10-02-2020, 09:00 | #1 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Poland
Member: 388491 Status: Offline Thanks Meter: 1 | Samsung G530, ISP, Critical error: Integer overflow ============================== 23.06.2020 (ver 1.6.3.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 MHz CMD Pullup Level: 1846 mV CMD Active Level: 2143 mV EMMC Device Information : EMMC CID: FE014E50314A39354B13007416EC3297 EMMC CSD: D06E01320F5913FFFFFFFFEF92400071 EMMC Manufacture : MICRON , EMMC NAME: P1J95K , HEX: 50314A39354B , S/N: 007416EC , rev. 0x13 EMMC Manufacture ID: 0xFE , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 3/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Counter: 33 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: P1J95K_007416EC_20200909_175900.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: apnhlos, [000000400000 - 000001300000], size: 000000F00000 (15,0 MB) Partition: modem, [000001300000 - 000004C70000], size: 000003970000 (57,4 MB) Partition: sbl1, [000004C70000 - 000004CF0000], size: 000000080000 (512 KB) Partition: ddr, [000004CF0000 - 000004CF8000], size: 000000008000 (32,0 KB) Partition: aboot, [000004CF8000 - 000004EF8000], size: 000000200000 (2,00 MB) Partition: rpm, [000004EF8000 - 000004F78000], size: 000000080000 (512 KB) Partition: qsee, [000004F78000 - 000004FF8000], size: 000000080000 (512 KB) Partition: qhee, [000004FF8000 - 000005078000], size: 000000080000 (512 KB) Partition: fsg, [000005078000 - 000005378000], size: 000000300000 (3,00 MB) Partition: sec, [000005378000 - 00000537C000], size: 000000004000 (16,0 KB) Partition: pad, [00000537C000 - 000005E00000], size: 000000A84000 (10,5 MB) Partition: param, [000005E00000 - 000006800000], size: 000000A00000 (10,0 MB) Partition: efs, [000006800000 - 000007600000], size: 000000E00000 (14,0 MB) Partition: modemst1, [000007600000 - 000007900000], size: 000000300000 (3,00 MB) Partition: modemst2, [000007900000 - 000007C00000], size: 000000300000 (3,00 MB) Partition: boot, [000007C00000 - 000008900000], size: 000000D00000 (13,0 MB) Partition: recovery, [000008900000 - 000009800000], size: 000000F00000 (15,0 MB) Partition: fota, [000009800000 - 000009D00400], size: 000000500400 (5,00 MB) Partition: backup, [000009D00400 - 00000A3FE000], size: 0000006FDC00 (6,99 MB) Partition: fsc, [00000A3FE000 - 00000A6FE000], size: 000000300000 (3,00 MB) Partition: ssd, [00000A6FE000 - 00000A700000], size: 000000002000 (8,00 KB) Partition: persist, [00000A700000 - 00000AF00000], size: 000000800000 (8,00 MB) Partition: persdata, [00000AF00000 - 00000B800000], size: 000000900000 (9,00 MB) Partition: system, [00000B800000 - 000069000000], size: 00005D800000 (1,46 GB) Partition: cache, [000069000000 - 00007BC00000], size: 000012C00000 (300 MB) Partition: hidden, [00007BC00000 - 000082000000], size: 000006400000 (100 MB) Partition: userdata, [000082000000 - 0001D1FFB000], size: 00014FFFB000 (5,25 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = grandprimelte Model = SM-G530FZ Phone platform = msm8916 CPU Abi = armeabi-v7a Android release = 5.0.2 Security Patch = 2017-03-01 Firmware version = LRX22G.G530FZXXS1BQC2 Firmware date = Mon Mar 20 13:40:57 KST 2017 Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 MHz CMD Pullup Level: 1846 mV CMD Active Level: 2143 mV EMMC Device Information : EMMC CID: FE014E50314A39354B13007416EC3297 EMMC CSD: D06E01320F5913FFFFFFFFEF92400071 EMMC Manufacture : MICRON , EMMC NAME: P1J95K , HEX: 50314A39354B , S/N: 007416EC , rev. 0x13 EMMC Manufacture ID: 0xFE , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 3/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Counter: 33 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: P1J95K_007416EC_20200909_175912.extcsd EMMC Init completed. Operation: File Explorer... Scan from: P1J95K Vendor: Qualcomm Searching GPT ... GPT header is found and is valid GPT header successfully parsed Scan done Mount [apnhlos] successfully PartType: FAT16 Mount [modem] successfully PartType: FAT16 Mount [persdata] successfully PartType: LINUX Mount [system] successfully PartType: LINUX Mount [cache] successfully PartType: LINUX Mount [preload] successfully PartType: LINUX Mount [data] successfully PartType: LINUX Critical error: Integer overflow. |
