Samsung a710k (a7 korea) FRP Not Suppor With New Update FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A710K Software version: 31.0 File analysis... OK Total file size: 0xB5505348 (2901 Mb) Searching USB Flash interface... COM29 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Sending modem.bin... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:03:13) Done with Samsung Tool PRO v.31.0 LOG FROM INFO : Operation: Info Selected model: SM-A710K Software version: 31.0 Searching Samsung modem... detected COM52 Reading phone info... OK Model: SM-A710K AP version: A710KKKU1APB1 CSC version: A710KKTC1APB1 CP version: A710KKKU1APB1 Product code: KTC Phone SN: R39H903SYK Unique number: C0000E594237853 Reading IMEI... OK IMEI: NONE (SIGN: NG_SIGN) Done with Samsung Tool PRO v.31.0 Try Flash with 3 File from SHELL but ADB Not Enable,,,,,,,,, |
Upp again,,Need Solution,,,,,,,,,,,,,,,,,,,,, |
Stil waiting Solution,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,, |
try to enable adb via emergeny call *#0808# |
Try Emergency call but not Work,,,,,,,,,,,, |
If need solution then pm or email. very easy |
HHeeeeeeemmmmmmmmmmmmmmmmmmmmmm |
