Old 07-23-2022, 22:30   #166 (permalink)
Member: 420658
Thanks Meter: 218
Tested on SM-R860 and SM-R870...
So IMHO also valid for SM-R890.
If problems like unknown device in Device Manager... switch green and white...
Best Regards
The Following 4 Users Say Thank You to adfree For This Useful Post:
Old 08-23-2022, 01:46   #167 (permalink)
Member: 420658
Thanks Meter: 218
For study...
SM-R870 Combination Firmware...
https://mega.nz/file/rBsW1ZJB#PahKa3...oDpM8kWePQ6lbA
I can not bypass eToken crap...
But with my rooted SM-R870 I was able to use FAC boot.img and FAC recovery.img...
And with Help of Magisk few APKs... with ROOT...
Only as info...
Best Regards
Old 09-08-2022, 14:57   #168 (permalink)
equinoks's Avatar
Member: 21508
Thanks Meter: 187
any R900 firmware link please??
thank you !
Old 10-06-2022, 11:22   #169 (permalink)
Member: 420658
Thanks Meter: 218
Please.
Need LDU Firmware for study.
SM-R860X
SM-R870X
SM-R880X
SM-R890X
And maybe somebody has older SM-R870...
I have DUK1 and EVA8...
Thanx in advance.
Best Regards
Old 10-07-2022, 22:01   #170 (permalink)
Member: 420658
Thanks Meter: 218
freshbl:/sdcard # mount -vo remount,rw /
try '/dev/block/dm-0' type 'ext4' on '/'
freshbl:/sdcard # cp Keystring_factory_FB.zip /system/priv-app
freshbl:/sdcard # cd /system/priv-app
freshbl:/system/priv-app # ziptool unzip Keystring_factory_FB.zip
Archive:  Keystring_factory_FB.zip
  inflating: Keystring_factory_FB/Keystring_factory_FB.apk
  inflating: Keystring_factory_FB/oat/arm/Keystring_factory_FB.odex
  inflating: Keystring_factory_FB/oat/arm/Keystring_factory_FB.vdex
freshbl:/system/priv-app # rm Keystring_factory_FB.zip
freshbl:/system/priv-app # rm -r GalaxyStore
freshbl:/system/priv-app # rm -r WFotaAgent
freshbl:/system/priv-app # cd ..
freshbl:/system # cd preload
freshbl:/system/preload # rm -r BudsController
freshbl:/system/preload # rm -r GlobalGoals
freshbl:/system/preload # rm -r MSOutlook_Samsung
No idea why. But with Root patched with Magisk 25.2... GVH2
I can write to /system
Only as info.
Best Regards
The Following User Says Thank You to adfree For This Useful Post:
Old 12-02-2022, 22:39   #171 (permalink)
Member: 420658
Thanks Meter: 218
User with dead SM-R870 (GVI3) told about endless loops and Diver Request for unknown PID...
Maybe similar problem if dead by GVK4...
For me it looks like sboot.bin is gone...
Requested Driver is:
VID_04E8&PID_1100&MI_00
Maybe somebody have an idea...
Thanx in advance.
Best Regards
Old 01-14-2023, 02:46   #172 (permalink)
Member: 420658
Thanks Meter: 218
Example of steady.bin aka eToken from GW4...
Looks to me like "Factory Token"...
Device Manufacturing
Taken from GW4 with Combination Firmware running...
It is dumped via dd from 4 MB steady partition...
Samsung seems to use Copy & Paste Protection... so RSA 2048 Signature is broken...
Maybe 2 Bytes missing or... FFFF IMHO more then 65 000 attempts...
Only as info...
Best Regards
Old 01-31-2023, 20:22   #173 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hey guys..
i am getting always this attention;
E:\R760\RLoff_v9>sdb connect 192.168.31.49:26101
connected to 192.168.31.49:26101
E:\R760\RLoff_v9>sdb root on
error msg: error: target not found
Old 01-31-2023, 20:50   #174 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
Originally Posted by LoveLess View Post
hey guys..
solved by using mobile hotspot instead of wifi...
E:\R760\RLoff_v9>sdb connect 192.168.43.74:26101
* daemon not running. starting it now on port 26099 *
* daemon started successfully *
fail to connect to 192.168.43.74
connected to 192.168.43.74:26101
Switched to 'root' account mode
E:\R760\RLoff_v9>sdb push empty.bin /opt/usr/media/
pushed                      empty.bin   100%        256KB
1 file(s) pushed. 0 file(s) skipped.
empty.bin                        341 KB/s (262144 bytes in 0.749s)
E:\R760\RLoff_v9>sdb shell dd if=/opt/usr/media/empty.bin of=/dev/mmcblk0p15
512+0 records in
512+0 records out
262144 bytes (262 kB) copied, 0.0264701 s, 9.9 MB/s
E:\R760\RLoff_v9>sdb shell reboot download
Rebooting with argument 'download'.
The Following User Says Thank You to LoveLess For This Useful Post:
Old 02-20-2023, 17:15   #175 (permalink)
Member: 946879
Sonork: 100.1615133
Thanks Meter: 20
C:\Users\user>adb root 192.168.0.108
'adb' is not recognized as an internal or external command,
operable program or batch file. FTER COMMOTION OPEN CMD NOT CONNACT
R760
Old 02-21-2023, 18:51   #176 (permalink)
Member: 946879
Sonork: 100.1615133
Thanks Meter: 20
where i can download adb files
Old 02-21-2023, 18:54   #177 (permalink)
Member: 946879
Sonork: 100.1615133
Thanks Meter: 20
C:\>adb root 192.168.0.109
C:\>
Old 12-01-2023, 03:25   #178 (permalink)
Member: 420658
Thanks Meter: 218
Please.
Need for study old FAC Firmware for SM-R875U:
COMBINATION_FAC_FBR0_R875USQU1AVE2_FACFAC_CL24349936_QB52279860_REV00_user_mid_noship_MULTI_CERT.tar.md5
COMBINATION_FAC_FBR0_R875USQU1AVF1_FACFAC_CL24506647_QB53168112_REV00_user_mid_noship_MULTI_CERT.tar.md5
COMBINATION_FAC_FBR0_R875USQU1AVG3_FACFAC_CL24733448_QB54122856_REV00_user_mid_noship_MULTI_CERT.tar.md5
Need only these old files...
AVE2 or AVF1 or AVG3 or older.
Thanx in advance.
Best Regards
Old 12-11-2023, 01:37   #179 (permalink)
Member: 2771748
Hello folks,
Is it possible to remove Reactivation Lock from GW4 R890?
I looked through the posts here and didn't find it, did I miss it?
Thanks.
Old 01-24-2024, 16:52   #180 (permalink)
Ligalig's Avatar
Member: 1079935
Thanks Meter: 511
Hi
Originally Posted by adfree View Post
if somebody need for study. As soon newer firmware via fota...
And rollback prevention crap is near...
Eva8 for 3 gw4 devices:
Eva8 for sm-r870
https://www.file-upload.net/download...z.001.abc.html
https://www.file-upload.net/download...z.002.abc.html
sm-r880 eva8
https://mega.nz/file/jjstlibd#bf3wzn...nle2e3mjnshoxy
https://mega.nz/file/mf8r0cjz#gy3tv5...pxtaghonb5346k
sm-r890 eva8
https://mega.nz/file/qnf0xzal#_qn6y5...ehgjiksvlw9q54
tested successfuly with netodin... We know from tizen world...
The 6 years old tool.
tiny hint.
Rename/remove .abc from file extension... To unpack with 7zip...
Result and ready to use in netodin:
smr870_eva8_oxm_v1.tar
smr880_eva8_oxm_v1.tar
smr890_eva8_oxm_v1.tar
original firmware contain fota.zip and *.lz4 compressed files...
But our old netodin not support *.lz4...
Best regards
do u have new link for this files?
The Following 2 Users Say Thank You to Ligalig For This Useful Post:
Page generated in 0.21486 seconds with 9 queries
