]: 00466090 (LOCKED) NCK[1]: 10=?44?1 (LOCKED) Br: Harkishan |
03-29-2010, 12:40 | #206 (permalink) |
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | <<<<Succsessfully unlock lg ks360 orange with z3x>>>> Here is log: Welcome to LG Infineon SGOLD3 TOOL v2x by NoName® models count: 51 Welcome to Sgold3 Module!! Count supported models - 51 Server news: ------------------------------------ [19.03.2010] Samsung Tool 3.4.0034 - E1170 and E1390 test full support. [18.03.2010] LG Qualcomm 1.8.6 released! Full Support for KE990c - World First! [11.03.2010] Samsung Tool 3.4.0033 - S7070 full support. [05.03.2010] China Editor 4.1 released! Added font using view and changing! [25.02.2010] Shell 3.4 released! New GUI. Bugfix. [16.02.2010] Samsung Smart Phone Tool Update 2.3.50 ----------------------------------- READ NEWS FOR DETAILS! ------------------------------------ Disconnected. PMB8888 Module 1.1 started. SW: Ver 2.2.2.162 Connecting to KS360 in UART Mode (COM8 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8888) prebooting... Release power button. Booting... Reading info... BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Analising EEPROM... Phone IMEI:357657038420051 Unlock codes: NCK[0]: 51133780 (LOCKED) Phone IMEI:357657038420051 Unlock codes: NCK[0]: <>0030=> (UNLOCKED) NCK[1]: 0=<?25?6 (LOCKED) Unlocking... Sending SEC pack... Reading EEPROM.... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\KS360_autobackup_29032 010_170553.eep Analising EEPROM... Phone IMEI:357657038420051 SimLock Data Cleared! Writing EEPROM.... Sending SEC pack... Unlock done! Br: Harkishan |
The Following 3 Users Say Thank You to Harkishan singh For This Useful Post: |
03-30-2010, 09:27 | #210 (permalink) |
Freak Poster Join Date: May 2007 Location: philippines
Member: 506576 Status: Offline Thanks Meter: 19 | need to add this version sir for imei repair KU990 RapidShare: 1-CLICK Web hosting - Easy Filehosting MD5: C33B6BBC7E02CAE66CF45E4FBAB8E3A0 |
Post here successfully job with Z3X-BOX Samsung (2010-2018) | mk | Z3X-Team Products | 21273 | 11-19-2018 09:21 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
