Samsung c3312 sim lock 100% done by z3x naieem rajpoot SAMSUNG C3312 SIM LOCK 100% DONE BY Z3X http://img213.imageshack.us/img213/5967/z3xn.jpg DEAR SAMSUNG GT-C3312 WITHOUT SIM CARD TRY THIS CODE #0141*842587# SIM LOCK PROBLEM SOLVE BY NAIEEM RAJPOOT |
without batt or with batt pls tell me bra .........r |
First U Need To Full Flash Ur Mobile Phone Select Flash Files Click On Firmware Than Insert Micro USB Cable To Phone After Full Flash Power On Ur Mobile Completely Remove And Insert Cable Again It Will take Driver Click On Direct Unlock Your Sim lock Will Be Removed B.R., Prem_India |
1, download flash files C3312DXLD1_OLALD1 2,insert the files correctly 3,press firmware button on z3x 4, connect phone pressing volume down key with usb cable 4, wait for flash complete attension please after flash,,, if set is dead ,,, do this job 1,press firmware button 2,connect phone pressing volume down key with usb cable without battery 3,wait for flashing after full flash connect phnoe with usb cable to other ports on your computer connecting time phone must be on check the com port window on z3x and select the port where you connect the phone select it then press the direct unlock on z3x phone must unlock now BR, TEJARAM |
Selected model: C3312 Selected com port: COM22 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM48) Phone SN: RZ1C6155V9 Deactivate MSL - OK Read - fail Unlock - ok Elapsed time: 72 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- |
First U Need To Full Flash Ur Mobile Phone Select Flash Files Click On Firmware Than Insert Micro USB Cable To Phone After Full Flash Power On Ur Mobile Completely Remove And Insert Cable Again It Will take Driver Click On Direct Unlock Your Sim lock Will Be Removed B.R., Prem_India Selected model: C3312 Selected com port: COM22 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM48) Phone SN: RZ1C6155V9 Deactivate MSL - OK Read - fail Unlock - ok Elapsed time: 72 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- |
Did U Flash UR Mobile First ??? After Full Flash Power On UR Mobile Connect USB Cable W8 For Take Driver Click On Direct Unlock W8 Till Operation Done If Any Error Remove/Insert USB Cable Click Again On Direct Unlock 100% Done |
unlock not +919898373779 |
Samsung c3312 sim lock 100% done by z3x - Alex chairman Selected model: C3312 Selected com port: COM19 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Erasing ... OK Sending...C3312RXXMB4_psi.fls (psi.fls) Writing ... OK Sending...C3312RXXMB4_slb.fls (slb.fls) Writing ... OK Sending...C3312RXXMB4_BSY.fls (CATFISH.fls) Writing ... OK Writing ... OK Sending...C3312RXXMB4_CDS.fls (CATFISH.fls) Writing ... OK Sending...C3312ROXEMB4_CSC.dffs (temp_GT-C3312_OXE.dffs) Writing ... OK Flash FLS - ok Elapsed time: 168 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- Direct unlock Selected model: C3312 Selected com port: COM26 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM27) Phone SN: RZ1C331FMD Deactivate MSL - OK Unlock - ok Elapsed time: 53 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- Read Codes Selected model: C3312 Selected com port: COM26 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM27) Phone SN: RZ1C331FMD Deactivate MSL - OK Calculated code please wait... Decrypted time: 4 sec This is zone 0 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*00000000# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*00000000# this is Master(freeze) code Read info - ok Elapsed time: 15 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- |
Selected model: C3312 Selected com port: COM65 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK it stuck after this what to do |
hi after hours of research .i am finally enlightened. i need z3x box which i do not have money to buy .. so please anyone who has or knows a SIM UNLOCK CODE for my samsung GT-C3312. (IMEI: 3521 11/05/499346/3 & IMEI: 3521 12/05/499346/1 ) .. please PM me ..thank you for your kindness |
not done call me - +919913453607 |
Selected model: C3312 Selected com port: COM8 Selected speed port: 921600 Attention !!! Use this operation after flashing phone Search diag port... OK (COM70) Phone SN: RV1C23V0WQ Deactivate MSL - OK Unlock - ok Elapsed time: 25 second, sw ver: 3.5.0040 sir mobile phone must b on Direct unlock than plz plug the usb and done |
thanks its working.... well ... |
