06-22-2022, 13:53 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: TURKEY ADANA Age: 36
Member: 724562 Status: Offline Thanks Meter: 217 | Samsung A520f u16 simlock problem [Answered] UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [UPLOAD 2021] Selected model: SM-A520F Software version: 44.11 Checking Login and Password... OK Balance: 20 crd. You have 20 credit(s) left. This operation takes 5 credits. Attention! In case if phone asking MCK code, using this method will consume credits twice - first for MCK code and then for NCK. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A520F Android version: 8.0.0 PDA version: A520FXXUGCTKA CSC version: A520FOXAGCTL1 Phone version: A520FXXUGCTKA Product code: SM-A520FZKAXEF CSC country code: France CSC sales code: XEF Phone SN: R58J61W039E IMEI: 358651087490874 HW version: MP 0.401 RF cal date: 20181211 Chip name: EXYNOS7880 Modem board: SHANNON325 Security patch: 2020-12-01 Boot Warranty bit: 0 SIM State: READY Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool Loader... OK Running zTool, please wait... OK Loading... OK Initialization zTool... OK Running zTool, please wait... OK Reading lock state... OK Executing... OK Searching Ramdump interface... COM610 detected Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Reading ramdump data from phone... OK Calculating... OK Now only the MCK(Freeze) code will be calculated. Continue? Yes Searching server... OK Waiting for server answer... OK Freeze code (MCK): 16971358 To calculate NCK(Network) code perfom the following operations: 1. Insert the SIM card. 2. Enter the MCK(Freeze) code. 3. Remove the SIM card. 4. Reboot phone. 5. Try again. Done with Samsung Tool PRO v.44.11 [SM-A520F,Read Codes via Server [UPLOAD 2021]] freze cod openinig succesfull and simlock pin |
06-23-2022, 14:52 | #6 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,056 | Method takes credtis separately for both codes, software warn you about this. Code: Attention! In case if phone asking MCK code, using this method will consume credits twice - first for MCK code and then for NCK. Continue? Yes Code: Now only the MCK(Freeze) code will be calculated. Continue? Yes |
