11-03-2011, 21:06 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: kanpur Age: 35
Member: 1033905 Status: Offline Sonork: amitsharma Thanks Meter: 892 | samsung A887 at$t not unlock z3x??? here logs..... Count supported models - 223 ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 ----------------------------- No answer from phone Error read info Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- Model: SGH-A887 CountryCode: ATT Factory SW: UCIFA UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S IMEI: 00000000000000/0 Phone S/N: 0000000000 Build: SBAM6290A-KPVZL-1.2.0075_3S Done with Samsung 3G tool ver 9.4 ----------------------------- Model: SGH-A887 CountryCode: ATT Factory SW: UCIFA UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S IMEI: 00000000000000/0 Phone S/N: 0000000000 Build: SBAM6290A-KPVZL-1.2.0075_3S Reading SysInfo... OK Calculating... error Searching SysInfo... OK Reading SysInfo... error! (Insert SIM or type *#7465625#) Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- Model: SGH-A887 CountryCode: ATT Factory SW: UCIFA UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S IMEI: 00000000000000/0 Phone S/N: 0000000000 Build: SBAM6290A-KPVZL-1.2.0075_3S Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- Select COM port Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- Model: SGH-A887 CountryCode: ATT Factory SW: UCIFA UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S IMEI: 00000000000000/0 Phone S/N: 0000000000 Build: SBAM6290A-KPVZL-1.2.0075_3S Done with Samsung 3G tool ver 9.4 ----------------------------- Model: SGH-A887 CountryCode: ATT Factory SW: UCIFA UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S IMEI: 00000000000000/0 Phone S/N: 0000000000 Build: SBAM6290A-KPVZL-1.2.0075_3S Reading SysInfo... OK Calculating... error Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:58) Freeze code: 75186384 NET lock: #7465625*638*97941717# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- Model: SGH-A887 CountryCode: ATT Factory SW: UCIFA UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S IMEI: 00000000000000/0 Phone S/N: 0000000000 Build: SBAM6290A-KPVZL-1.2.0075_3S Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 ----------------------------- No answer from phone Error read info Done with Samsung 3G tool ver 9.4 ----------------------------- No answer from phone Error read info Done with Samsung 3G tool ver 9.4 ----------------------------- No answer from phone Error read info Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- Enable to open COM75 Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... detected (COM78) Model: SGH-A887 SW: A887UCIJ1 IMEI: not readable Done with Samsung 3G tool ver 9.4 ----------------------------- No answer from phone Error read info Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... detected (COM78) Model: SGH-A887 SW: A887UCIJ1 IMEI: not readable Done with Samsung 3G tool ver 9.4 ----------------------------- No answer from phone Error read info Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... detected (COM78) Model: SGH-A887 SW: A887UCIJ1 IMEI: not readable Done with Samsung 3G tool ver 9.4 ----------------------------- Model: SGH-A887 CountryCode: ATT Factory SW: UCIFA UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S IMEI: 00000000000000/0 Phone S/N: 0000000000 Build: SBAM6290A-KPVZL-1.2.0075_3S Reading SysInfo... OK Calculating... error Searching SysInfo... OK Reading SysInfo... error! (Insert SIM or type *#7465625#) Done with Samsung 3G tool ver 9.4 ----------------------------- Model: SGH-A887 CountryCode: ATT Factory SW: UCIFA UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S IMEI: 00000000000000/0 Phone S/N: 0000000000 Build: SBAM6290A-KPVZL-1.2.0075_3S Reading SysInfo... OK Calculating... error Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:52) Freeze code: 75186384 NET lock: #7465625*638*97941717# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 ----------------------------- No answer from phone Error read info Done with Samsung 3G tool ver 9.4 ----------------------------- No answer from phone Error read info Done with Samsung 3G tool ver 9.4 ----------------------------- Model: SGH-A887 CountryCode: ATT Factory SW: UCIFA UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S IMEI: 00000000000000/0 Phone S/N: 0000000000 Build: SBAM6290A-KPVZL-1.2.0075_3S Reading SysInfo... OK Calculating... error Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:52) Freeze code: 75186384 NET lock: #7465625*638*97941717# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... detected (COM78) Model: SGH-A887 SW: A887UCIJ1 IMEI: not readable Done with Samsung 3G tool ver 9.4 Searching USB Device... detected (COM78) Reading Phone Info... OK Model: SGH-A887 Factory SW: UCIFA CountryCode: ATT UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S SW: A887UCIJ1 IMEI: not readable Reading SysInfo... OK Searching server... error (Maybe OLD Security) Change Mode to Qualcomm and Try Again Done with Samsung 3G tool ver 9.4 Searching USB Device... not found Done with Samsung 3G tool ver 9.4 Searching USB Device... detected (COM78) Reading Phone Info... OK Model: SGH-A887 Factory SW: UCIFA CountryCode: ATT UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S SW: A887UCIJ1 IMEI: not readable Reading SysInfo... OK Searching server... error (Maybe OLD Security) Change Mode to Qualcomm and Try Again Done with Samsung 3G tool ver 9.4 Searching USB Device... detected (COM78) Reading Phone Info... OK Model: SGH-A887 Factory SW: UCIFA CountryCode: ATT UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S SW: A887UCIJ1 IMEI: not readable Reading SysInfo... OK Searching server... error (Maybe OLD Security) Change Mode to Qualcomm and Try Again Done with Samsung 3G tool ver 9.4 ----------------------------- No answer from phone Error read info Done with Samsung 3G tool ver 9.4 ----------------------------- No answer from phone Error read info Done with Samsung 3G tool ver 9.4 ----------------------------- No answer from phone Error read info Done with Samsung 3G tool ver 9.4 ----------------------------- Model: SGH-A887 CountryCode: ATT Factory SW: UCIFA UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S IMEI: 00000000000000/0 Phone S/N: 0000000000 Build: SBAM6290A-KPVZL-1.2.0075_3S Reading SysInfo... OK Calculating... error Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:52) Freeze code: 75186384 NET lock: #7465625*638*97941717# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- Model: SGH-A887 CountryCode: ATT Factory SW: UCIFA UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S IMEI: 00000000000000/0 Phone S/N: 0000000000 Build: SBAM6290A-KPVZL-1.2.0075_3S Done with Samsung 3G tool ver 9.4 ----------------------------- Model: SGH-A887 CountryCode: ATT Factory SW: UCIFA UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S IMEI: 00000000000000/0 Phone S/N: 0000000000 Build: SBAM6290A-KPVZL-1.2.0075_3S Reading SysInfo... OK Calculating... error Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:53) Freeze code: 75186384 NET lock: #7465625*638*97941717# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- Model: SGH-A887 CountryCode: ATT Factory SW: UCIFA UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S IMEI: 00000000000000/0 Phone S/N: 0000000000 Build: SBAM6290A-KPVZL-1.2.0075_3S Done with Samsung 3G tool ver 9.4 ----------------------------- Model: SGH-A887 CountryCode: ATT Factory SW: UCIFA UniqueNumber: 80080000443494 MemoryPhone: K5R2G1GACC(A887)S IMEI: 00000000000000/0 Phone S/N: 0000000000 Build: SBAM6290A-KPVZL-1.2.0075_3S Reading SysInfo... OK Calculating... error Searching SysInfo... OK Reading SysInfo... OK Calculating codes... OK (time - 00:00:52) Freeze code: 75186384 NET lock: #7465625*638*97941717# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 phone is network unlock..i try net unlock phone say failed... read info. in z3x not show imei and SN number.... i will try also qualcomm mode but not sucess....???? how 2 unlock its urgent |
12-29-2012, 16:09 | #2 (permalink) |
Freak Poster Join Date: Nov 2007 Location: THE GREAT INDIA
Member: 622862 Status: Offline Thanks Meter: 52 | Selected model: A887 Selected port: COM15 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... OK Model: SGH-A887 Country code: ¹Ì±¹/ATT Cal date: 2009-11-16 Factory SW: UCIJ1 Unique number: 80900000533082 Memory phone: K5R2G1GACC(A887)S Phone S/N: RVYZ182038 Reading IMEI... OK IMEI: xxxxxxxxxxxxxxxx Build: SBAM6290A-KPVZL-1.2.0075_3S Reading phone version... OK Phone version: A887UCIJ1 Searching sysinfo... OK Reading sysinfo... OK Please wait, calculating codes... OK (time - 00:02:25) Freeze code: 75204048 NET lock: #7465625*638*62682424# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# Done with Samsung Tool v.13.7 |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
