02-19-2020, 11:13 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | A40 A405FN Network Unlock Cheap Price To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-A405FN Software version: 39.4 Checking Login and Password... OK Ballance: 5 crd. You have 5 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A405FN Android version: 9 PDA version: A405FNXXU2ASG1 CSC version: A405FNOBE2ASG1 Phone version: A405FNXXU2ASF2 Product code: SM-A405FZKDEVR CSC country code: UK CSC sales code: EVR Phone SN: R58MA39J5AT IMEI: 351777xxxxxxxxx HW version: REV0.3A RF cal date: 20191015 Chip name: EXYNOS7904 Modem board: SHANNON327 Security patch: 2019-07-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 70590727 NET lock: 48052071 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.39.4 |
The Following 2 Users Say Thank You to qasir_amz For This Useful Post: |
06-09-2020, 18:45 | #2 (permalink) | |
Product Supporter Join Date: Nov 2006 Location: Ecuador, Shenzhen, Guangzhou Age: 55
Member: 394446 Status: Offline Sonork: 100.1579789 Thanks Meter: 74 | Quote:
It is taking long to unlock is it normal? | |
The Following User Says Thank You to otto68 For This Useful Post: |
