Old 05-15-2015, 14:46   #1 (permalink)
Member: 762446
Thanks Meter: 13
canot repair imei sam g313hz
why i canot repair imei sam g313hz wiyh z3x?
http://postimg.org/image/9m2u1ii65/
http://postimg.org/image/sr4e4650n/
Old 05-15-2015, 22:09   #2 (permalink)
joel_3mo's Avatar
Member: 2061381
Sonork: 100.1673769
Thanks Meter: 129
View image: z3x2
View image: z3x
First you have to use LATEST software version, if you have activated Sams Tool PRO you should use v21.0 if not activated, you should use 20.5
Try and post result, and details of how you connected it.
Old 05-16-2015, 01:32   #3 (permalink)
Member: 762446
Thanks Meter: 13
REPAIR INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. connect the phone to PC with USB cable, install drivers if needed.
4. Fill values what you need to repair.
5. Press 'Repair' button.
Operation: Repair
Selected model: SM-G313HZ
Software version: 20.5
Waiting phone... not found
Done with Samsung Tool v.20.5
I've been at the root phone
Old 06-01-2015, 12:48   #4 (permalink)
gwlime's Avatar
Member: 1493085
Sonork: n/a
Thanks Meter: 92
same problem right here
Operation: Repair
Old 06-01-2015, 12:58   #5 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,558
Operation: Repair
use 19,1 or 21.2 version of sofrware.
The Following User Says Thank You to blang For This Useful Post:
Old 06-01-2015, 13:31   #6 (permalink)
gwlime's Avatar
Member: 1493085
Sonork: n/a
Thanks Meter: 92
Selected port:
Selected port speed: 115200
Waiting ADB device... OK
Reading phone info...
Model: SM-G313HZ
Android version: 4.4.2
Product code: Unknown
Phone version: Unknown
PDA version: G313HZDBU0ANL1
CSC version: G313HZOLB0ANL1
IMEI: Unknown
Phone S/N: Unknown
Checking Super user right... true
Repairing SN... OK
Bypass MSL... error (3)
Done with Samsung Tool v.19.1
Read info
Selected port: COM45 Z3X BOX Serial Port
Searching Samsung modem... detected COM137
Software version: =1,1
IMEI: 000000000000000
Old 08-04-2015, 15:23   #7 (permalink)
yudibanjar's Avatar
Member: 713923
Thanks Meter: 38
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on phone in download mode (turn off phone, press vol.down + home + power).
5. Connect phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Repair
Software version: 21.8
Model: SM-G313HZ
Product code:
Phone version:
PDA version: G313HZDBU0ANK3
CSC version: G313HZOLB0ANK2
CSC country code: INDONESIA
CSC sales code: XSE
HW version:
Phone S/N:
Modem board:
RF cal date:
IMEI:
Bypass MSL... error (-1)
Done with Samsung Tool PRO v.21.8
Please Help
cant repair imei
Page generated in 0.15336 seconds with 8 queries
