06-26-2015, 17:49 | #1 (permalink) |
Banned Join Date: May 2010
Member: 1300929 Status: Offline Thanks Meter: 0 | Problem Unlock SM-G900FD Android 5.0 i try unlock procedure but not detect Code: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. |
08-22-2015, 07:20 | #3 (permalink) |
Freak Poster Join Date: May 2009 Location: Bangladesh
Member: 1024699 Status: Offline Sonork: 100.1622959 Thanks Meter: 601 | Only Update ur handset using wifi (Setting-About-Software Update) After, Enable CP logging in Recovery Mode and select DM+MODEM+ADB then connect the phone directly to PC and check whether phone in being recognized correctly.Press Unlock... |
