Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,486 ![]() | Samsung g955u s8 plus unlock done UNLOCK INSTRUCCIONES: Unlocking with original MSL code: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G955U Software version: 28.5 Checking Login and Password... Listo Balance: 45 crd. Waiting ADB device... Por favor, permite la depuración USB en el teléfono... Listo Leyendo información del teléfono ... Modelo: SM-G955U Android version: 7.0 Código del Producto: SM-G955UZVACCT Versión del telefono: G955USQU1AQDE PDA version: G955USQU1AQDE CSC version: G955UOYN1AQDE Código de país CSC: USA Código de Venta CSC: CCT HW version: REV1.0 Phone SN: R28J526ESZB Chip name: MSM8998 Módem: MSM8998 Security patch: 2017-04-01 RF cal date: 2017.05.18 IMEI: Reiniciando teléfono ... Listo Waiting ADB device... Listo Reiniciando teléfono ... Listo Waiting ADB device... Listo Initialization zTool... Listo Running zTool, please wait... Start... Listo Initialization... Listo Generate and check client proof... Listo Verify proof by client... Listo Lectura de datos desde el teléfono ... Listo Searching Ramdump interface... COM241 detected Lectura de datos desde el teléfono ... Listo Calculando... Listo Buscando servidor... Listo Waiting for server answer... Listo Congelar código: 85848370 NET lock: 59306296 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 Para comprobar bloquea el estado: *#7465625# Done with Samsung Tool PRO v.28.5 |
The Following 5 Users Say Thank You to maxpatri9 For This Useful Post: |
![]() | #6 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2014
Member: 2228428 Status: Offline Thanks Meter: 49 | Quote:
![]() | #9 (permalink) |
Major Poster ![]() ![]() Join Date: Dec 2013
Member: 2092415 Status: Offline Thanks Meter: 12 | Hello, I just unlocked a couple of this models days ago, but after unlock, during the using, the screen "UPLOAD MODE..." appears suddenly, I did a reset and the issue disappeared apparently, but yesterday happened again... Do you know what is happening?... Maybe if I flash it with the original firmware can be fixed it... I haven't found the link for this firmware, someone knows where to download it?... Thanks in advance! |
![]() | #10 (permalink) | |
Member: 2382052 Status: Offline Thanks Meter: 1,486 ![]() | Quote:
Sent from my LGLS775 using Tapatalk | |
![]() | #14 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,486 ![]() | https://www.androidfilehost.com/?w=search&s=G955U https://www.androidfilehost.com/?w=search&s=G950u Sent from my LGLS775 using Tapatalk |
