s3332.Writing c... error solution for this s3332 :confused::confused: Selected model: C3262 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 921600 Reconnect battery and connect phone to USB cable Phone detected Opening device... OK Checking device descriptions... OK Vendor ID: 04CC Lang ID: 0409 Checking config descriptor... OK Reading product ID... OK Product ID: 000150B318E8E620 Reading SCROM version... OK SCROM version: 0x32 Chipset version: 0x48 Sending loader... OK Start loader... OK Waiting phone... OK Opening device... OK Checking device descriptions... OK Vendor ID: 04CC Lang ID: 0409 Checking config descriptor... OK Reading loader version... OK Loader version: 7.5.16 Init Flash... OK Loading flash info... OK Configure Flash... OK Erase memory for external loader... OK Sending external loader... OK Start external loader... OK Waiting phone... OK Opening device... OK Checking device descriptions... OK Vendor ID: 04CC Lang ID: 0409 Checking config descriptor... OK Reading loader version... OK Loader version: 7.5.16 Init Flash... OK Load flash info... OK Configure Flash... OK OK Loading PTT file... OK Reading first block... OK Erasing first block... OK Flashing first block... OK Init bad block... OK Erasing IMAGE... OK Erasing LCDACT... OK Erasing DATA_RW... OK Erasing DSP... OK Erasing PAGE... OK Erasing MAIN... OK Erasing a... OK Erasing b... OK Erasing c... OK Erasing d... OK Erasing OTPW... OK Writing IMAGE... OK Writing LCDACT... OK Writing DATA_RW... OK Writing DSP... OK Writing PAGE... OK Writing MAIN... OK Writing a... OK Writing b... OK Writing c... error Done with Samsung Tool v.18.8 Done with Samsung Tool v.18.8 |
how about this, please direct me the right one please. :p:p FLASH INSTRUCTIONS: 1. Choose correct flash file(s). CSC can not be flashed separately, without main PTT file. 2. Press 'Flash' button. 3. Connect phone in flash mode (reconnect battery and connect USB cable). If you have dead phone, then try to connect it pressing 'Hold'+'vol.up' button and connect USB cable. Operation: Flash Selected model: GT-C3262 Software version: 23.0 Load model info... OK Loading BIN PTT file... OK Loading CSC PTT file... OK Reconnect battery and connect phone to USB cable Phone detected Checking device descriptions... OK Link type set to USBF Reading OTP register... OK OTP register: 00000000 Unprotected device detected Reading product ID... OK Product ID: 0x 0 150B318E8E620 Reading SCROM version... SCROM Version - 0x 32 Chipset Version - 0x 48 Downloading Loader of main loader in Internal RAM... OK Start PreLoader... OK Wait for device... OK Checking device descriptions... OK Loader verison... 7.5.16 Uploading internal Loader in S/D-DRAM Interface... DDRAM detected Flash memory parameters Capacity params: 0 Datawidth - 0 Block number - 0 Block size - 0 Buffer prog. Timing params: 0 ms erase block time - 0 us write buffer time Loader parameters Write Test flash params: 0x0 Test Address - 0 Test size Buffer params: 5 Buffer type - 1024 Buffer size - 1024 Tansfert size - 0 Tansfert RAW size Bad Block params: 0 Bad block reservoir size Wait for device... OK Checking device descriptions... OK Loader verison... 7.5.16 Nand Flash memory SSG_K521F12ACH-B050 detected Flash memory parameters Capacity params: 1 Datawidth - 1024 Block number - 128 Block size - 0 Buffer prog. Timing params: 6 ms erase block time - 600 us write buffer time Send Loader and NAND Flash Parameters... Loader parameters Write Test flash params: 0x0 Test Address - 0 Test size Buffer params: 3 Buffer type - 66958336 Buffer size - 32768 Tansfert size - 32768 Tansfert RAW size Bad Block params: 22 Bad block reservoir size SW Boot compatible Get First Block... OK Prepare First Block... OK Init Bad Block Managment... OK Send Verify Cmd... OK Erasing Partition_1... OK Erasing Partition_2... OK Erasing Partition_3... OK Erasing Partition_4... OK Erasing Partition_5... OK Erasing Partition_6... OK Erasing Partition_7... OK Erasing Partition_8... OK Erasing Partition_9... OK Erasing Partition_10... OK Erasing Partition_12... OK Programming Partition_1 Prepare CRC32... OK Set Partition Params... OK Download Partition_1 'IMAGE'... OK Check CRC32... OK Programming Partition_2 Prepare CRC32... OK Set Partition Params... OK Download Partition_2 'LCDACT'... OK Check CRC32... OK Programming Partition_3 Prepare CRC32... OK Set Partition Params... OK Download Partition_3 'DATA_RW'... OK Check CRC32... OK Programming Partition_4 Prepare CRC32... OK Set Partition Params... OK Download Partition_4 'DSP'... OK Check CRC32... OK Programming Partition_5 Prepare CRC32... OK Set Partition Params... OK Download Partition_5 'PAGE'... OK Check CRC32... OK Programming Partition_6 Prepare CRC32... OK Set Partition Params... OK Download Partition_6 'MAIN'... OK Check CRC32... OK Programming Partition_7 Prepare CRC32... OK Set Partition Params... OK Download Partition_7 'a'... OK Check CRC32... OK Programming Partition_8 Prepare CRC32... OK Set Partition Params... OK Download Partition_8 'b'... OK Check CRC32... error Flashing done (time - 00:03:41) Done with Samsung Tool PRO v.23.0 |
s3332 is not done with samsung pro. samsung tool is the answer. Selected model: C3262 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 921600 Reconnect battery and connect phone to USB cable Phone detected Opening device... OK Checking device descriptions... OK Vendor ID: 04CC Lang ID: 0409 Checking config descriptor... OK Reading product ID... OK Product ID: 0005548818F26040 Reading SCROM version... OK SCROM version: 0x32 Chipset version: 0x48 Sending loader... OK Start loader... OK Waiting phone... OK Opening device... OK Checking device descriptions... OK Vendor ID: 04CC Lang ID: 0409 Checking config descriptor... OK Reading loader version... OK Loader version: 7.5.16 Init Flash... OK Loading flash info... OK Configure Flash... OK Erase memory for external loader... OK Sending external loader... OK Start external loader... OK Waiting phone... OK Opening device... OK Checking device descriptions... OK Vendor ID: 04CC Lang ID: 0409 Checking config descriptor... OK Reading loader version... OK Loader version: 7.5.16 Init Flash... OK Load flash info... OK Configure Flash... OK OK Loading PTT file... OK Reading first block... OK Erasing first block... OK Flashing first block... OK Init bad block... OK Erasing IMAGE... OK Erasing LCDACT... OK Erasing DATA_RW... OK Erasing DSP... OK Erasing PAGE... OK Erasing MAIN... OK Erasing a... OK Erasing b... OK Erasing c... OK Erasing d... OK Erasing OTPW... OK Writing IMAGE... OK Writing LCDACT... OK Writing DATA_RW... OK Writing DSP... OK Writing PAGE... OK Writing MAIN... OK Writing a... OK Writing b... OK Writing c... OK Writing d... OK Writing OTPW... OK Rebooting... done Flashing done (time - 00:03:08) Done with Samsung Tool v.18.8 Done with Samsung Tool v.18.8 |
i need working firmware for z3x pro plz |
