Old 05-11-2012, 04:47   #1 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 502
Arrow samsung E2222 Blinking Solution 100% Tested
Samsung E2222 Blinking Solution
Download firmware from support area E2222XEKD4. Press 5+8 button and Insert usb cable install driver if require. Then Write E2222XEKD4 firmware. After This all done.
Driver http://www.ziddu.com/download/19359976/E2222Driver.rar
Uploaded with ImageShack.us
The Following User Says Thank You to sr8787 For This Useful Post:
Old 07-11-2012, 07:54   #2 (permalink)
33872's Avatar
Member: 442421
Thanks Meter: 68
Question
i used same process not solve same problem any other solution
Old 08-06-2012, 08:26   #3 (permalink)
Member: 589712
Thanks Meter: 82
if not solve the problem is you.
Old 08-06-2012, 08:33   #4 (permalink)
Member: 1707621
Sonork: 1602735
Thanks Meter: 41
Try This bro Insert Battery and Press Q+W buttons and Insert USB cable.
Old 10-22-2012, 13:07   #5 (permalink)
Member: 1670311
Sonork: 431001
Thanks Meter: 6
Selected model: E2222
Selected com port: COM6
Selected speed port: 921600
Press "volume down" + "lock" and connect USB cable to phone
Connect to control pipe... OK
Processor ID -> 0A34
Sending loader... OK
Connect to write pipe... OK
Connect to read pipe... OK
Sending part LCDACT:
Erasing... OK
Sending... OK
Sending part MAIN:
Erasing... OK
Sending... OK
Sending part DSP:
Erasing... OK
Sending... OK
Sending part ROOT:
Erasing... OK
Sending... OK
Sending boot sector:
Erasing... OK
Sending... OK
Sending TFS... OK
Sending CSC... OK
Download - ok
Elapsed time: 311 second, sw ver: 3.5.0040
flashed successfully bt problem nt solve
Old 11-09-2012, 14:46   #6 (permalink)
Member: 1533554
Thanks Meter: 7
Talk sence guyz tried everything nothing solved
Old 11-20-2012, 12:15   #7 (permalink)
Member: 774169
Thanks Meter: 123
i too tried but not solved
Old 11-21-2012, 18:13   #8 (permalink)
Member: 1416270
Thanks Meter: 9
z3x cannot flash this phone. is not true the procedure given out.
infact z3x need to wake up b4 is too late...... i try all tricks but still not successful.
what is happening z3x.
Old 11-21-2012, 19:04   #9 (permalink)
Member: 1416270
Thanks Meter: 9
Selected com port: COM199
Selected speed port: 115200
Connect to control pipe... FAIL
Send loaders - fail
Elapsed time: 32 second, sw ver: 3.5.0040
Old 11-29-2012, 11:11   #10 (permalink)
Member: 1006045
Thanks Meter: 13
Send loaders - fail
use sw ver: 3.5.0035
Old 03-25-2013, 09:29   #11 (permalink)
iceman_27's Avatar
Member: 754225
Thanks Meter: 145
not working.....still the same problem...
but wen i used this software....(Flash loader 7.4.7 SSG vo.1)Problem solved!
DOWNLOAD HERE:
FREE SOFTWARE
FLASHFILE HERE
br
Old 04-04-2013, 11:48   #12 (permalink)
Member: 1753166
Sonork: 100.1626196
Thanks Meter: 22
i have flashed with this file not ok
http://img842.imageshack.us/img842/9...msunge2222.png
Old 05-08-2013, 10:36   #13 (permalink)
Member: 1930679
Sonork: 123456789
help m please maybe my problem is tha usb cord
Old 08-08-2013, 19:03   #14 (permalink)
Member: 1164699
Thanks Meter: 62
YES, this is a chalenge to solve when z3x fails. We must try through many way. I am giving the result later.
Old 08-08-2013, 19:06   #15 (permalink)
Member: 1164699
Thanks Meter: 62
DOWNLOAD HERE:
FREE SOFTWARE
FLASHFILE HERE
br
Thanks to you. I have success by your direction.
It is flashed by the file E2222XXKF1_OXAKF1. Must use flashloader 7.4.7 ssg v0.1 lite. Force A+S.
The Following User Says Thank You to cdas For This Useful Post:
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
Pic Solution jan Nokia Hardware & Hardware Repair 8 10-11-2010 10:56
100% unlock1 for Nokia 6150 v5.17 ------,......... cIVIc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-10-1999 02:00
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! spterminator Main Sales Section 2 08-13-1999 05:55
Page generated in 0.30392 seconds with 10 queries
