Samsung 6 edge G925T v5.1.1 root failed downgrade to v5.0.1 pls z3x team i av samsung g925t it av v5.1.1 cant root to unlocked and av dwld firmware from support trying to flash so it can downgrade but i got error here is the logs Operation: Flash Selected model: SM-G925T Software version: 21.5 File analysis... OK Total file size: 0xDB8E1740 (3512 Mb) Searching USB Flash Interface... detected COM196 Setup connection... OK Reading PIT from phone... OK Sending boot.img... error timeout Done with Samsung Tool PRO v.21.5 On phone it said KEANEL REV. CHECK FAIL. DEVICE:2, BINARY:1 Phone hang now |
What root is failing? Have you tried CF autoroot for the G920T? (I know you have the G925T) |
it cant boot now only with logo |
I have 2 with the same problem. Both were repaired (IMEI and Unlocked) and now are stuck on SAMSUNG logo after updating to 5.1.1 Any solution to this problem? |
You need to flash this original firmware and make phone alive again G925TUVU1AOCG_G925TTMB1AOCG_G925TUVU1AOCG_HOME.tar https://www.unlockbase.com/download/...e-firmware.zip Then root it with Tennis root when phone is alive :D:D:D:D then unlock it if you wish Also there is no downgrade or upgrade for this phone at all, doesn't exist at any place for the moment any other firmware except the one above posted which can be found also on Z3X support site Quote:
KEANEL REV. CHECK FAIL. DEVICE:2, BINARY:1 on the phone and cant boot hang on logo |
So...has anyone tried twrp/cwm? Afaik, custom recoveries normally work in the event that direct kernel roots and cf roots dont work. (Please dont ask where to get a custom recovery or how to use it...these things are easily searchable and will result in a lmgtfy response from me). |
IMEI repaired S6 edge..for testing purposes updated to 5.1.1 . Phone will not boot. I flashed stock original EFS and phone came back on just fine..also you cannot downgrade due to new boot loader. |
So its blocking custom recoveries...why not just use a locked bootloader at that point? *shrug* |
