Old 09-05-2016, 15:56   #16 (permalink)
Member: 75
Thanks Meter: 2
I have too this problem
Checking local file... Non trovato
Ricerca server... OK
File not found on server for this model
Eseguito con Samsung Tool PRO v.26.6
Old 09-05-2016, 22:19   #17 (permalink)
Member: 2185147
Thanks Meter: 2
I have this error every time some one can help?
Operation: Reset FRP/React/EE
Selected model: SM-G930F
Software version: 26.5
Checking local file... OK
Searching server... OK
Compare local and server file... OK (up to date)
Searching USB Flash Interface... detected COM7
Setup connection... OK
Reading data from phone... OK
Sending data to phone... OK
Waiting ADB device... time out
Phone not found
Done with Samsung Tool PRO v.26.5
Trying to reset frp but i get this !
Old 09-06-2016, 06:25   #18 (permalink)
Member: 1809822
Thanks Meter: 16
in my case it does download recovery pack but can't boot to it
Old 09-06-2016, 08:22   #19 (permalink)
Member: 75
Thanks Meter: 2
Some problem,phone not found after write ....
Old 09-06-2016, 08:25   #20 (permalink)
Member: 75
Thanks Meter: 2
UNLOCK ISTRUZIONI:
1. Power on the phone.
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
To reset Google account activation or Samsung reactivation lock:
1. Power on phone in download mode (turn off phone, press vol.down + home + power).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operazione: Reset FRP/React/EE
Modello selezionato: SM-G935F
Versione software: 26.6
Ricenrca Interfaccia USB... Trovato COM11
Impostazioni connessione... OK
Lettura dati da telefono... OK
Scrittura device ADB... tempo scaduto
Telefono non trovato
Old 11-05-2016, 15:26   #21 (permalink)
Member: 1845710
Sonork: MMM
Thanks Meter: 4
I have big problem. Please help me !!!
It is possible to remove frp from 935f with DRK problem ?? or fix drk with frp lock ?
Old 11-28-2016, 05:06   #22 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 502
same problem here
Old 11-28-2016, 12:32   #23 (permalink)
Member: 2423006
Same problem with G935F ,
I did try to remove FRP and / or DRK from the phone by Z3X per last 4 weeks but no look at all , why z3x have this option if it is not working at all .
I did flash combination firmware but it do nothing to help remove any FRP or DRK .
z3x is working perfect with the phones up to samsung s6 .
in 4 months samsung s8 will be out but I dont see how will it work if we are still not able to sort out s7 yet .
This is a big problem .
Old 12-30-2016, 13:07   #24 (permalink)
Member: 2349253
Thanks Meter: 5
Same problem with G930F, solutions?
Old 02-12-2017, 15:35   #25 (permalink)
Member: 2669283
Red face can't activate adb mode on G935w8 to reset FRP
hi,
i put my s7edge in download mode,i click on ResetFRP,its asking to put phone in ADB mode, i can't access to settings to activate it,of course because of FRPLock
any ideas how to activate ADB from this stage , i tried to flash combinations its very difficults to find one for my model,
more details:
s7edge SM-G935W8 (canada)
Z3X V27,7
no important data on phone
Old 02-16-2017, 12:40   #26 (permalink)
Member: 2209993
Thanks Meter: 5
i same problem, its not solutio
Old 02-16-2017, 13:49   #27 (permalink)
Member: 46489
Thanks Meter: 3
Phone not found
2 phone already written me this and it is not, then the phone died. Someone has found a solution.
Old 03-20-2017, 16:16   #28 (permalink)
Member: 10948
Thanks Meter: 14
Checking local file... Ok
Searching server... Ok
Searching USB Flash interface... COM40 detected
Setup connection... Ok
Reading data from phone... Ok
Sending data to phone... Ok
Waiting ADB device... timeout
Phone not found
Done with Samsung Tool PRO v.27.8
at the moment its stay on logo screen and cant get in download mode.
Old 03-20-2017, 22:23   #29 (permalink)
Member: 2562183
Sonork: Adnan
Thanks Meter: 2
Samsung s7 and s7edge can we remove frp directly with z3x..without flashing with adb file????
Old 03-21-2017, 07:05   #30 (permalink)
Member: 2697825
I am having the following issue on FRP remove for 935F via Z3X. Any ideas??? Thanks in advance.
Selected model: SM-G935V
Software version: 27.8
Searching USB Flash interface... COM5 detected
Setup connection... error
Page generated in 0.18296 seconds with 8 queries
