06-29-2017, 12:05 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | i9060 after flash no service 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. If you have one file firmware, then you must check 'Use one package file' option. 4. Check flashing options if needed (Repartition, EFS clear, Boot update). 5. Power on phone in download mode (turn off phone, hold Volume Down + Home + Power). 6. Connect phone to PC with USB cable, install drivers if needed. 7. Press 'Flash' button. Operation: Flash Selected model: GT-I9060 Software version: 28.2 File analysis... Ok Total file size: 0x53A030C8 (1338 Mb) Searching USB Flash interface... COM55 detected Setup connection... Ok Reading PIT from phone... Ok Sending sboot.bin... Ok Sending param.lfs... Ok Sending dt-blob... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending system.img... Ok Flashing done (time - 00:06:46) Done with Samsung Tool PRO v.28.2 |
06-29-2017, 19:16 | #3 (permalink) |
Freak Poster Join Date: Jun 2017 Location: Garden Grove, Ca U.S.A. Age: 49
Member: 2723959 Status: Offline Thanks Meter: 49 | Easiest way....flash BINARY 4 files with ODIN: USE these options: Auto-Reboot NAND Erase All Re-Partition F. Reset Time Phone Bootloader Update Phone EFS clear Wait 10 minutes after flash to reprogram Modem Complete Restore to FACTORY complete!! |
