Old 11-03-2018, 13:55   #286 (permalink)
Member: 2728296
Sonork: kushbeka1234
Thanks Meter: 31
J810f
https://drive.google.com/open?id=1d2...r8s1MtVtqHO3V3
Old 11-04-2018, 18:06   #287 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,273
Originally Posted by Creatos View Post
Is their a combination file for SM-T380 Running android 8.0?trying to do frp removal or can anyone help with this frp removal?
https://shell.boxwares.com/Download.aspx?L=4953
U1 combination
Old 11-05-2018, 13:32   #288 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 261
j530f rev3 combination
I need j530f rev3 (u3) firmware 5 files for frp bypass ; i have this combination: https://drive.google.com/uc?id=1hhRh...xport=download
thanks in advance
Old 11-05-2018, 13:40   #289 (permalink)
Member: 1941705
Thanks Meter: 1,248
COMBINATION_FAC_FA70_J530FXXU3ARI1
The Following 3 Users Say Thank You to Xaker2012 For This Useful Post:
Old 11-06-2018, 05:06   #290 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 204
here:
****************************/file/czhwf...0FXWU3BRI1.rar
The Following 2 Users Say Thank You to jamohaki For This Useful Post:
Old 11-06-2018, 15:53   #291 (permalink)
lolo24's Avatar
Member: 2572618
Sonork: no
Thanks Meter: 185
Hello...
Here is combi for u.
https://androidfilehost.com/?fid=11410932744536991839
The Following 3 Users Say Thank You to lolo24 For This Useful Post:
Old 11-07-2018, 17:51   #292 (permalink)
Member: 2613252
Thanks Meter: 1,837
combination binary 8 for the model SM-G935 compatible for these models of SM-G935
For this combination binary 8 SM-G935 these models are compatible
Combination Model : G935P , G935A , G935V(x) , G935T , G935U, G935T1
COMBINATION_ATT_FA60_G935AUCU8ARJ2.rar
Link download:
https://drive.google.com/file/d/152A...FLC3ysb0B/view
Old 11-19-2018, 01:20   #293 (permalink)
yonic69's Avatar
Member: 2590666
Thanks Meter: 130
Combination COMBINATION_FA60_G935FXXU3ARI2_CL7964511_QB1963552 1_REV00_user_mid_noship.
Note: File provided by Amleto90.
How to unlock:
1. flash modem file from combination. and perform unlock.
2. To unlock OLD security type:
1. Power on the phone.
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press "Unlock" button and select "Unlock" for direct unlock.
To read security codes (all security types):
4. Press "Read codes" button to read security codes.
To read security codes via diagnostic port:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't use this function.
2. Type *#0808# and select "DM+MODEM+ADB".
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Press "Read Codes DIAG" button to read security codes.
To read security codes using sever:
Knox warranty does not matter.
2. Tap 7 times on "Build number" in "Settings"-"About phone" to enable "Developer options",
go to "Settings"-"Developer options" and enable "USB debugging".
4. Select device in ADB settings.
5. Press "Read Codes via server" button, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings.)
Old 11-19-2018, 18:46   #294 (permalink)
Member: 2613252
Thanks Meter: 1,837
Originally Posted by alexid View Post
need combnation n930f u3
Hello, here you can find the combinartion for n930f binary 3, be careful to install the combination that is compatible with the firmware of the phone and firmware security patches otherwise risk damaging it
COMBINATION_FA60_N930FXXU3APL1_CL9419305_QB1183520 4_REV00_user_mid_noship.zip
Download:
https://androidfilehost.com/?fid=818070582850510068
The Following User Says Thank You to amleto90 For This Useful Post:
Old 11-19-2018, 22:56   #295 (permalink)
Member: 63646
Sonork: 1670920:45069
Thanks Meter: 23
SM-T580 7.0 bin3 comb file ?
I have a SM-T580 with FRP ON. firmware is 7.0 bin 3 there is no comb.file on support . is it possible to unlock frp , downgrade is not possible.
Old 11-19-2018, 23:17   #296 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,439
don't waste your time
always use the latest combination and the latest firmware
grab b4 from the support and use the utility samfirm.exe for the firmware T580XXU4CRJ9 (SM-T580,DBT)
Old 11-23-2018, 18:21   #297 (permalink)
Member: 2613252
Thanks Meter: 1,837
Originally Posted by ajaycuteboy View Post
N935K U3 binary combination file needed
Thank You
hello, here you can find the link to download the combination n935k binary 3 this combination is compatible with the models g935s-n935k-n935L binary 3
COMBINATION_FA60_N935SKLU3AQG2_CL11670943_QB141636 75_user_mid_noshipN935S U3 Combination FileN935k U3 Combination FileN935L U3
Link Download:
COMBINATION FA60 N935SKLU3AQG2 QB14163675 rar - 4file.net
Old 11-23-2018, 18:24   #298 (permalink)
Member: 2613252
Thanks Meter: 1,837
Thank You
Sorry I rewritten the post because I was not the link to access to download the combination, here you can find the link to download the combination n935k binary 3 this combination is compatible with the models g935s-n935k-n935L binary 3
Link Download:
Download [up Gsmhungvu com] COMBINATION FA60 N935SKLU3AQG2 QB14163675 rar
Old 11-24-2018, 17:46   #299 (permalink)
paulbs's Avatar
Member: 74719
Sonork: paulelectro
Thanks Meter: 181
Originally Posted by amleto90 View Post
combination binary 8 for the model sm-g935 compatible for these models of sm-g935
for this combination binary 8 sm-g935 these models are compatible
combination model : G935p , g935a , g935v(x) , g935t , g935u, g935t1
combination_att_fa60_g935aucu8arj2.rar
link download:
https://drive.google.com/file/d/152a...flc3ysb0b/view
allwais error download file...please new upload
Old 11-24-2018, 18:13   #300 (permalink)
Member: 2613252
Thanks Meter: 1,837
Hello, new download combination binary 8 for the model SM-G935 compatible for these models of SM-G935
Link download:
https://mega.nz/#!ExslUSqR!6xX3UGTDs...5gMiZm3Rc3OI8M
Password archive rar: windows4droid95
LGQ UMTS Tool Update! v1.0.3 andrew_tm Z3X-Team Products 1 09-15-2010 11:33
Z3X LG Qualcomm Tool 1.1.6 & LG AD Tool 1.0.1 blang Service Products News & Updates 0 08-23-2008 19:34
New update from Z3X team LGQ UMTS Tool Update! v1.1.0 blang Z3X-Team Products 4 04-21-2008 15:27
LGQ UMTS Tool Update! v1.0.4 blang Z3X-Team Products 5 04-16-2008 20:51
LGQ UMTS Tool Update! v1.0.1 andrew_tm Z3X-Team Products 7 03-02-2008 14:30
Page generated in 0.23252 seconds with 10 queries
