Old 03-27-2017, 19:40   #1 (permalink)
Member: 2314688
Sonork: 100.1681375
Thanks Meter: 179
Remove Frp Sony With Android 7.0 By Z3x [GUIDE]
Hi Every Body
Remove Frp Sony With Android 7.0 By Z3x latest Security
First : Connect your phone with Wifi and press next
then press first choice as in the photo
Second : press on any option then long press on any word then Choose Assist
Third : You show Google Now opened , write file to go file manager
Forth : connect your mobile with computer and copy Quick Shortcut Maker App into phone memory
Fifth : install app and open it and write on search "cor" Choose first choice
then check to enable Adb mode restart phone
sixth : connect phone with computer open z3x and choose any model support
remove Frp by Adb mode I had choose G935F and press Reset Frp then restart phone
Seventh : phone will be open , go setting and enable OEM unlock
Note : not necessary z3x you can do it with any box can remove Frp by Adb mode
The Following 160 Users Say Thank You to AbdallahAyoub For This Useful Post:
Old 03-31-2017, 15:38   #2 (permalink)
Abussabah's Avatar
Member: 412813
Sonork: 100.1594692
Thanks Meter: 345
Unbelivable
but ok 100%
The Following 5 Users Say Thank You to Abussabah For This Useful Post:
Old 04-06-2017, 17:38   #3 (permalink)
raulka2003's Avatar
Member: 489331
Thanks Meter: 1,135
Also no need Z3x box , just
Use adb command and will be done
The Following 5 Users Say Thank You to raulka2003 For This Useful Post:
Old 04-08-2017, 11:20   #4 (permalink)
GSMsurgeon's Avatar
Member: 6524
Thanks Meter: 246
100% working !!!!!
Tested many SONY phones and 100% working with z3x frp remove!!
The Following 6 Users Say Thank You to GSMsurgeon For This Useful Post:
Old 04-08-2017, 13:56   #5 (permalink)
Vahidpappali's Avatar
Member: 2602890
Sonork: NOTINSTALLED
Thanks Meter: 228
dosent neeed a box bro
if adb is on its dosent matter
The Following 3 Users Say Thank You to Vahidpappali For This Useful Post:
Old 04-13-2017, 18:24   #6 (permalink)
OBEDAKHARAT@EFT's Avatar
Member: 2706092
Thanks Meter: 1,554
yes all phones android enaple adb working unlock frp
The Following 2 Users Say Thank You to OBEDAKHARAT@EFT For This Useful Post:
Old 04-21-2017, 18:47   #7 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 707
Does this work with my Xperia theft??
The Following User Says Thank You to nessyb For This Useful Post:
Old 04-21-2017, 20:39   #8 (permalink)
Member: 1933270
Thanks Meter: 18
What command will you use on adb???
The Following 2 Users Say Thank You to ebemka For This Useful Post:
Old 04-25-2017, 14:09   #9 (permalink)
Member: 2604344
working with sony xperia z5?
The Following User Says Thank You to recyclers For This Useful Post:
Old 04-25-2017, 20:35   #10 (permalink)
Member: 686560
Thanks Meter: 66
everything will work if you did .
The Following 5 Users Say Thank You to serpas007 For This Useful Post:
Old 04-29-2017, 18:25   #11 (permalink)
Member: 2277857
Thanks Meter: 68
I have a Sony Xperia X Performance (Model SO-04H) from Japan. On the "Important Information Screen", I only have the "Diagnostics" choice. Anyone have an alternative to get to Internet/File Explorer?
The Following User Says Thank You to brg7562 For This Useful Post:
Old 05-02-2017, 16:41   #12 (permalink)
Registered User
Member: 567838
Thanks Meter: 64
I have a F5121 NOUGHT 7.0
When i try type file it does not show file commander in the list
The Following User Says Thank You to MORRISGSM For This Useful Post:
Old 05-31-2017, 10:33   #13 (permalink)
Member: 216446
Thanks Meter: 219
sony xz FRP REMOVER -not possible to copy
sony xz not possible to copy to quickshortcutmaker .apk to internal memory
its saying phone locked while i put in folder
The Following User Says Thank You to jseyedanas For This Useful Post:
Old 06-20-2017, 08:27   #14 (permalink)
Member: 2584867
Thanks Meter: 4
how about e6633 z5 adb will not work? i'll follow your instruction but no adb device.
The Following User Says Thank You to master_jey For This Useful Post:
Old 07-13-2017, 14:29   #15 (permalink)
Member: 2375318
Thanks Meter: 9
adb command??
please give adb commands
The Following 4 Users Say Thank You to PaRaDoX-M For This Useful Post:
Page generated in 0.22340 seconds with 9 queries
