09-19-2017, 22:46 | #2056 (permalink) | |
Junior Member Join Date: Sep 2017
Member: 2759457 Status: Offline Thanks Meter: 0 | Quote:
there is 8 files to download in firmware how to make difference who is the file for ech icon... | |
09-24-2017, 21:11 | #2058 (permalink) |
Junior Member Join Date: Aug 2013 Location: london
Member: 1994699 Status: Offline Thanks Meter: 6 | please upload new combination file for s8 plus G955N because the combination downloaded from z3x tool pro is corrupted and says WRONG TAR when flashing combination for G955N. |
09-26-2017, 12:33 | #2061 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: GT-I9515 Software version: 29.3.1 File analysis... OK Total file size: 0xF46746C0 (3910 Mb) Searching USB Flash interface... COM69 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending cache.img... OK Flashing done (time - 00:03:33) Done with Samsung Tool PRO v.29.3.1 |
09-26-2017, 12:53 | #2062 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: GT-I9515 Software version: 29.3.1 File analysis... OK Total file size: 0xA471F3E8 (2631 Mb) Searching USB Flash interface... COM38 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending sbl2.mbn... OK Sending sbl3.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending boot.img... OK Sending recovery.img... OK Sending persdata.img.ext4... OK Sending system.img.ext4... OK Sending modem.bin... OK Sending NON-HLOS.bin... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... OK Flashing done (time - 00:09:05) Done with Samsung Tool PRO v.29.3.1 |
09-27-2017, 09:34 | #2063 (permalink) | |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | Quote:
Write a post for mistaks some users at now thats rulles about write full flash name I see u lose ur mind at now Thanx for hard work mr.blang Sent from my SM-N910C using Tapatalk | |
09-27-2017, 14:46 | #2064 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J500FN Software version: 29.3.1 File analysis... OK Total file size: 0x717D52B0 (1815 Mb) Searching USB Flash interface... COM38 detected Setup connection... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending hyp.mbn... OK Sending NON-HLOS.bin... OK Sending sec.dat... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... OK Flashing done (time - 00:03:37) Done with Samsung Tool PRO v.29.3.1 |
10-13-2017, 16:08 | #2070 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. If you have one file firmware, then you must check 'Use one package file' option. 4. Check flashing options if needed (Repartition, EFS clear, Boot update). 5. Power on the phone in download mode (turn off phone, hold Volume Down + Home + Power). 6. Connect the phone to PC with USB cable, install drivers if needed. 7. Press 'Flash' button. Operation: Flash Selected model: GT-S5830I Software version: 29.5 File analysis... OK Total file size: 0xBE1751A4 (3041 Mb) Searching USB Flash interface... COM204 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending preloader.img... OK Sending lk.bin... OK Sending param.bin... OK Sending trustzone.bin... OK Sending efuse.img... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending secro.img... OK Sending userdata.img... OK Sending md1rom.img... OK Sending md1dsp.img... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:02:35) Done with Samsung Tool PRO v.29.5 |
LG Flash Files Requests are here: | NoName® | Z3X-Team Products | 540 | 06-14-2021 13:30 |
Full Flash Files, Here are some links, add more if you can | simbirley | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 13 | 07-16-2013 08:33 |
Samsung A877, Flasher and flash files request??? | jham | Samsung Flashers, Software, Firmware. | 3 | 05-09-2011 13:13 |
All member request plz post here all Huawei flash file request | mohit_kripalu01 | Various CDMA/TDMA Cell Phones | 0 | 10-06-2009 14:38 |
