01-06-2017, 18:19 | #2 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 677934 Status: Offline Thanks Meter: 28 | Searching Samsung modem... detected COM79 Reading phone info... Ok Model: SM-G935FD AP version: G935FXXS1APG3 CSC version: G935FOJV1APF1 CP version: G935FXXU1APEQ Product code: SM-G935XZKAXSG Phone SN: RF8H31RC88Y Unique number: 9885E6303839425632 Reading IMEI... Ok IMEI: 351989030000011 (SIGN: NG_NONE) IMEI 2: 355565554989890 (SIGN: NG_NONE) Done with Samsung Tool PRO v.27.7 |
01-06-2017, 22:49 | #4 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Follow these instructions 1.Flash this firmware G935FXXUIAPD8(search on android file host) 2.Hard reset mobile 3.Root with z3x(Do not use cf root or any other) 4.Repair ime 5.patch cert You are done.. check network and dont forger root will trip knox which means it will drain bettery just because of patched kernal even after restore to stock plus you need to patch cert after each flash.It is a temporary solution like s3 in old days.. And it will stay as it is untill blang figures some other way to do it. |
The Following User Says Thank You to zishhaider For This Useful Post: |
01-07-2017, 10:37 | #6 (permalink) | |
Member: 677934 Status: Offline Thanks Meter: 28 | Quote:
no link for this firmwear have a link i search but not found | |
01-07-2017, 12:06 | #7 (permalink) |
Freak Poster Join Date: May 2008 Location: SYRIA Age: 32
Member: 772728 Status: Offline Thanks Meter: 163 | this is your firmware https://www.androidfilehost.com/?fid=24533103863137523 and this is my bost http://forum.gsmhosting.com/vbb/f453...100-a-2163386/ GOOD LUCK MY FRIND |
The Following User Says Thank You to ahmad0x9 For This Useful Post: |
