07-11-2013, 13:44 | #1 (permalink) |
No Life Poster Join Date: Sep 2010 Location: romania
Member: 1390461 Status: Offline Thanks Meter: 80 | galaxy s4 i9505 unlock fail Selected port: COM52 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Reading phone info... fail Done with Samsung Tool v.14.4 Done with Samsung Tool v.14.4 i mention that when i type *#7284# menu does not appear and i cannot activate modem option |
07-11-2013, 19:15 | #4 (permalink) |
Member: 1390461 Status: Offline Thanks Meter: 80 | SOLVED!!!! Selected model: I9505 Selected port: COM52 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Searching server... OK NET lock: #7465625*638*05927193# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool v.14.4 Done with Samsung Tool v.14.4 FLASHED WITH EARLY VERSION OF 4.2.2 AND ALL GOOD NOW! |
07-13-2013, 16:31 | #9 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 969318 Status: Offline Thanks Meter: 82 | How to: - Cable UART C3300K - Select com port box in ST software - Press *#7284# and select "Modem" (Only show one option interface "UART") *default setting: "PDA" - Press *#9090# and select "4 - DM over UART" *default setting: "DM/DUN over HS-USB" - Press "Unlock" |
The Following User Says Thank You to big_gsm For This Useful Post: |
07-13-2013, 19:12 | #10 (permalink) | |
Member: 1390461 Status: Offline Thanks Meter: 80 | Quote:
09-28-2013, 15:03 | #11 (permalink) |
Freak Poster Join Date: Jan 2013 Location: spain
Member: 1867931 Status: Offline Sonork: 100.1625521 Thanks Meter: 36 | How to: - Cable UART C3300K - Select com port box in ST software - Press *#7284# and select "Modem" if problem in*#7284# you flash and then try (Only show one option interface "UART") *default setting: "PDA" - Press *#9090# and select "4 - DM over UART" *default setting: "DM/DUN over HS-USB" - Press "Unlock Selected model: I9505 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.15.5 |
