Samsung Galaxy S3 I8190 Unlock Problem Hi Team, Today I try To Unlock Samsung Galaxy S3 I8190 But Not Done Just Check Logs.......... Selected model: I8190 Selected port: COM13 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I8190 Android version: 4.1.1 Product code: GT-I8190MBAXSG Phone version: I8190XXALJL PDA version: I8190XXALJL CSC version: I8190OJVALJ9 IMEI: Unknown Checking Super user right... false Rooting phone, please wait... error Not supported android version 4.1.1 Done with Samsung Tool v.14.2 Done with Samsung Tool v.14.2 I Think Same Bugs In v.14.3 So Help Me How Can I Done ...........:rolleyes: Regards, |
reset phone then try to root and after unlock |
root it first then use z3x to unlock |
*#7284# (select Modem for both options) *#9090# (select USB Diag, then turn on USB Debugging Mode) Install all the USB Drivers then reboot device!! check this method via usb cable |
flash root file root 100% ok |
Root manual here - i8190 Root |
Hello Mr. blang.. Just Check My Logs & Where I M Wrong Please Clear This:- <ID:0/025> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> HOME_I8190XXAMB3_I8190OXAAMB3_ROOTED.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/025> Odin v.3 engine (ID:25).. <ID:0/025> File analysis.. <ID:0/025> SetupConnection.. <ID:0/025> Initialzation.. <ID:0/025> Get PIT for mapping.. <ID:0/025> Firmware update start.. <ID:0/025> boot.img <ID:0/025> NAND Write Start!! <ID:0/025> cache.img <ID:0/025> hidden.img <ID:0/025> modem.bin <ID:0/025> STE_boot1.img <ID:0/025> STE_boot2.img <ID:0/025> system.img <ID:0/025> RQT_CLOSE !! <ID:0/025> RES OK !! <ID:0/025> Completed.. <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/025> Removed!! =============================== After That With Z3x :- Selected model: I8190 Selected port: COM13 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I8190 Android version: 4.1.2 Product code: GT-I8190MBAXSG Phone version: I8190XXAMB3 PDA version: I8190XXAMB3 CSC version: I8190OXAAMB3 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Now connect phone to UART cable Checking phone at COM13 OK Bypass MSL... OK Unlocking... OK Unlock done Codes set to 00000000 Done with Samsung Tool v.14.3 Done with Samsung Tool v.14.3 But Still Same No Service So What U Think About This......:) Regards, |
======================================== <ID:0/025> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> recovery-clockwork-touch-6.0.2.7-golden.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/025> Odin v.3 engine (ID:25).. <ID:0/025> File analysis.. <ID:0/025> SetupConnection.. <ID:0/025> Initialzation.. <ID:0/025> Get PIT for mapping.. <ID:0/025> Firmware update start.. <ID:0/025> recovery.img <ID:0/025> NAND Write Start!! <ID:0/025> RQT_CLOSE !! <ID:0/025> RES OK !! <ID:0/025> Completed.. <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/025> Removed!! =========================== After That Z3x:- Selected model: I8190 Selected port: COM13 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I8190 Android version: 4.1.2 Product code: GT-I8190MBAXSG Phone version: I8190XXAMB3 PDA version: I8190XXAMB3 CSC version: I8190OXAAMB3 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Now connect phone to UART cable Checking phone at COM13 OK Bypass MSL... OK Unlocking... OK Unlock done Codes set to 00000000 Done with Samsung Tool v.14.3 Done with Samsung Tool v.14.3 Still Same Emergeny Call Only Then No Service:(:( Now How Can I Done...:( Regards, |
Selected model: I8190 Selected port: COM13 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I8190 Android version: 4.1.2 Product code: Unknown Phone version: Unknown PDA version: Unknown CSC version: Unknown IMEI: Unknown Checking Super user right... false Rooting phone, please wait... error Not supported android version 4.1.2 Done with Samsung Tool v.14.4 |
Sent from my GT-I9300 using Tapatalk 2 |
````````````````how to process``````````````` 1st root by VRoot_1.7.5.5379_Setup 2nt just unlock click z3x box and SamsungTool_15.5 Selected model: I8190 Selected port: COM13 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I8190 Android version: 4.1.2 Product code: GT-I8190MBAXSG Phone version: I8190XXAMB3 PDA version: I8190XXAMB3 CSC version: I8190OXAAMB3 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Now connect phone to UART cable Checking phone at COM13 OK Bypass MSL... OK Unlocking... OK Unlock done Codes set to 00000000 Done with Samsung Tool v.15.5 Done with Samsung Tool v.15.5 |
check imei in the phone, in the log says imei unknown |
I8190 csc unknown *1234= imei repair by pass msl error how to solve firmware write but not solve help me |
