07-09-2016, 07:46 | #2 (permalink) |
No Life Poster Join Date: Sep 2004 Location: coast Age: 52
Member: 83397 Status: Offline Thanks Meter: 204 | i have same problem trying write cert but get this berror massage anyway to fix this problem BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-G920F Software version: 25.5 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 5.0.2 Product code: Phone version: G920FXXU1AOCW PDA version: G920FXXU1AOCZ CSC version: G920FVFG1AOC4 CSC country code: UK CSC sales code: VOD HW version: Phone S/N: RF8G41DNS6W Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK Checking certificate file... OK KEY ID: 0346 Reading nv data... OK Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.25.5 |
