samsung e1310s unlock error the user code was successfully restored to 00000000 but when i enter the code in mobile phone it is showing password error i flashed that phone also |
good luck |
tried that also man i have many handsets also posted the logs this is the first handset i am getting this error |
here is the log Selected model: E1310S Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK NAND format - ок Start NOR flash NOR flash - ok Start Flash TFS Download - ok Elapsed time: 780 second, sw ver: 3.4.0033 ------------------------------------------------------------------------------- Selected model: E1310S Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 3520880******* Phone SW: E1310SDDIC4 Phone BT ADDR: 0000-00-000000 Phone SN: RPJS******* Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 14 second, sw ver: 3.4.0033 ------------------------------------------------------------------------------- Selected model: E1310S Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 3520880******* Phone SW: E1310SDDIC4 Phone BT ADDR: 0000-00-000000 Phone SN: RPJS7***** Deactivated MSL - TRUE [FREZEE]: 00000000 [NET Lock]: 00000000 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00000000 Read info - ok Elapsed time: 11 second, sw ver: 3.4.0033 ------------------------------------------------------------------------------- Selected model: E1310S Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35208803******* Phone SW: E1310SDDIC4 Phone BT ADDR: 0000-00-000000 Phone SN: RPJS7***** Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 12 second, sw ver: 3.4.0033 |
if phone locked after unlock - may be branded fw. |
how to debrand firmware |
problem solved it was not in firmware just ticked the flash mode from tat mode it was done thank u all for ur replies |
yes.thank you. reset phone and after read code nspro e1310m.new code. |
