samsung a10 imei repaire problem here is log BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write NV DATA' if you need to restore NV backup. Operation: Repair Selected model: SM-A105F Software version: 37.0 Waiting ADB device... OK Reading phone info... Model: SM-A105F Android version: 9 PDA version: A105FPUU3ASG3 CSC version: A105FOJM3ASG2 Phone version: A105FXXU3ASG3 Product code: SM-A105FZKGPAK CSC country code: PAKISTAN CSC sales code: PAK Phone SN: RF8M42TK21R IMEI: xxxxxxx HW version: MP 0.300 RF cal date: 20190420 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2019-06-01 Boot Warranty bit: 1 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... modem not supported Searching server... OK Checking available files... not found compatible file KNOX WARRANTY VOID is 0x1. Phone is not supported Done with Samsung Tool PRO v.37.0 |
no answer???????????????????? |
downgrad modem all ok |
Try that Modem https://mega.nz/#!KEsG2Cga!mGjS8KX6K...3KCy8La-Hr9kCA |
A105f new security can not be flashed by eng modem or combination file.. |
