02-09-2018, 04:04 | #17 (permalink) |
No Life Poster Join Date: Dec 2006 Location: yes
Member: 420658 Status: Offline Thanks Meter: 211 | Okidoki... ODIN Protocol maybe easier... Seems require TCP Server... Upload protocol was TCP Client... First success... ODIN answer over WiFi with: LOKE Need some time to prepare files for sending few lines of HEX... So I hope I will manage this year... dumping PIT from Gear over Wifi... Best Regards |
The Following 3 Users Say Thank You to adfree For This Useful Post: |
02-11-2018, 01:24 | #18 (permalink) | |
Member: 420658 Status: Offline Thanks Meter: 211 | Mühseelig ernährt sich das Eichhörnchen... Its not so easy to find fully usable and easy to handle TCP Server Tool to fire up 25 Commands in a row... Tried few Android apps on my GT-I9300... but limitation is to use more then 1 Command with 1024 byte to send... in HEX... Similar problems with free available PC Windows Tools... On Screenshot is result visible... after sent Command 2 First Command is easy... in ASCII or HEX... ODIN or 4F44494E Second command seems to show ODIN Protocol Version... IMHO. Screenshot is valid for my both Wearables: SM-R732 and SM-R760 Code: 6400000000000300 And my old GT-I9300 shows lower "Protocol Version"... but Commands are same to dump PIT... Code: 6400000000000200 And creating stupid Batch file *.bat Maybe something like this work: https://stackoverflow.com/questions/...tcp-connection Quote:
Need some time for tests... Best Regards | |
02-11-2018, 04:30 | #19 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Untested! Status: Feuchter Traum Under Construction... Based on this Theory: https://stackoverflow.com/questions/...tcp-connection This is my idea how to dump PIT... partition.pit from Wearables over WiFi... instead USB cable. I will check my theory on my SM-R732 first... if nothing explode... Then my SM-R760... Now I have to fight with NetCat on my old Vista Notebook. Best Regards |
02-11-2018, 06:26 | #20 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Seems easier... with NetCat... Command looks like this: Code: nc -l -p 13579 < ODINcommand_full.bin > response_full.bin Best Regards |
The Following 2 Users Say Thank You to adfree For This Useful Post: |
02-11-2018, 07:28 | #21 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | First success to dump PIT partition.pit from Wearables over WiFi... Tested with my 2 devices: SM-R732 SM-R760 I see some red text on Screen... but at the moment I can ignore... Tested only with Combination Firmware... Own risk! NetCat I have taken from here: https://eternallybored.org/misc/netcat/ Tested on my old Windows Vista Notebook... with this Version: netcat-win32-1.12.zip I will check now if I can use Phone + Android App... to send these 25 KB... to receive 7 KB result... Best Regards |
The Following User Says Thank You to adfree For This Useful Post: |
02-13-2018, 03:54 | #22 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Stuck with Upload Commands... As I have no newer device to connect via USB and to sniff what is send... Download (Wireless) and Upload (Wireless) in rootfs.img Code: /usr/bin/wireless-download Code: wu_rdx_cmd_search_idx wu_rdx_cmd_powerdown wu_rdx_get_cmd_size wu_rdx_cmd_preamble wu_rdx_init wu_rdx_cmd_search_addr wu_rdx_cmd_data_transfer wu_rdx_generate_log wu_rdx_dump_info_init wu_rdx_add_dump_entry wu_rdx_handle_cmd wu_rdx_do_upload_file wu_rdx_send_cmd wu_rdx_cmd_probe wu_rdx_recv_ack Download "Commands" netODIN related: Code: wd_odin_send_ack wd_odin_handle_cmd wd_odin_get_cmd_size wd_odin_get_version wd_odin_cmd_pit wd_odin_cmd_xmit Attached are files from SM-R760... taken from different Firmware Versions... Best Regards |
02-15-2018, 02:35 | #23 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Please I need Tester for dump/read PIT partition.pit via WiFi. Thanx in advance. I have tested with my SM-R732 and my SM-R760... ... with Combination Firmware only On my old Notebook with 32 bit Windows Vista... Need help to confirm it work... on normal Stock Firmware... On Tizen 3 Firmware... I have attached netcat + Batchfile + Command Binary in 1 package... + Video Maybe somebody can test or have ideas how to improve netcat Batch... So I don't need to press ctrl + c Thanx in advance. Best Regards |
02-15-2018, 03:11 | #24 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Code: nc -l -w 5 -p 13579 < ODINcommand_full.bin > response_full.bin Added corrected Version... Best Regards |
03-10-2018, 03:38 | #26 (permalink) | |
Member: 420658 Status: Offline Thanks Meter: 211 | Quote:
Feel free to PM me. @all Meanwhile we have RL removed from few more devices. For instance: SM-R360 Gear Fit 2 = STEADY partition is on p15 SM-R730 series = STEADY partition is on p22 All possible if Combination Firmware is available... And simple with WiFi only... NO wires NO USB cable required Only as info. Still I need Korean Firmware or PIT file for: Code: SM-R765S SM-R765K SM-R765L No Stock Firmware nor Combination FTMA nor FT30... Best Regards | |
03-10-2018, 04:35 | #27 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | I am too old as it seems... or too much Vodka. SM-R730 series have STEADY on partition 26... Attached new RL off collection... But SM-R360 p15 like SM-R760/SM-R770 is correct. In theory it is very easy to identify where STEADY is... 1 way is to check simple PIT file... partition.pit So no device mandatory to search for STEADY or to confirm it is correct... Best Regards Last edited by adfree; 03-10-2018 at 04:44. |
The Following 5 Users Say Thank You to adfree For This Useful Post: |
03-10-2018, 05:43 | #28 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | SM-R600 Gear Sport not tested... No idea if Samsung changed something in Security... Code: STEADY partition is p17... PM me for help. Best Regards |
03-14-2018, 09:24 | #29 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Code: CSC_OKS_R775SOKS2CQL2_usr.tar.md5 CP_R775SKSU2CQJ4_CL401035_QB7878159_SIGNED.tar.md5 BL_R775SKSU2CQL2_usr.tar.md5 AP_R775SKSU2CQL2_usr.tar.md5 Will test if PIT is signed with same key like SM-R765S... Best Regards |
03-19-2018, 23:21 | #30 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Meanwhile we have 1 SM-R765 alive again. With mix of sboot.bin + cm.bin from SM-R765S... + PIT from SM-R775 + Firmware from SM-R775 (few files removed)... We have now working CQL2 Firmware. Best Regards |
