Old 05-22-2018, 17:30   #1 (permalink)
Member: 713641
Thanks Meter: 5
G925f frp memory problem
bonjour
i have frp and samsung account unlock with Z3x but after the phone works fine baut the memory is not 32 go but 3 go
Model: SM-G925F
Platform Id: exynos5
OS Version: 7.0
Build Id: NRD90M
Build version: NRD90M.G925FXXU5EQI6
Software version: G925FXXU5EQI6
any solution for recover the full 32 go
THANKS
ALL YOU NEED IS....
Old 05-22-2018, 20:08   #2 (permalink)
Member: 2613252
Thanks Meter: 1,837
Originally Posted by ALLYOUNEEDIS View Post
bonjour
Model: SM-G925F
OS Version: 7.0
Build Id: NRD90M
THANKS
ALL YOU NEED IS....
hello, to restore the memory to 32 gb you have to try to flash another firmware based on the binary revision of the firmware that you have installed in the phone in this case binary 5 and according to the firmware of the country of origin and see if the memory from 3 gb back to 32gb to bypass frp you can use the ufs memory method z3x with the uart cable or the combination file
The Following User Says Thank You to amleto90 For This Useful Post:
Old 05-23-2018, 10:59   #3 (permalink)
Member: 713641
Thanks Meter: 5
BONJOUR
THANKS amleto90
BUT WHERE CAN I FIND THIS FIRMWARE AND THIS COMBINATION FILE
THANKS
ALLYOUNEEDIS
Old 05-23-2018, 12:12   #4 (permalink)
Member: 2613252
Thanks Meter: 1,837
BONJOUR
THANKS amleto90
THANKS
ALLYOUNEEDIS
hello, before using the combination file use the ufs memory method for the z3x frp bypass here below two videos of how to proceed
https://m.youtube.com/watch?v=VfygzlDlg6E
https://m.youtube.com/watch?v=C6vdA2BIRIA&t=3s
In case the uart method does not work I can give you the compatible combination with the firmware installed on the phone to download the firmware with binary 5 you can download from sammobile . com according to the binary of the firmware and the country of origin of the firmware and the phone
Old 05-23-2018, 16:48   #5 (permalink)
Member: 713641
Thanks Meter: 5
Thanks but now my phone is in binary 6
any ide
br
allyounnedis
Old 05-23-2018, 16:53   #6 (permalink)
Member: 2613252
Thanks Meter: 1,837
any ide
br
allyounnedis
Hi, you can try the same with the method UFS memory using the UART cable for the FRP bypass with z3x, since you had posted the PDA firmware that you installed IE this: Build version: NRD90M. G925FXXU5EQI6
Software version: G925FXXU5EQI6 is a binary 5: G925FXXU5
Unless you did the flash of another firmware with binary 6
Have you solved with the 3GB memory bringing it back to 32 GB and bypassing the FRP on the phone
Page generated in 0.15490 seconds with 8 queries
