04-30-2017, 22:37 | #46 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2465774 Status: Offline Thanks Meter: 0 | sm-g935f error 0 4 I have this problem being repaired Lettura info telefono... Modello: SM-G935F Android version: 6.0.1 Codice prodotto: SM-G935FZSANEE Versione Phone: G935FXXU1APBD PDA version: G935FXXU1APC8 CSC version: G935FXEU1APB2 Codice Paese CSC: UK & IRE Codice vendita CSC: XEU HW version: MP 0.801 Phone SN: RF8HB0HWMTW Chip name: EXYNOS8890 Piastra modem: SHANNON335 Security patch: 2016-03-01 RF cal date: 20161105 IMEI: Controllo diritti Super user... vero Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Stò calcolando... errore (0 4) Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Lettura dati da telefono... Ok Piastra modem: SHANNON335 HWID: D8 76 1D B2 AE FE F6 52 39 C0 ED 96 20 26 F5 6F Stò calcolando... Ok Riparazione... Ok Writing NV data... Ok Riavvio telefono... Ok Riparazione eseguita Done with Samsung Tool PRO v.28.1 Solutions to my problem? Thanks to team z3x |
05-01-2017, 07:10 | #48 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: PDA version: G935FXXU1BPLB CSC version: G935FOJV1BPK2 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: RF8H327G0EF Chip name: EXYNOS8890 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.8 |
05-01-2017, 12:06 | #51 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. (Note, that the cert file for this model is unique. You can write cert, wich is readed from this device exactly.) 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-G935F Software version: 27.8 Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: PDA version: G935FXXU1APAW CSC version: G935FBTU1APB2 CSC country code: UK & IRE CSC sales code: BTU HW version: Phone SN: RF8H327G0EF Chip name: EXYNOS8890 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.8 |
05-08-2017, 16:26 | #52 (permalink) |
Junior Member Join Date: Feb 2005 Age: 52
Member: 115991 Status: Offline Thanks Meter: 0 | After performing the imei repair, I also performed the certificate patch, when I restarted the phone, I found two imei. Did it happen to you too? Is it possible to solve the problem? Thank you |
10-24-2017, 19:27 | #55 (permalink) |
Crazy Poster Join Date: Apr 2005 Location: Gronau Age: 48
Member: 136882 Status: Offline Thanks Meter: 16 | Solution Patch 7.0 I downgraded 3 phones to 6.01 and patched cert. 1 everything fine but 2 units loose wifi no camera. One Turkish guy claiming that he repaired 7.0 but files are pw protected. Octopus did it and we are still waiting with half solutions. Any suggestions or info how to patch 7.0 on G935F |
01-04-2018, 07:00 | #56 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 328 | G935f Dual sim 7.0 need patch CERT but Can't Root Hello Team i need help to Patch Cert Samsung S7 G935f on 7.0. I try to root phone by Cf auto root file & also try with TWRP method but always phone locked memory and Stuck on startup logo. Phone successfully rooted on 6.0.1 & patch Cert done. but Customer want 7.0, every time after update 6.01 to 7.0 this phone needs to repair network. Why? This phone is Dual Sim, in download mode, phone show Sm-G935f but after flash phone show in about Sm-G935FD. Here is info Code: Searching Samsung modem... detected COM23 Reading phone info... OK Model: SM-G935FD AP version: G935FXXU1DQIC CSC version: G935FXXU1DQIC CP version: G935FXXU1DQB1 Product code: BTU Phone SN: R58J26L255T Unique number: CE12160CE3AA6CA10C Reading IMEI... OK IMEI: 3547083741***** (SIGN: NG_SIGN) Reading IMEI 2... OK IMEI 2: 354708384***** (SIGN: NG_SIGN) Done with Samsung Tool PRO v.30.2.2 phone has no Root. please tell me any solution for root this phone or any way to solve this problem (every time after update 6.01 to 7.0 this phone needs to repair network) Thanks Best Regard's |
01-18-2018, 09:24 | #58 (permalink) |
Freak Poster Join Date: Jul 2013 Location: In your heart.
Member: 1973579 Status: Offline Thanks Meter: 30 | Try to root using TWRP. If you had flashed custom rom (ROM.G93xF.XXU1DQIC-v21.0.by.ambasadii.zip) phone will boot successfully. After that you can patch cert. |
02-05-2018, 08:12 | #59 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: pakistan
Member: 583290 Status: Offline Thanks Meter: 107 | Quote:
patch cert but imie status NG_SIGN and phone is with emergency calls only. need help please..need to solve with 7.0. | |
02-24-2018, 19:51 | #60 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1532191 Status: Offline Thanks Meter: 2 | Only Emergency call G935f Hello I just repaired an IMEI of a G935F and everything OK in Android 7.0, the problem is that I only appear ONly EMERGENCY CALL, I have seen that it is fixed by degrading the modem, can someone guide me a bit? PD: i used patch certificate yet |
