03-04-2017, 15:14 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Bangladesh/USA/UK Age: 39
Member: 1033714 Status: Offline Sonork: 1640811:mothertelecom Thanks Meter: 91 | g925f imei repair error Security damaged (1) REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Repair Selected model: SM-G925F Software version: 27.7 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G925F Android version: 6.0.1 Product code: Phone version: G925FXXU4BPF1 PDA version: G925FXXU3DPFJ CSC version: G925FOLB3DPFJ CSC country code: VIETNAM CSC sales code: XXV HW version: Phone SN: Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.7 |
03-04-2017, 16:25 | #2 (permalink) | |
Insane Poster Join Date: Jul 2013
Member: 1989337 Status: Offline Thanks Meter: 5 | SM-G925F CERT - Download - 4shared Quote:
03-04-2017, 16:28 | #3 (permalink) | |
Member: 1989337 Status: Offline Thanks Meter: 5 | Quote:
03-04-2017, 22:04 | #5 (permalink) |
Insane Poster Join Date: Mar 2010
Member: 1249625 Status: Offline Thanks Meter: 17 | hey bro he posted cert lol ? SM-G925F CERT - Download - 4shared |
The Following 3 Users Say Thank You to bleross For This Useful Post: |
03-06-2017, 02:18 | #7 (permalink) |
Junior Member Join Date: Jul 2014 Location: beirut lebanon
Member: 2230122 Status: Offline Sonork: 100.1659238 Thanks Meter: 6 | hello guys plz i need ur help i have samsung s6 edge sm-g925f but when entering download moce it shows g925p model and un able to flash repair files and unable to boot device frp lock is off i flashed tochwiz falied to repair drv using z3x plz help |
The Following User Says Thank You to mega.bahri For This Useful Post: |
