11-12-2019, 10:32 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Kampala,Uganda
Member: 2294589 Status: Offline Thanks Meter: 116 | G935F imei repair Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Root Selected model: SM-G935F Software version: 38.2 Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 6.0.1 PDA version: G935FUBU1BQB1 CSC version: G935FTCE1BQB1 Phone version: G935FXXU1BPL6 Product code: SM-G935FZKLTCE CSC country code: MEXICO CSC sales code: TCE Phone SN: RF8H42ZNGNH IMEI: 350000000000000 HW version: MP 0.801 RF cal date: 20160428 Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2017-02-01 Boot Warranty bit: 0 SIM State: ABSENT Checking Super user right... false Rebooting to download... OK Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Searching USB Flash interface... COM17 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... timeout Phone not found Done with Samsung Tool PRO v.38.2 After the operation its now hanging on log |
11-12-2019, 21:41 | #2 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Under the Sky
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 171 | Quote:
Its not rooted or you didnt grant access Sent from my iPhone using Tapatalk | |
The Following User Says Thank You to oktay50000 For This Useful Post: |
