s8000 no network Hi i unlocked a samsung s8000 by Flashing patch file to phone S8000XEIG2_patched_for_unlock.crp and then unlock method Read codes was used then i flashed it agin with S8000XEIG2_crp and no its not picking up any network i even changed the imei number to see but still no network. Any help im a new user. Thank You. Searching Samsung USB interface... detected (COM20) Model: S8000 SW: S8000XEIG2 IMEI: 35202803508511/2 Reading codes... OK Calculating codes... OK (time - 00:00:57) Freeze code: 79419482 NET lock: #7465625*638*00000000# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*00000000# SIM lock: #7465625*746*00000000# For check lock status: *#7465625# Count supported models - 188 Reading file... OK Model: S8000 Version: S8000XEIG2 Searching Samsung USB Flash interface... detected (COM20) Sending file 1 of 5... sended Sending file 2 of 5... sended Sending file 3 of 5... sended Sending file 4 of 5... sended Sending last file... sended Flashing done (time - 00:07:02) Count supported models - 188 Searching Samsung USB interface... detected (COM20) Model: S8000 SW: S8000XEIG2 IMEI: 35202803505811/9 |
try manual reset just type *2767*3855# if same flash w/original version of phone and then unlock |
I try manual reset *2767*3855# its same i dont no what was the original version of phone |
ma flash de fon with patch unlock file it will be ok |
tryed that to still no network |
Is the no one that can help? |
me too , i have 1 was unlocked good , and 1 no signal . i will make new dumf with ORT and will say result. |
its just says s8000 on the back of phone |
:( i have2 phone no network after unlock :( is s8000l any chance to revive :) |
