02-09-2015, 10:27 | #1 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2328103 Status: Offline Thanks Meter: 0 | S4 GT-i9505 ( mobile network not avialable ) serial number 00000000000 PROBLEM i am new to z3x boxes i have both of your products the BOX and the Pro Jtaj so i have this problem which i9505 came to me with ( not registered in network ) problem with 4.2.2 AOS i had just update it to new 4.4.2 kitkat version with the firmware details as follow : AP: i9505xxufna5 CP: i9505xxufna5 csc: i9505ojvemk5 the problem was temporary fixed but back again with ( mobile network not avialable ) problem and serial number becomes 00000000000 Then i rooted it and changed the IMEI with the original IMEI which in back sticker , problem still in with network. Then i flashed modem file or Baseband with i9505XXUFNA1 just for trying and also i attempt with restoring the QCN file i Backed it up firstly also still stuck with this PROBLEM ( mobile network not avialable ) . 1- i don't sure which serial number to write and how to do that... 2- i think it's realy simple problem but there is something messing for me because the i9505 is 4G LTE phone and in my region it's not function-able yet we had only GSM 2G / 3G wcdma hspa and these 3G releases. 3- i read a bout repair network and Network fix file NVM but these method was in earlier versions of z3x software tools and i use the latest one. please help me if you understand exactly where can be this problem and how to fix it with my tools... |
02-09-2015, 10:58 | #2 (permalink) |
No Life Poster Join Date: Mar 2013 Location: pakistan Age: 34
Member: 1899191 Status: Offline Sonork: 100.1625109 Thanks Meter: 136 | bro u need to find out ok efs back up from runing set and then restore with z3x ur imei num will dame like 00444999 but ur serial num show RXZXXXX LIKE THIS after that repair imei num and check gain ur problm wil slove ......but take back up laso of everyt hing |
The Following User Says Thank You to Malik_GSM For This Useful Post: |
02-09-2015, 11:14 | #3 (permalink) |
Member: 2328103 Status: Offline Thanks Meter: 0 | thanks Malik_GSM but please tell me if you can the under battery sticker is scratched i can't see the S/N and where can i find a good EFS back up file and how to write it with z3x PLEASE i am STUCK with this phone from two days ago |
02-09-2015, 11:18 | #4 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
if you will not follow this manual, post will be deleted | |
The Following User Says Thank You to blang For This Useful Post: |
02-09-2015, 11:41 | #5 (permalink) |
Member: 2328103 Status: Offline Thanks Meter: 0 | also After that if i found EFS file how to repair the IMEI and S/N how can i generate these numbers i have the IMEI but the S/N is 00000000000 and sticker is gone as i mentioned before |
02-10-2015, 11:52 | #7 (permalink) |
Member: 2328103 Status: Offline Thanks Meter: 0 | my problem now is how to write a QCN file to i9505 running AOS 4.4.2 first problem is with help connection procedure in manual i can't see MODEM or PDA setting when use *#7284# and when use DM/DUM over HS-USB* in *#9090# the phone reboot and don't know it's set or not sometimes when i use RNDIS-DM-MODEM can read QCN but when attempt to Write QCN it ends with error as the log below Selected model: I9505 Selected port: COM15 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading QCN file... OK Checking phone at COM15 Detected ID: 00000FE8 (Unknown) SW Version: Checking paths... error Restoring EFS Backup... error (0) Done with Samsung Tool v.18.9 and when i use QPST tool it doesn't read the phone |
