Samsung Galaxy A5 2016 SM-A510F EFS nv data cert read done BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Read certificate via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT DIAG' button to read certificates. Operation: Read CERT Selected model: SM-A510FD Software version: 34.8 Waiting ADB device... OK Reading phone info... Model: SM-A510F Android version: 6.0.1 PDA version: A510FXXU4BQC2 CSC version: A510FDOJP4BQC3 Phone version: A510FDXXU4BQC3 Product code: SM-A510FZDFXID CSC country code: UAE CSC sales code: XSG Phone SN: RR8HB0KH6ZT IMEI: 352625080549486 HW version: MP 0.000 RF cal date: 20161121 Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-03-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Incorrect model selected. This may damage your phone. Continue? Yes Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... OK Reading data... OK HWID: A1 79 28 41 5B F4 A1 E4 EE 15 68 60 29 37 AC 1B Calculating... OK Certificate file saved to D:\BST\SamsungToolPRO\backup\Cert\SM-A510F_352625080549486_352700080549487_9-3-2019_19-10-54.cert Done with Samsung Tool PRO v.34.8 efs nv data download here https://www.4shared.com/rar/Zq4sV4lH...nd_nv_da.html? |
