05-09-2011, 21:30 | #1 (permalink) |
Insane Poster Join Date: Jun 2007
Member: 526391 Status: Offline Thanks Meter: 19 | Samsung E251 no service I flashed, restore defautl EEPROM from the site, and nothing happens... I got the phone with this problem, client say that before it has network signal, but after he try to unlock (putting any !@#$%^&* codes) the imei set in 00000.....). So I custom repair the phone, IMEI now is Ok, but no signal! BTW restoring default EEPROM from the site doesn't work, here are the logs: Selected model: E251 Selected com port: COM2 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3721 Sending loader2... OK Flash ID: 00EC2206000100000024 timeout Send NOR - fail Elapsed time: 89 second, sw ver: 3.5.0015 But when I read and write phone EEPROM, everything is Ok but network signal is out anyway... Any idea?? I don't think is hardware fail, also I read in the forum some reference to the same problem? Somebody from Z3x Team please help me?? Thanks in advance... |
03-11-2013, 23:24 | #8 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: Europe Wienna
Member: 984046 Status: Offline Thanks Meter: 255 | Quote:
Same here. Anyone have some readout? / NOT eeprom from support Br Haltec | |
03-13-2013, 13:51 | #9 (permalink) |
Member: 984046 Status: Offline Thanks Meter: 255 | Code: Selected model: E251 Selected com port: COM2 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3721 Sending loader2... OK Flash ID: 00EC2206000100000024 timeout Send NOR - fail Elapsed time: 72 second, sw ver: 3.5.0040 Can someone upload an ok E251 eeprom for Z3X? thx Haltec |
03-14-2013, 19:06 | #10 (permalink) |
Member: 984046 Status: Offline Thanks Meter: 255 | Ok I tried every possible combination of USB<<>>Serial interfaces, along with onenand_downloaders along with z3x soft versions... on a different PC's And can't DUMP single HEX nor EEP from two different E251 one with no network and one fully functional!!!! Code: Selected model: E251 Selected com port: COM2 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3721 Sending loader2... OK Flash ID: 00EC2206000100000024 timeout Read EEP - fail Elapsed time: 86 second, sw ver: 3.5.0030 Selected model: E251 Selected com port: COM2 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3721 Sending loader2... OK Flash ID: 00EC2206000100000024 timeout Read EEP - fail Elapsed time: 83 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- ** Wait for Connect Request from Mobile... ** (POWER ON the PHONE!) ** Send '0x44' to SWIFT Chip ** Connection granted from SWIFT Chip ** Received 16 bytes from SWIFT chip ** Sending the customer ID and the same 16 bytes to SWIFT chip... OK! ** Try to change Timeout ! ** Ok! Timout Changed(1600 mSecond) ** Setting downloading address (SCRAM: 0x1C000000)... OK! ** Downloading the pre-Loader (1856 bytes)... OK! ** Set the start address of pre-Loader (SCRAM:0x1C000000)... OK! Start Pre-Loader... OK! Trying to change the baudrate... Change Baudrate 115200 -> 921600... OK! BB Chip version(00003721) Downloading the Boot-Loader (237348 bytes)... OK! Jump to Boot-Loader (RAM:0x30000000)... OK! Sending the base address of CS0 (0x20000000)... OK! Checking FLASH ID... Detected (KAP29SN00M),OneNandID(24) Nand flash ID = ONE 512M NAND FLASH ** Now you can do the followings. ** 1. Download the BINARY and/or TFS files 2. Dump NOR-Flash 3. Erase NOR-Flash 4. Format Nand-Flash 5. Dump TFS files 6. Check the status of NAND-Flash ** Checking TFS system (NAND Flash)... OK! < Result > 1. FileSystem Type( f_type ) : 12EE94 2. Optimal transfer block size( f_bsize ) : 2010467276 (0x77D54BCC) 3. block size in bits( f_bsizebits ) : 6501872 (0x6335F0) 4. total data blocks in file system( f_blocks ) : 874 (0x36A) 5. free blocks in file system( f_bfree ) : 9194 (0x23EA) 6. free blocks avail to non-superuser( f_bavail ) : 9194 (0x23EA) 7. total file nodes in file system( f_files ) : 1176832 (0x11F500) 8. free file nodes in file system( f_ffree ) : 0 (0x0) 9. file system id( f_fsid ) : FATF 10. maximum file size( f_maxfilesize ) : 61132800 (0x3A4D000) 11. maximum length of filenames( f_namelen ) : 255 (0xFF) Dumping sector ( SectorNum = 220 )... OK! Dumping sector ( SectorNum = 221 )... OK! Dumping sector ( SectorNum = 222 )... ** Wait for Connect Request from Mobile... ** (POWER ON the PHONE!) ** Send '0x44' to SWIFT Chip ** Connection granted from SWIFT Chip ** Received 16 bytes from SWIFT chip ** Sending the customer ID and the same 16 bytes to SWIFT chip... OK! ** Try to change Timeout ! ** Ok! Timout Changed(1600 mSecond) ** Setting downloading address (SCRAM: 0x0C000000)... OK! ** Downloading the pre-Loader (1840 bytes)... Bad response(0xFE) from SWIFT Chip Anyone ever managed to made hex dump with one of downloaders??? Is it some buggy samsung $HIT or what? Cant even restart procedure when stopped, without restarting whole sw!!!! Ideas? Haltec |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
gsm service provider | sidou | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-30-2000 11:09 |
FREE SP unlock service | timxy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-22-1999 16:05 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
